Red Lines in Picture grainy picture
Does anyone have an idea on what would cause this issue? I see it on all inputs including the menus. The TV is about 3 years old.
could it be the X-main board?
[IMG]http://i56.photobucket.com/albums/g178/fburke/DSC_0059.jpg[/IMG]
[IMG]http://i56.photobucket.com/albums/g178/fburke/DSC_0055.jpg[/IMG]
Try checking the board for swollen caps.. That fixed my Vizio p4
Posted on Sep 10, 2008
I am having picture problems with my n 64 connected to a Panasonic viera. The picture is black and white and very grainy if anyone can help I would be very grateful thanks
If there is no yellow socket (terminal) on the TV, as in most recent year's VIERAs:
Connect the Yellow male plug from your gaming device into the TV's GREEN female socket (terminal).
Press INPUT on the Panasonic TV remote and select the Video input. In some VIERA models, you need to press INPUT, go down and select the Comp. option and then press >right to select Video.
To get audio (sound), make sure to connect the Red and White plugs from the gaming device into the TV's Red and White sockets (terminals) that are labeled AUDIO.
Mar 26, 2016 | Panasonic Televison & Video
Vizio xvt3d580cm has red contour lines in dark regions of picture. What causes this?
Does it do this using more than one input? Have you tried using a different source such as DVD? IF using HDMI inputs does it do it on all of them? I have seen this trouble because of configuration issues with some satellite boxes also have seen similar issues because of a bad HDMI input.
Oct 13, 2013 | Vizio VO37LHDTV10A 37 in. LCD TV
Mitsubishi 62725 lines scrolling in picture
Try first a DVD etc connected to a rear audio and video input, that may rule some things in or out.
Set does have a soft reset but it is unlikely to help for this issue
Dec 23, 2012 | Televison & Video
Samsung ln52a650a1fxza LCD has horizontal band of dark lines across screen
check connections on top of screen this is becoming a stockfault on samsung tvs
Dec 01, 2012 | Televison & Video
Hitachi RP CRT Gone Red On All Inputs!!!
I want you to do a simple visual check of something that will tell me what the problem may be.
Go to a channel that is in black and white--old movie and tell me what color the screen/picture is.
You can also turn the COLOR in the customer menu all the way off and look that way.
What we are trying to see here is if TRACKING is set correctly or has changed. If the screen is somewhat to medium reddish it may be an adjustment outside of the customer menu.
Let me know what you find--I have seen several of these where the black and white picture was somewhat red--the idea is it should be as close to black and white as possible--if red is the predominant background color the picture will look reddish.
If this has helped and you confirm the red instead of black and white picture--I can tell you a easy way to adjust this.
If this information told you something you did not know and helps you rate this solution as I do this here for free.
SD TECH
Dec 23, 2009 | Hitachi 57F710 TV
Grainy and red tint on component video inputs from
Usually when you have a red tint when using the component input i'ts because the wires are switched on one end or one of the 3 video wires is bad. See if blue and green are switched.I see this all the time. Is your picture grainy on all input?
Nov 22, 2009 | Panasonic TH-42PX75U 42 in. Plasma...
Hitachi 51GWX Scrambled Picture
STK392-560 STKS convergence CHIPs Replace both of them.
Feb 24, 2008 | Hitachi 51GWX20B 51" Rear Projection...
LCD RCA quality issue with V.Smile
No picture or sound on TV with V-Smile. Could the wires be replaced on the V-Smile?
Dec 10, 2007 | Televison & Video
Televison & Video Logo
205 people viewed this question
Top Televison & Video Experts
