Question about HP Officejet 6500 Wireless All-in-One InkJet Printer
How to set it up for wireless printing. guide says use wizard there is no wizard option
    New Friend:
Am bodilon..pls .i want to setup my pockect pc panasonic
Posted on May 28, 2012
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 126 Answers
Hi, To set up wireless communication using the device control panel with wireless setup wizard, please follow this instruction:
The Wireless Setup Wizard provides an easy way to set up and manage a wireless connection to your device.
NOTE: To use this method, you must have a wireless network set up and running.
1. Set up the device hardware (see the getting started guide or the setup poster that came with your device). 2. On the device control panel, press the Setup button. 3. Press an arrow button to move to Network Settings, and then press OK. 4. Press an arrow button to move to Wireless Setup Wizard, and then press OK. 5. Follow the display instructions to complete the setup.
I hope this helps!
Posted on Sep 01, 2011
SOURCE:
How to instal
You'll wanna check out: ftp://downloads.netgear.com/files/WNR1000_SM_WW_23Jan09.pdf
Look for "installation"..
To help you set up your router and get on the Internet quickly, the Resource CD contains a Smart Wizard™ Installation Assistant. The Installation Assistant walks you through the steps required to connect your router, modem, and PC(s); configure your wireless settings; and enable wireless security for your network. When you have finished, you will be Internet ready!
You can set up your wireless router using one of two methods:
• Smart Wizard Setup: The Smart Wizard Installation Assistant setup is available on your Resource CD. See "Installing Your Router Using the Smart Wizard" on page 9 to use the Smart Wizard Installation Assistant.
- This is the easiest option. The wizard guides you through the setup process. It automates many of the steps and verifies that the steps have been successfully completed.
- Smart Wizard requires a PC running Microsoft Windows.
• Manual Setup: If you cannot or prefer not to use the Smart Wizard Installation Assistant, see "Manually Installing Your Router" on page 13. For example, if you are connecting to a Mac, are using a Linux operating system, or are technically knowledgeable, select this option. If you choose to use this option and install your router manually, for best results, install and set up your router in this order:
Failure to follow these guidelines can result in significant performance degradation or an inability to wirelessly connect to the Internet.
NETGEAR does not recommend or support adding a NETGEAR router behind another router, or replacing a gateway with a a NETGEAR router.
If you have a Macintosh or Linux system, you must use the manual installation method (see "Manually Installing Your Router" on page 13).Getting to Know Your Wireless Router 7
1. Install and connect your wireless router to your network (see "Connecting Your Wireless Router" on page 14).
2. Set up your wireless router for Internet access (see "Setting Up Your Router for Internet Access" on page 18).
3. Configure your wireless network and select wireless security settings to protect your wireless network (see "Configuring Your Wireless Network" on page 21)
Feb 04, 2011 | NetGear WNR1000 Router
Wont allow me to connect 2 additional computers and need pin name or number
Two methods to solve your problem:
Method 1:
(1) Using your currently connected and working computers, access the wireless router security page at 192.168.1.1 (page 8 of 44 from the WRT54G2 manual), default password "admin" (page 7 of 44 from the WRT54G2 manual)
PDF file of the Linksys/Cisco Wireless-G Broadband Router User Guide:
http://belkashop.com.ua/products_files/WRT54G2_V10_EN.pdf
You'll need Adobe Acrobat Reader to view/print this file - free from www.adobe.com
(2) get the WEP or WPA password, and enter it into the wireless LAN (WLAN) settings on your 2 additional computers.
Method 2:
Alternatively, access the WEP or WPA key on one of your working PC, by
(1) make sure the printer is working, powered up and online.
(2) invoke "Network Setup Wizard"
(3) wind thru various steps (click-ing NEXT), then select "Print Network Settings"
(4) use the printed WEP or WPA key in the WLAN settings on your additional 2 PCs.
