Reds are printing brown - Televison & Video
    Novelist:
    Champion:
  • 203 Answers
How is the set hooked up? Does it do this on all inputs? If it does it on one input only and its hooked up componet then it may be something as smiple as a bad cable between the cable/sat box and the tv. Other things could cause this as well. a model number would be helpfull.
Tim
Posted on Sep 11, 2008
Dell 2145cn won't print red properly
Check the red ink printer cartridge. also check the settings
Nov 07, 2012 | Dell 2145cn All-In-One Laser Printer
CANNON MP510 The RED is printing as a dullish brown/red how can I fix this please Ron Bowen Australia
Find your printer, go to properties, then find maintenance. You should have an option named "head cleaning". Just follow the instructions. Sometimes, you have to clean the print head several times before obtaining satisfying results. Just bear in mind that cleaning the print head uses a lot of ink.
Hope that helps!
Mar 05, 2010 | Office Equipment & Supplies
I need the color code for phone cables. 25 pair up to 1800 pair. I need to splice it.
white/blue
white orange
white green
white brown
white slate
red blue
red orange
red green
red brown
red slate
black blue
black orange
black green
black brown
black slate
yellow blue
yellow orange
yellow green
yellow brown
yellow slate
violet blue
violet orange
violet green
violet brown
violet slate
**Keep all pairs together and you should be fine***
Feb 22, 2010 | Lands Phones
Colors are off. Browns print green or purple. I
BROWN is made by mixing two of the three "primary" colours.
So, if the printer is out of RED ink, you'll get the "other" primary colour.
Print a "test" page, and verify that part of that page is RED.
Run a printer "cleaning" cycle, and consider replacing the RED cartridge.
Jan 08, 2010 | Canon i860 InkJet Photo Printer
My brand new ESP 5 will not print red letter on a
It seems to be a problem with the colour ink cartridge ,did you remove the protective tape that came with it?
you should return the colour cartridge and get it replaced or buy another one.
If that doesn't solve it then return the printer since it's under warranty.
Jun 15, 2009 | Kodak ESP 5 Printer
Prints all yellow, with some blue and black, no brown
the problem is very simple the magenta ink the cartridge is over or the head is been blocked from where the magenta ink comes out,
because red colour requires ---yellow plus magenta(pink)----to make it red.and ----dark yellow plus magenta(pink) -------- for brown colour.
Nov 22, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Red prints as "brown"
Either 01 of the ink from the cartridge is emptied or the cartridge has exhausted.
Warm Regards,
Manoj Joseph
+91 9352008418
May 01, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Changed all 3 colors and black---Red not printing
Print is brown: mingles yellow with bk and cyan and red.
Did you use generic ink? You have to use a set of original brother ink carts: dinsert the original carts. press menu then start b/w copy then fourtimes arrow-up. when machine is in maintenance mode press 7 then 6 then 4 then start b/w copy. machine will initiate the carts and do some power cleaning. whnen finished press 7 then 6 then 3 then start b/w copy. machine does a power purge. leave maintenance by pressing 9 then 9. Do run a test print. If you cant see any mag. do the power purge two days later. If your not lucky then (you cant see ANY mag squares on test print) the head is defective and needs replacemnt.
Mar 16, 2008 | Brother MFC 420CN All-In-One InkJet...
Red colour prints brown
Just replace the non genuine inks with proper Canon ones and then do about 4 full cleans, that should fix it. If not you will have to replace the printhead, which is usually caused by using non genuine ink. Good luck
May 27, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
Canon iP6700D printer
Browns printing pink suggest the blue/yellow jets are clogged or not functioning. If the uses head in cartridge type[that is with a sheet of contacts on the front of the cartridge- then take then out ,damp a tissue in some warm water an place on a plate or similar - then stand the cartriges in the damp tissue until the tissue turns colour - then replace the cartrdge. If it is head in the printer Then take a look here www,fixyourownprinter.com
May 24, 2007 | Canon Pixma iP6000D InkJet Photo Printer
Televison & Video Logo
Top Televison & Video Experts
