Air conditioner guts!
Hi there, I simply need a wiring diagram for my model air condiotner. GE ASW0
Thanks so much
  • 8 Answers
SOURCE: whirlpool air conditioner simply does not turn on
Check out this article. You may find the solution. Good luck!
http://h-mac.com/blog/2008/06/05/how-to-maintain-a-window-air-conditioner/
Posted on Jun 17, 2008
  • 230 Answers
SOURCE: Frigidaire air conditioner - no cool air coming out.
if you used it alot, i would check it for freon.
checkthe air filter, make sure it's not dirty.
check the front panel, make sure there's no "ice/frost" in the unit.
Posted on Jun 30, 2008
SOURCE: wiring diagram for portable air conditioner
I think the wiring diagram is on a printed sticker on the side of the water collector, just pull it out of the right side as you look at it. There should be one on there hope this helps as i have the same unit in the other room. regards Richard
Posted on May 29, 2009
atocrxr
  • 135 Answers
SOURCE: air conditioner wiring diagrams
What brand of A/C is it? Are you looking for the thermostat wiring? Different Brands use different wiring, but the usual is as follows:
R terminal at furnace is 24 volt Hot
W is the control for the heating cycle
G is used to start the furnace blower
Y is used to start the outdoor A/C
B or X depending on Brand is the 24 volt common
Yellow and B or blue is the other wire that goes to the outdoor unit
If you want more info, I need Brand, and type of unit, gas furnace and A/C, electric furnace and A/C, or is it a heat pump for the outdoor unit?
Hope this helps./
Sincerely,
Paul Gibson
Posted on Apr 01, 2010
shastalaker7
  • 1515 Answers
SOURCE: I need Hitachi RUA-30AT3S wiring diagram. This is
FSM Forums • View topic - Hitachi Air Conditioner ManualsHitachi Air Conditioner Manuals - looking for Operations & Maintenance Manuals, ... RUA 30AT3S (Package 30 Tons) RUA10AT3S (Package 10 tons) ...
www.manual-directory.com/forum/viewtopic.php?f=10&t=2453...0 Hi, although your unit is a 2 1/2 ton, you will be able to get a manual showing you the correct wiring diagram using the model number you supplied. It shows your model above. This is the only way to get a diagram for this unit. Please keep me posted on the out come or if you need more help.
Sincerely,
Shastalaker7
Posted on Apr 03, 2010
I need a wiring diagram for a ge window air conditioner
Need model number to try and find you one. Older ge air conditioners had the diagram glued to the inside of the outer case. Newer ones had a sheet of paper folded up and stuck near the control panel sometimes in a plastic envelope.
Jun 09, 2015 | GE Refrigerators
Need wiring diagram to include: Underfloor heating downstairs (wet system,polyplumb) combi boiler for the heating and hot water
could you provide the exact model number or the product you need the wiring diagram for
Thanks
Proton
Oct 30, 2008 | Honeywell Heating & Cooling
Wiring diagram
Have a look on the inside covers, often a wiring diagram sticker is placed on it.
Sep 21, 2013 | General Electric APE08AK Portable Air...
Is it posible to konnect a remote thermostat model TR400HC-A to the air conditioner model AZ28E15DABm1 GE? The Zoneline Air Conditioner is working "On" "Of" and again when the outside...
You can connect That thermostat provided your unit must have option of 2 stage cool and 2 stage heat. If not you have to jumper with Y1 and Y2 and also W1 and W2. Follow the manual and wiring diagram. If any more details plz write here again. Thanks.
Feb 16, 2011 | GE Heating & Cooling
I need Hitachi RUA-30AT3S wiring diagram. This is a self contained air conditioner. Rats damaged all wires while it was in store. I have no clue about re-wiring.
Sincerely,
Shastalaker7
Apr 03, 2010 | Heating & Cooling
Wiring diagram
http://www.partadvantage.com/store/spider/ge/7
Please Click on the Link above and just, click on your model#
Your info is there.
Hope i helped
Please Rate me
Thank You
George
Apr 27, 2009 | GE AJCQ08ACB Air Conditioner
Need wire diagram for GE electric furnace
Usually the older GE's are straight forward and any generic wire diagram will help you out. If its newer and a Trane made unit try A Trane dealer.
Mar 27, 2009 | GE Heating & Cooling
I have an older ge zoneline and one of the locknuts came off a selector switch. when it was turned it turned to far and twisted off five wires. i can put them back on but im not sure what terminals they...
I obtained the following statment from the GE web site:
How to Obtain a Wiring Diagram or Schematic...diagram. If you are in need of a replacement wiring diagram, simply call the GE Answer Center with your complete model number. The diagram may be faxed, e-mailed or mailed. You can reach us by dialing 1-800-626-2005. We are available...
http://genet.geappliances.com
Dec 19, 2008 | Heating & Cooling
Wiring diagram
i need a air conditioner wiring diagram
Apr 25, 2008 | Intertherm P3RC-030K Air Conditioner
Heating & Cooling Logo
19 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
