Question about Hitachi 61UWX10B 61" Rear Projection Television
COLOR SHADING This issue showed up overnight. We are having shadowing yellow on everthing. Any one have a fix for this?
  • r8derzfan Oct 26, 2008
    WE CAN'T GET OUR MAGIC FOCUS BACK ON OUR HITACHI HDTV 61UWX10B. THE REPAIR GUY SAYS IT'S OUT PICTURE TUBE HE WROTE BAD BLUE CRT IS THE TV BETTER LEFT ALONE AND TO BUY A NEW ONE OR CAN THIS BE FIXED? WE HAD IT FOR 8 YEARS.THE PROBLEM STARTED OVER NIGHT WITH THE YELLOW AND BLUE TINT AT THE TOP OF THE SCREEN MOVING DOWN TO THE MIDDLE LIKE HALOS ON PEOPLES HEAD SHOWING UP.WELL I HOPE SOMEONE MAY HELP ME OUT. THANKS
    MICHELLE
We had the same overnight issue repair guy came out quoted one price ended up another anyhow the problem he said is it's a bad blue crt can we change this our self or do we need someone to do it and he quoted over 2000 saying the crt is the picture tube hmm it's a hitachi 61uwx10b. Thanks
Posted on Oct 26, 2008
    Novelist:
    Champion:
  • 203 Answers
Sounds like a bad convergence circuit, unless you know how to use a meter and solder well you will need to call a reapir man. This repair should run you anywhere from $300-$500 depending on your area and the tech that comes out. If you were to do it yourself it would run less than $100. Please let me know if you need more info or would like to try it yourself.
Tim
Experttv@comcast.net
Posted on Sep 11, 2008
Certain colors show up as green instead of their intended color. Usually, occurs in shadows or reflective surfaces.
Game cartridge save battery needs to be replaced is a hassle but can be done, First split the cart case open find out what sort of battery purchase and replace. Some N64 Cartridges required the battery to be soldered in and out.
Jan 11, 2013 | Nintendo 64 Console
Picture has ghost shadows in the faces of people mainly news anchors. Light colors like whites and oranges also have shadows. What could be causing this?
If it does not really display this when a DVD etc is played via a rear audio/video input it is not the set.
Modern cable or sat signals often are compressed and sets cannot on close up views keep up with the signal--when signal is compressed it causes this kind of issue--no way around it.
Jun 16, 2012 | HP Pavilion MD5020N 50" DLP HDTV
Colors are not printing the acutal color
It all depends on the meaning of 'not properly'.
Try creating a document with four different squares, or words, of these colours: yellow, magenta, cyan and black. If all of them print (albeit not with the correct shades) it is probably an ICM driver error. But my guess is that only one of those four colors will print badly, due to a defective color cartridge.
The OKI 5150 makes all perceivable colours using cyan, magenta, yellow and black toners, so if one of these malfunctions, the resulting colors will lack the required shade of, say, yellow, and will appear to be "wrong". The yellow colour itself, of course, would simply disappear (the "yellow" you use might actually be 95% yellow and 5% cyan; then the "yellow" square will be printed as a very light shade of cyan, while the other colors - say, 95% magenta and 5% yellow - will turn out almost exact).
Try with the color test and replace any failing cartridge; if all four (almost) pure colours do print incorrectly, it's unlikely to be a cartridge problem, and we'll have to dig deeper.
Sep 09, 2009 | OKI C5150n Led Printer
Blue and yellow shades
That problem is due to failure of convergence section in TV, you need to check convergence out section in TV to fix that problem.
Jul 18, 2009 | Sony KP-53V75 53" Rear Projection...
Phillips HDTV Projection TV. Colors don't line up create shadow
yes sounds like a convergence issue. The following link has convergence repair kits which contain the parts and a cd with instructions on how to do the repair.
http://www.tvrepairkits.net/
Jul 10, 2009 | Televison & Video
Can't set color and everthing has a shadow
I sounds like you have a convergence IC issue. These parts are not expensive, the average repair for replacement of these and re-convergence is around $250-350 from most svc co's.
Feb 28, 2009 | Zenith Televison & Video
Mitsubishi WD-52631 shadows and blurs in dark lit movies
If you are getting the same problem with both TV monitors it could then be assumed it's an input problem to the TV monitor. If you are using a digital output from your receiver it could be the cabling. If you are using an analog output from your receiver it is probably coming from the receiver.
Digital video processing does have issues with darker scenes.
Can you try another video source seperate from the receiver like a DVD or better yet an analog VHS, if you still have one. Good luck and let me know.
Sep 17, 2008 | Samsung HL-R6168W 61" HDTV
54" Projection TV
Your green gun in our tv is misagligned/out of focus. Your tv uses red, green and blue guns that layer in different shades and mix to create the different colors. Your green is a little off so the colors aren't mixing right which explains the green haze and the shadows. A tv repair man can fix this problem pretty easily and it isnt expenisve.
Aug 28, 2008 | Akai PT4298HD Rear Projection Television
Hitachi 61UWX10B 61" Rear Projection Television Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
