Question about Whirlpool GD2SHGX Refrigerator
Whirlpool gold GS6NBEXRL01
THat is my model number its a side by side refig freezer with on door ice dispenser. problem is my ice maker worked fine except the icetray needed to be defrosted and so i unplugged it ad and defrosted it i didnt touch anything but when i plugged it back in its not working. is there a reset button in the controls that checks everything. i know parts shouldnt be replaced since it worked without issue and nothig was broken forced or turned. just defrosted...
  • dlforsberg Nov 12, 2008
    Ice maker just stopped working, it makes a clicking noise and the ice extractor fingers willl not move. The water dispensor works fine, and the freezer is cold. The ice makere will not dispense the water into the ice maker to make the ice cubes.
  • 943 Answers
Hi .thanks for the question . the defrost cycle is probably on. either that or a faulty thermostat. thanks the appliance doc rate me please
Posted on Oct 01, 2008
I have a whirlpool ref/freezer the ice dispenser won't work. makes ice and water dispenser is ok. sv
Your model appears to be quite simple electrically. It does not have a major circuit board it's very possible that the pressure switch, wire connection at the dispenser, hinge or the interlock freezer lightswitch is bad on your model. Do you have a multi-meter/OHM meter? John T. Appliance 911 Appliance 911 Sea Breeze
Here is a manual that is very close to your model
May 09, 2014 | Whirlpool EL02CCXP 19" Cold Pals Compact...
Whirlpool side by side with ice maker dispenser not working
Hello, we are sorry to hear that you are experiencing this problem. We would suggest checking the ice chute to make sure that there is no ice lodged in the way of the flap. If the issue persist we would suggest having a certified technician out to look at the Refrigerator. If you would like further assistance you can send your name, phone number, address, model/serial of the appliance and the date on which you purchased the Refrigerator to Thank you.
Apr 17, 2017 | Whirlpool Refrigerators
Whirlpool indoor ice maker not making ice
Could not locate your model number. However, Check fill tube for icemaker inside the freezer. Iced solid? replace water valve. No ice in fill tube? Get correct model number and resubmit your request.
Sep 11, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool GS6NBE side by side ice maker works fine but the ice dispenser doesn't. I can hear a sound and a click when I push it and the dispenser flap works but no ice will come out. Water works fine.
The four prong (flat) plug to the ice maker (in the freezer compartment) in my Whirlpool Gold SbyS Refrigerator; should I be able to test for 120 Volts with a tester, should this plug be 'HOT"?
Sep 04, 2009 | Whirlpool Freezers
Ice Maker Works, Water Dispenser Doesn't
I have a whirlpool side by side. water and ice in front. ice working and water not. the hose is not frozen and it is not humming when you push the water dispenser. It would give us water and quit but now we have nothing.
Jun 25, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
If your model is the Whirlpool Gold I can possibly help you.
Whirlpool Gold GD5NVAXSY need model number to got to service manual. Sorry, but manual people don't realize how many versions of refrigerators. Thanks, Sea Breeze
Jun 02, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool Model GS6NBEXRL01 ice maker not making ice
Most likely the water control valve on back of the refrigerator near floor or the thermostat inside the ice maker is defective. You can fill the ice maker with water from tap and see if it cycles one time or you can check the control valve solenoid that feeds water to the ice maker. Click on link below and then paste your model number in model search feature. That takes you to a page with breakdown photos of the parts I mentioned. On the left of your screen click on photo # 12. If you need help with this I am here, just let me know, Sea Breeze
May 18, 2009 | Whirlpool GS6NBEXRL Side by Side...
Ice maker will not dispense the ice
When you press the lever to dispense the ice, there are multiple switches being activated. Chances are, the one that moves the motor to turn out the ice is bad. Or that motor itself is bad.
Mar 13, 2009 | Whirlpool GS6SHAXLB / GS6SHAXLL /...
I have a Whirlpool(Model: GS6NBEXRL01) Side-by-Side has a sensor on the right side of the freezer and a flap on the left. The light is red and the icemaker is making ice, but will not dispense through the...
The Dispenser Lock (on some models)
Your dispenser can be turned off for easy cleaning or to prevent
unintentional dispensing by small children and pets.
NOTE: The lock feature does not shut off power to the product, to
the ice maker, or to the dispenser light. It simply deactivates the
ice and water dispensers. To turn off the ice maker, see "Ice
Maker & Storage Bin."
• Press and hold LOCKOUT for 3 seconds to lock the
• Press and hold LOCKOUT a second time to unlock the
Let me know if this is your problem, Can get the manual for you if you like, Sea Breeze
Feb 04, 2009 | Refrigerators
Whirlpool gold ice maker problem
  • The refrigerator has a duel water valve, one for the ice-maker and one for the water dispenser (if equipped). The valve that the ice-maker relies on may be bad, or it could be the ice-maker itself.
  • Another thing that could cause it would be the temperatures in the freezer. The ice-maker will not call for water until it reaches under 15 degrees.
  • In addition, check the water tube behind the ice-maker to make sure it is not frozen, blocking more water from entering.
  • note: The water does not go to the ice-maker or thru the filter unless the ice-maker turns on the water valve.
Jul 05, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool GD2SHGX Refrigerator Logo
405 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
