My Magnavox 810H DVD Recorderd / Hard Disk won't sart. It seems to repeatedly loop through the Startup process and none of the controls will interrupt ut except my tunring off the power supply.
4 Suggested Answers
  • 814 Answers
SOURCE: will not play disk comes up no disk
With the power turned off, open the DVD Player, and then open the top where you load the DVD into the player. Locate the laser lens and notice that the laser is attached to a transport assembly that moves the laser diagonally outward in a slot. 1. Slide this assembly outward to the end of its track. 2. Slide the assembly back inward to the closest inward position. 3. Repeat the process of sliding the assembly outward and then back inward.4. Put in a music CD and let it play all the way through. This helps to calibrate the laser head assembly movement. When the music CD is finished playing. 5. Put in a DVD, and you should have a working unit again This is a factory solution from Mintek that was given to a customer who ask for help with the forever loading disc problems. This solution may work on other models of portable DVD players. Most portable DVD players use this type of transport mechanism. Try this solution it might work for you. I hope this information helps you with your problem.
Posted on May 29, 2009
  • 4 Answers
SOURCE: Philips DVDR3570H/05 constantly looping on startup
I had this problem, it was solved by reformatting the hard-drive.
NOTE: if you do this, all settings and all that is saved on the harddrive is lost. But seeing that you can't start it anyway, that is acceptable, right? :)
Anyway, here's how you do it, according to Philips support:
  1. Pull out the power cord from the socket.
  2. Press and hold PREV and STOP (i.e. left and down) on the front panel.
  3. Plug the power cord into the socket again.
  4. Wait until the front panel says "FMT KEY" to let go of the buttons. Wait for it to finish formatting, upon which you will get "-- --" on the panel.
Restart the box and you should now end up at a screen asking you to set the language for the box, as if being started for the first time ever.
Also of note: if you want to restore the firmware to factory settings, Philips support told me to pull the cord, press and hold the STANDBY button, and plug it back in again. For the looping problem though, I didn't need that.
Posted on Dec 06, 2009
tvtek
  • 1284 Answers
SOURCE: Do I need a remote control to control the Philips
Usually most DVD's play movie trailers and sometimes advertisement before the movie will play. Once the ads or trailers are done it should go to the menu screen and at that point "play" or something like that should be underlined. If it is you can press play or select on the DVD player then the movie should start : )
Posted on Jul 27, 2011
No valid code to use my Sony Remote with my Magnavox DVD/VCR combo
have you tried ? 60000 60035 60039 60081 60593 61593 (VCR)
if the codes for the DVD didn't work ...
Jan 05, 2014 | Magnavox Televison & Video
My Toshiba Satellite L300-D won;t get poast Startup Repair page. Keeps defaulting to Startup Repair and then says "Windows cannot automatically repair your computer". It all started with a folder...
Your Hard drive is faulty which means it wont go any further and loops back trying to fix a problem it cant do. you can either replace the hard drive and install everything from scratch or send it in to a computer repair shop to do it for you. Kronoguy
Aug 02, 2011 | Toshiba Satellite Pro L300 Notebook
Acer aspire one AOA110 tries to start up but keeps looping back to the startup screen. Goes throught a lenghty disk check and goes back to startup screen.
Possible hard drive errors I would say.
Try and start it from your restore disk or your System disk and back up your data them replace the hard drive.
Hope that helps.
Nov 29, 2010 | Acer Aspire ONE AOA110-Aw Netbook
I need a owner's manual and a remote control. I purchased a Pioneer DVR-810H on Craigslist and it doesn't have a remote or owner's manual.
portablemedia.manualsonline.com/manuals/.../pioneer/pioneer_dvr_dvr810hs.html
or
http://www.pioneerelectronics.com/PUSA/Support/HomeEntertainment/Blu-rayDisc+DVD/PioneerDVDPlayers+Recorders/ci.DVR-810H-S.Support
COPY AND PASTE EITHER ONE OF THE ABOVE LINKS IN YOUR ADDRESS BAR TO BRING YOU TO YOUR USER MANUAL DOWNLOAD.
COPY AND PASTE BELOW LINK IN YOUR ADDRESS BAR TO PURCHASE REMOTE.
Pioneer.PartStore.com
Remotes.com
ebay.com
pioneer.newremotecontrol.com/PioneerDVD.php
Oct 01, 2009 | Pioneer DVR-810H DVD Recorder
Audio Problem on a Pionneer DVR-810H Recorder
Thinking the problem might be the cable box..I bypassed the Tivo and hooked the cable box direct...there was audio on ch. 3 ....reconnected the Tivo and the audio was fine...strange?
Thank you.
Ken Havel
Greenville,WI
Oct 10, 2008 | Pioneer DVR-810H DVD Recorder
I bought a Magnavox 810H 160GB HDD/DVD recorder. It's a decent machine which worked perfectly for a few months, but now I can't get it to record to DVD. The HDD recording and playback functions work fine,...
Try switching it over to DVD . Because you may still have it on HDD when you put the disc in it may be that the unit is still thinking you are on HDD and don't recognise it as a disc just the hard drive
Sep 11, 2008 | Televison & Video
Windows Movie Maker to Ulead DVD Movie Factory 6
Ulead Movie Factory Requires you to Create a "Menu" First,or else it will Loop over and over again.
Oct 20, 2007 | Ulead DVD MovieFactory for PC
Televison & Video Logo
96 people viewed this question
Top Televison & Video Experts