Jan 02, 2011 | Linksys WRT54G2 Wireless Router
How to turn on wifi
Configuring the optional internal wireless print server
If you purchased the optional internal wireless print server after your printer was already set up, follow these steps:
1 Install the internal wireless print server into the printer. For more information, see "Installing an optional internal
wireless print server" in the "Setting up the printer" chapter.
2 Click Start Programs or All Programs Lexmark 3500-4500 Series.
3 Click Wireless Setup.
4 Click Start.
5 Follow the instructions on the computer screen.
6 Click Finish to complete the installation.
Also here is the link to the setup guide and user manual
click here
configuring the wireless is in the setup guide
Oct 18, 2010 | Lexmark X3550 All-In-One Printer
Hello, How do I connect my Epson stylus PHOTO px700 to my laptop?
NETGEAR’s 54 Mbps Wireless Print Server with 4-port Switch allows you to connect one or two printers to your existing wireless network, without using unsightly Ethernet cables. Simply place your printers anywhere in your home or office that works best for you, plug them into the print server’s USB ports, and the Smart Wizard set-up function automatically guides you through configuration. Then you can send your business documents to a high-end color printer, and your kids’ homework to a black-and-white printer. The print server also acts as a wireless Ethernet bridge, connecting a cluster of up to four PCs and laptops without requiring dedicated wireless adapters. I t employs powerful WEP Encryption and WPA-PSK to keep your wireless network secure, and interoperates with all standard b and g wireless devices. All this in a sleek, space-saving stand-up case.
Mar 22, 2010 | NetGear WGPS606 (WGPS606NAR) Print Server
D-Link DPR-1260 print server setup problem
Try admin for logon & password.
Sometimes it is user ......
Feb 01, 2010 | D-Link RangeBooster G DPR-1260 (DPR1260)...
Cann't get my wireless router to work,don't understand how to config the router.
HI helock,
This is a step by step instructions:
Note: It is recommended that you configure the Wireless Router from a wired
computer.
1. Open your web browser, type http://192.168.10.1 in the Address bar, and then press Enter.
2. Enter the User Name and Password, and then click Log In. By default: User Name: admin Password: admin
3. The Wizard will automatically appear. Click Wizard if the Wizard does not automatically appear.
4. Click Next.
5. Select your Time Zone and then click Next.
6. Click Next. Note: Do not change default settings unless it is conflicting with your existing hardware.
7. The TEW-432BRP will attempt to auto detect your Internet connection. Follow the wizard instructions and continue on to step 9.
8. This screen will appear if the TEW-432BRP is unable to auto detect your Internet connection. Configure the settings based on information provided by your ISP.
9. Follow the wizard instructions to complete the configuration. Note: Each Internet Connection type may have different options.
10. Click Next
Note: It is recommended that you enable encryption on the wireless router. Please refer to the User Guide on the User's Guide CD-ROM for information on
setting up encryption on the wireless router. 11. Click Restart. 9. Follow the wizard instructions to complete the configuration. Note: Each Internet Connection
11. Click Restart
12. Click Close.
13. Wait 30 seconds while the router reboots.
14. Verify that the following panel lights are on: LAN, WAN and WLAN.
15. Open up your browser and enter in a URL (e.g. www.trendnet.com) to verify that you have Internet connection.
Your configuration is now complete.
Good Luck,
And don't forget to leave a rating
Thanks
Mark
Sep 14, 2009 | Trendware TRENDnet TEW-432BRP 54Mbps...
How do i make my speedstream 6520 wireless?
"If your PC has not been connected to a broadband modem or other network device, you will need to
perform the PC configuration procedure below. Remember to restart each PC when finished. If your
PC has been connected to a broadband modem or other network device, continue to the “Using the
Wireless Connection” section below.
1. Start your Web browser. In the Address box, enter the following: »speedstream.
2. Press Enter. The SpeedStream Simple Setup Wizard will launch.
3. When prompted, enter the Internet connection information provided by your
Internet Service Provider.
