I HAVE A GOODMAN FURNACE GMS8 WHAT IS THE LARGEST SEER RATED AIR CONDENSER WILL WORK WITH THIS UNIT.
  • 182 Answers
Seer is not a problem....18 would be fine.depending on the size of the blower,you may have limitations on tonnage of the ac.
Posted on Sep 10, 2008
Purchased Rheem 4 ton 16 seer AC installer just left
Ask your installing company for the AHRI number. If installed with a
matching furnace and coil as listed in the certification then you will get 16 seer rating. If they installed something different than what is listed in the certificate then demand all parts listed or a refund.
Jul 18, 2014 | Rheem 14AJM49A01-RHLLHM4821JA 4 Ton 16...
Why condenser won't start board flashes6times meaning open rollout
check your roll out with an ohm meter they should have continuity if not they have a reset button on top of the switch push it and this will reset them. If they don't have continuity they are open.
Jul 17, 2014 | Goodman Manufacturing Goodman DSXC180601...
Difference in seer
i would check fan speed. it's probably on high. you might be moving more air with new system. a dirty evaporater on old unit woud have gave you a larger temperture drop.
Jun 16, 2014 | Goodman Heating & Cooling
I have a GMS8 furnace and it will not kick on.. No heat coming out of heater vents..
Is inducer motor running. If not change it. If it is then remove vacuum line from it and blow through the line on start up. If this works change the pressure switch. If not start jumping the sensors around the burner until you find the bad one
Jan 23, 2013 | Goodman GMS90703BXA Heater
I have a gms8 furnace that will not light. The error code that I get is 3 fast blinks
Sorry to read about your problem, I hope this helps you out.
3 Blinks represent a problem with the combustion fan, pressure switch or a vent blockage.
if you have snow, it could be blocking the intake vent. if not that, most likely a defective preassure switch.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 02, 2011 | Goodman GMS90703BXA Heater
Can I change airflow direction with Goodman GMS8?
I would probably use a furnace for the correct application. However some motors do have a reverse speed connection. Besides the blower speed taps,
capacitor wires and the nuetral wire. There are two wire sets that you can switch that can do this if your blower motor is equipped.
You might experience some airflow problems, probably a lack of airflow, if the furnace was installed
as an upflow model instead of a counterflow.
Feb 17, 2010 | Goodman GMS90703BXA Heater
Extremely long time to get cool air with 5 ton 13 seer goodman heat pump which is 3 years old.
Check your filter. Make sure it is clean. Make sure the outdoor unit is operational. (power on). Clean your condenser coil with a garden hose. If possible check your evaporator coil. If it is dirty clean it. Your furnace (or air handler) blower speed should be set on high. All of your registers (supply & return) should be open and unobstructed. Check for proper thermostat settings. If none of this information solves your problem , then your units charge needs to be checked. You could be over or undercharged with freon.
Good luck......
May 06, 2009 | Goodman Heating & Cooling
Heating & Cooling Logo
123 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
