Back to:
Tags:
SanDisk SDMX1 MP3 Player
Sticky play button (by 3 users)
posted by mauler on Apr 09, 2006
The play button is stuck so it won't play the next song without me controlling it.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by Guest, posted on Apr 23, 2008
I don't know which button to touch to play all my 27 playlist.
Comment by kevin_24, posted on Mar 30, 2008
on my dell pocket dj the play button is also stuck..so i cant use it at all please tell me what i can do with out sending it back to the company and getting a new one or gettinbg it repaired!! i just want to know what to do so i can do it my self. thank you
Best Solution
posted on Apr 09, 2006
FixYa! (100)
techman
Rank:Guru Guru
Rating: 87%, 6806 votes
If you mean the push button got push down into the case then youll have to probably replace the case as these buttons are most of the time attached right to the outer housing and are not available by them selfs. if you wanna take a chance then open the unit and take out the pcb chassis and see if you can push back the s,mmall button but its something I would not recommend as there are lots of problems you can cause if you dont know the right procedture on disassembly.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on sticky play button:
I don't want to Accept this solution
Solution #2
posted on Jan 06, 2008
Not Rated (0)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
i think you might have accidentally set it to repeat. find it in the menus
Thank You!
Solution #3
posted on Mar 23, 2007
Not Rated (0)
Rad2girls
Rank:Master Master
Rating: 73%, 38 votes
and you might damage a hardware tooooo.....
Thank You!
Can you Help with these MP3 and Digital Media Players problems?
CAN'T REMEMBER HOW TO ACCESS SETTINGS FOR AUDIO OUTPUT -...
I have deleted all the files from the player and now I can...
every time i plug in my mp3 player it tells me it...
i downloaded the songs from limewire but they didnt...
I have one of these ReFurbs. SanDisk SDMX!-512R. I tried...
Loading problems.
Repair Service
Find MP3 and Dig. Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