4. At the end of the Setup Wizard, you will be given the option to either connect to
the Internet or further configure the optional settings of the gateway.
5. If additional configuration is desired, select the icon for the service or option
you wish to configure: the gateway’s firewall and security settings, User
Profiles and content filtering, or home network options."
"Using the Wireless Connection
By default, the SpeedStream® Gateway is configured to work
seamlessly with other SpeedStream® wireless products. The default
wireless interface settings are:
SSID: SpeedStream
Channel: 11
Mismatched wireless settings will prevent successful
wireless network connections between devices, so
you may need to reconfigure some wireless settings
to ensure that all settings match between wireless
devices if you are:
a) Using another manufacturer’s wireless products
b) Adding the SpeedStream® Gateway to an existing
wireless network
The Setup Wizard will walk you through setting up wireless settings."
Jun 14, 2009 | Computers & Internet
NetGear PS121 Print Server Problem
Here are some troubleshooting steps that I suggest you try:
1. Check physical connections.
a. Connect the modem to the Internet port of the router. The Internet “i” LED on the front of the router should light up.
b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password".
Note: If you were unable to access the router's web-based utility, you may reset the router to restore the settings to factory default.
To reset the router:
a. Please push the reset button at the back of the router and release after 30 seconds.
b. Unplug the power adapter for 10 seconds and then plug it back in.
3. Configure the router.
If your Internet Service Provider is using a cable connection, please follow the steps below:
a. Click on Basic Settings under Setup tab.
b. Select No for Does Your Internet Connection Require A Login?.
c. Scroll down on the center page and look for the Router MAC Address section. Set it to Use computer MAC address and click on the Apply button.
If your Internet Service Provider is using a DSL connection, please follow the steps below:
a. Click on Basic Settings.
b. Select Yes for Does Your Internet Connection Require A Login?.
c. Select Other on the Internet Service Provider drop down box.
d. Enter your ISP's username (username@ISPdomain) and password. Then, click on Apply.
4. Configure the wireless settings.
a. Click on the Wireless Settings under Setup.
b. Change the SSID to any unique name.
c. Scroll down, look for the Security Options settings and select WEP (Wired Equivalent Privacy).
d. Set the Authentication type to "Automatic" and the Encryption Strength to "64bit".
e. Leave the Passphrase field blank, select Key 1 and enter a 10-digit number.
Note: The 10-digit number you typed in the key 1 will be the password or network key for the wireless connection.
f. Click Apply button to save the changes.
g. Go to Router Status under Maintenance tab and check if there is an IP address under Internet port. If it's 0.0.0.0, do a power cycle.
5. Power cycle.
a. Power off the modem, router and computers.
b. Turn on the power of the modem first and wait for it to initialize, the lights to stop blinking.
c. Power back the router and the computers. Check if it will be able to get online.
If you have wireless computers, you can connect them wireless to the router. Kindly follow the instructions below:
6. Connect wireless computer to the router.
If you are using Windows XP with Service Pack 1, please follow the steps below:
a. Please right click on the Wireless icon on the right lower end portion of your computer.
b. Then click on View Available Wireless Networks.
c. Click on the Advanced tab.
d. Please delete all the preferred networks then click on OK.
e. Right click on the Wireless icon again and click on View Available Wireless Network. Please select your network and click on Connect. It will ask you for the network key.
f. Please type in the network key and then confirm it. Network key is the password you type on the key 1 of the wireless settings of the router.
g. Make sure not to enable IEEE and then click on Connect.
If you are using Windows XP with Service Pack 2, please follow the steps below:
c. Click on the Change Advanced Settings.
d. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
e. Right click on the Wireless icon then click on View Available Wireless Networks.
f. Select your network and click on Connect.
g. It will ask you for the network key. Type in the network key and confirm it. Then click on Connect. Network key is the password you type on the key 1 of the wireless settings of the router.
