Question about Western Digital 500GB My Book World Edition 500 GB Hard Drive
Cannot remove mp3 player
Can't remove device from my J drive-pop up reads "generic volume device in use, turn off what's using it and try again later" later has gotten too damned late! HELP!!!
    Sergeant:
  • 300 Answers
Ah ! , which means brother in hebrew by the way ,
your drive is in use by windows , simply turn off the computer and remove the drive.
it really is that simple
shalom
Posted on Sep 11, 2008
How can i keep my mp3 on so i can put music and videos on it
Make sure the hold/lock switch is not engaged.
Try another USB port.
If that fails:
Triple Reset for Philips’ GoGear:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
-Tha Mp3 Doctor
Mar 04, 2009 | Philips GoGear SA3125/37 MP3 Player
The device Generic volume cannot be stopped right now. Try stopping the device again later
why not try to use a separate program to safely remove the drive.
download here
what is it?
USB Safely Remove is a USB device manager. It saves time and extends user abilities on active work with flash-drives, portable drives, card readers and other gadgets.
post back and let us know.
Feb 09, 2009 | Seagate Maxtor 750GB One Touch 4 Plus...
My philips 2gb wont turn on
All of your issues may be hardware-related - call Philips to see if you are still under warranty. To narrow it down, try this:
-Tha Mp3 Doctor
Feb 02, 2009 | Philips GOGEAR SA6045 MP3 Player
9-in1 card reader, USB ports can't be "safely removed"
GO INTO CONTOL PANEL UNDER INSTALLING NEW HARDWARE OR INSTALL NEW DEVICES
IT SOUNDS LIKE IRQ OR COM PORT ISSUE
SEE IF SET THE COMPORT 7 OR 8
CONTACT ME AGAIN
CANDYMANGANDY
Jan 28, 2009 | Microsoft Windows XP Home Edition
Device Manager can't read the device
Here is something you can try:
-Tha Mp3 Doctor
Jan 12, 2009 | Philips HDD1630 MP3 Player
I cant start my mp3 player
2 diff. problems, actually, disguised as 1:
hotroger - Your description has some holes in it - When you add large files, or a large number of files, to an mp3 player, it will stay stuck on updating for upwards of 30 minutes. The solution to that problem is to only give it a few songs or 1 movie at a time. So, for your player to say updating and not show the main menu sounds normal so far. What happened between the time when it was disconnected from the computer and when you replugged it into the computer? If you didn't let it finish updating, or turned the player off while it was updating, you frazzled that poor player's brain. Connect the player in the OFF position to the computer while holding in the volume + button (it is the arrow button in some of the newer GoGear's). Continue holding volume + (or arrow) for 5-15 seconds until a Window pops up on your computer saying Found New Hardware Wizard - it will half-cocked lead you to Repair your device using the Philips Device Manager. Once the Repair is complete, all your songs/videos will be erased but your player should work again.
ranke - You were trying to add files that were not in the proper format. Load only songs in mp3 format, and you will never have this problem again. Many of the newer Philips players are not DRM-compatible, and the songs you were trying to load probably had DRM protection.
-Tha Mp3 Doctor
Dec 20, 2008 | Philips GoGear SA178 MP3 Player
Turining my mp3 player on
You need to upgrade the firmware
-Tha Mp3 Doctor
Nov 28, 2008 | Philips GOGEAR SA6045 MP3 Player
Cant detect as portable device
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard
Apr 28, 2008 | Samsung YP-K3 MP3 Player
RCA OPAL M4002 mp3 player
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Mar 20, 2008 | RCA OPAL M4001 MP3 Player
Western Digital 500GB My Book World Edition 500 GB Hard Drive Logo
133 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
