Question about Sub-Zero 15.3 cu. ft. / 433 liter Upright Freezer 700TF
Control panel on sub zero built in 700 series freezer is showing 2 bars with no info and i can not get it to change
  • altdjsmoke Apr 19, 2009
    control panel goes to 'two bars' when I try to raise the temp per the owners manual - cannot adjust above 34.
    Genius:
  • 1,239 Answers
Hi use a user manual guide or see the control pannels divisions thank u,,rate it
Posted on Sep 10, 2008
Water is leaking out from the fridge floor onto the ground.
The drain pan in the back evaporates from the heat of the compressor. The freezer drain drains into this pan. If there is water under the bins it sounds like the drain is partially clogged and over flowing into the refrig section. But I need more info, like model , brand.
Nov 17, 2013 | Sub-Zero 700 Refrigerator Freezer...
690 series subzero freezer issue
Richard, what you are doing is ok for afew month. Your system is not broken yet. There could a variety of reasons. Wait until it breaks.
Nov 16, 2013 | Freezers
In the control panel apear two bars like this - -
You have a code error that needs to be fixed. Call either your mfr or refer to manual or google the problem , include. Model # and code .
Feb 07, 2013 | Sub-Zero 700 Refrigerator Freezer...
My freezer drawers are very warm All food defrosted smells horrible even after cleaning. Should I clean condensor, temp is not cooling?
It is likely the condenser fan is not functioning, or the condenser is dirty. You may need to open the compressor access panel to check. If you can hear the compressor running, and the condenser feels warm, the fan should be running. If it isn't, it probably needs to be replaced. Another symptom is the area around the doors feels warm.
Jan 01, 2013 | Sub-Zero 700 Refrigerator Freezer...
Sub Zero 700 suddenly stops after 12 years. Compresser is burning hot.
The compressor will normally be 100 to 110 degrees. I would suspect the thermostat or mouse damage in the freezer area. Also, if you keep it overstocked, to the point of poor air circulation, you could just have ice blockage. Put the frozen food in a styrofoam cooler or a good heavy corrugated box and give the unit a good full defrosting.
Dec 15, 2012 | Sub-Zero 700 Refrigerator Freezer...
Water on floor
The hose that goes into the drip pan to defrost the refer is plugged with stuff.
take the back off and see the hose connection.A coat hanger works well.Usually a 1/4" hose.
Also see where the bottom of the freezer drains into the drip pan.That may be plugged,also.
The temp may be set too low and the condenser is frozen up,leaking water into the floor.Just ice stuck to the condenser.
Possible that the condenser FAN stopped turning. That will ice up and melt at random:
see/hear that the fan is working.
If stuff gets into the fan,it will ice up,melt and make a mess on the floor.
Nov 26, 2012 | Sub-Zero 700 Refrigerator Freezer...
Sub zero freezer - 501 f
It is likely the condenser fan is not functioning. You may need to open the compressor access panel to check. If you can hear the compressor running, and the condenser feels warm, the fan should be running. If it isn't, it probably needs to be replaced. Another symptom is the area around the doors feels warm.
Jun 19, 2012 | Sub-Zero Freezers
I have a Sub-Zero Model 501F freezer making ice cubes
Check defrost heater that goes into drain tube. When the drain freezes ;the defrost water spills into the icemaker.
Oct 08, 2009 | Freezers
Sub-Zero 15.3 cu. ft. / 433 liter Upright Freezer 700TF Logo
211 people viewed this question
Top Sub-Zero Freezers Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Roderick Scott
Roderick Scott
Are you a Sub-Zero Freezer Expert? Answer questions, earn points and help others