If you are using Windows Vista, please follow the steps below:
a. Click Start then select Connect To.
b. Connect to a network window will show up.
c. Select your wireless network and click Connect.
d. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect.
From the above configuration, please check if you can now access the Internet.
For the print server setup, please follow the steps below:
Note: Before setting up the print server, make sure that you can print when printer is connected directly to the computer.
1. Wire the print server to router. Check the lights on it. It should have the ACT light on and the Error light off.
2. One way to test if the printer would work with the print server is to reset the print server for 3 to 5 seconds while it is powered on and after you release the button, the printer should automatically print the IP address of the print server.
Note: If the printer did not print, there is a possibility that they are not compatible. However, you may still continue to try to set up the print server.
3. Install the PS121 software.
a. Power on your computer, let the operating system boot up completely, and log in as needed.
b. Insert the Resource CD for the PS121 into your CD-ROM drive. The CD main page shown at the right will load.
c. Click Install Software.
d. Click Next and follow the software installation utility prompts to complete the software installation.
e. When prompted, restart your computer to complete the installation.
f. When your computer restarts, click Finish to run the Print Server Setup Wizard.
4. Run the Print Server Setup Wizard to Set Up a Fixed IP Address for the PS121.
a. The Print Server Setup Wizard screen should be displayed.
b. Click Next to proceed. The Print Server Wizard will now search your network for the PS121. If the Print Server Setup Wizard cannot find your PS121, check the network connections and status lights on the PS121.
c. The “Server Name” and the “IP Address” your network assigned to the PS121 are displayed. Click Next to proceed to the device name screen.
d. You can enter a descriptive Device Name and Domain Name or accept the defaults. Click Next to proceed to the IP Address configuration screen. The Print Server Wizard displays a recommended static IP address setting for the PS121. This is usually fine.
e. Click Next to proceed.
f. Click Finish to exit the Print Server Setup Wizard. This completes the configuration of the PS121 for operation on your network.
g. Click Yes to run the Add Printer Port Wizard. Follow the instructions in the next section for using the this wizard to set up each computer to use the PS121.
To set up each computer to use the PS121, please follow the instructions below:
1. Use the NETGEAR Add Printer Wizard to set up each PC to use the PS121.
a. When the Print Server Setup Wizard finishes, you are prompted to run the Add Printer Port Wizard. Click Yes to proceed. Alternatively, from the Windows Start menu NETGEAR Print Server program group, you can run the NETGEAR Add Printer Wizard.
b. After a short delay while the software searches the network for your PS121, the Printer Select window opens and displays the PS121 you have set up.
c. Click Next to proceed to the Port/Printer name screen. Take note of the printer model number listed.
2. Set up the correct printer driver for the printer port.
a. Click Next to proceed to the Port/Printer name screen. Take note of the printer model number listed.
b. Click Next to proceed to the Select Printer screen. If you see the exact printer model number listed as the printer model number from in the previous screen, click it to select it from the list.
c. If prompted, print a test page to verify operation of the printer and the PS121. Then, close any remaining Add Printer Port Wizard or Windows Add Printer Wizard windows.
Use the NETGEAR PS121 Mini Print Server Resource CD to run the Add Printer Port Wizard to set up each PC on you network that you want to use with the PS121. Select the port you added
You may also use the links below as your guide to troubleshoot the print server:
http://kbserver.netgear.com/kb_web_files/n101269.asp
http://kbserver.netgear.com/kb_web_files/n100033.asp
However, if this does not resolve the issue we will need to get some additional details from you to be able to assist you further. I have summarized my questions below:
1. Model number of router
2. Model of printer
3. Operating system of computer/s
Apr 26, 2008 | NetGear PS121 Print Server
HP Officejet 6500 Wireless All-in-One InkJet Printer Logo
1,164 people viewed this question
Clive
Clive
Thomas F. Schneider
