Question about SanDisk SDMX1 MP3 Player
Stick play button
The play button is stuck so it won't play the next song without me controlling it.
  • Anonymous Jun 04, 2008
    My play button doesn't "click" on my SanDisk sdmx1 512 mp3 player. Is there any way to resolve this?
    President:
  • 3,130 Answers
You could attempt to open and free the button but you will probably need a entire case assy.. You should contact http://www.sandisk.com/Retail/Default.aspx?CatID=1246 Good Luck
Posted on Apr 15, 2006
How do i skip to the next cong quickly
According to the manual, which can be found online here: http://www.radioshack.com/graphics/uc/rsk/Support/ProductManuals/55041503_PM_EN.pdf, once you start a song using the Play button, you can immediately press the Next button to skip to the next song. It appears that the next button is the right button on the control pad.
Here is the layout of the control pad, from what I can determine online: Play/Pause Previous Next Volume
Jun 02, 2011 | Mach Speed Eclipse 180 MP3 Player
I have a Polaroid PMP280cb-4 and the songs will only play for 10 seconds and then it switches to the next song. How do I get it to play the whole song?
It's stuck on intro mode....I have the same Mp3 and I've had the same problem, just press the reset button on the side. (requires a pin or needle)
Feb 21, 2011 | Audio Players & Recorders
My swimp3 will not go to previous song when I hit the previous button. When I hit the Next button, it will go to the next song; however, the previous button will only go to the song that is currently...
There will be a 4-7 digit number stamped on the backside of the USB stick when the cap is removed, can you provide this number please? Also you can try double tapping the previous button, for with the new Firmware update the units have received this is the standard function. If you have any other questions feel free to contact me directly a mmoss@finisinc.com.
Jan 22, 2011 | Finis Swi MP3 Player
My uncles mp3 only plays 10 seconds of a song each time it plays
Your Uncle's player is stuck in INTRO mode. To remedy this problem
1. Play a song
2. press the button on the side of the player
3. Select PLAY MODE
4. Choose NORMAL
Sep 12, 2009 | GPX ML648B MP3 Player
I've just purchased a Laser MF001 - MP3 player and have downloaded my songs. Now it won't work, how do I turn in on?
- Make sure you have installed AAA battery: MP3 player won't work otherwise (it does not need a battery to work as USB memory stick to transfer/delete songs or data) - To turn-on (or off for that matter), press first button on your LHS (eg. same side as earphone plug) for 2 or 3 seconds until (blue) LED is on: if you press button too long after the LED is on, it will switch the player off! - When the LED is on, stop pressing this button: it is ready to play the MP3 track by pressing on this same button until the LED starts flashing (LED will keep on flashing while track is playing). - If you want to skip this track and get to the next track, quickly press and release the next (e.g. middle) button. - The third button (e.g. nearest to the USB plug), quickly press and release, is used to rewind or go back to previous track. - Volume control is also performed by pressing and holding down the second or third buttons Have fun!
Sep 03, 2009 | Audio Players & Recorders
My ps2 controller doesn't do what I want it to.
well.you can unplug the controller blow into the end or your controller is broke.good luck!
Apr 10, 2009 | Sony PlayStation 2 (PS2) Console
Problem with MP3 player-Stops after one song
On closer look (after my long road trip to test this out), I realize when you hit Browse, there's a button on the bottom titled Play All. If you select this button, the buttons mentioned above work as intended, and the Forward, Backward buttons bring you to the next or previous songs in the list.
Sep 27, 2008 | Garmin Nuvi 660 GPS Receiver
Nextar mp3 player button problems
i figured out how to use it without using the play/pause botton by going to browse it plays the song automatically instead of having to press play.
thank you for the help
Jul 28, 2008 | Nextar MA933A MP3 Player
Ipod nano 2nd generation won't fast forward
Turn repeat off in the menu.
Setting iPod nano to Repeat Songs
You can set iPod nano to repeat a song over and over, or to repeat a sequence of
songs. iPod nano repeats songs within the list you choose to play.
To set iPod nano to repeat songs:
m Choose Settings from the iPod nano main menu.
â To repeat all songs in the list, set Repeat to All.
â To repeat one song over and over, set Repeat to One.
To turn repat off, go to Repeat off.
May 21, 2008 | Apple iPod nano 2nd Generation MP3 Player
Music will not play, just cycles through songs without playing
I just had the same problem with my 2GB silver nano. I had to restore the factory settings through iTunes and reload all of my music. There was also an update for the nano that I downloaded yesterday (Jan. 29, 2006) and installed when I restored the factory settings. My nano appears to be running fine for the moment,but we'll see if this actually took care of the problem.
Jan 29, 2007 | Apple iPod nano
SanDisk SDMX1 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
