Sharp CD-C3800 Shelf System
Problem for Sharp CD-C3800 Shelf System
Sharp CD-C3800 won't turn on
By Bobbi on Apr 09, 2006
A few years back, my stereo quit working. It won't power on at all. I'd like to try to fix it but not sure what the problem is. I haven't done anything with it at all, just trying to find the best place to start.
Same Problem
Nov 29, 2007
-   my jvc doesnt turn on was working with full display tape and cd was working to model ca-mx50bk help was plugged into a power board-   buzbee
Nov 13, 2007
-   I just need a schmetic.-   Tom Jones
Best Solution
posted on Apr 10, 2006
Helpful)
BowerR64
Rank: Wiz
Rating: 80%, 980 votes
Sometimes you can smell a burnt electronic device and see if somthing is burn up inside. Its common that fuses can blow sometimes they are a bit under rated and can blow for no reason. Check the fuse first and try and replace it with the same one first. They usualy are near the power cord and you need a coin to open them. They are not a common fuse you need to get them from radio shack or an audio parts store.
Was this helpful?
Yes
No
Solution #2
posted on Apr 09, 2006
Not Rated)
techman
Rank: Guru  Sharp Expert
Rating: 86%, 7655 votes
Well now the first thing your gonna need is a vom. If you dont have one or dont know what that is then stop right here and take to a repair shop.. If you know how to use a vom the first thing you wanna do is measure the primary of the power xformer and check all the a/c fuses. Next make sure there are no mechanical switch to switch the ppower off from the power supply next try to measure the voltages comming fron the power supply and Im not sure whats supose to be where but a schematic should assist ya with the voltages. Good Luck
Was this helpful?
Yes
No
Popular Solutions for Sharp CD-C3800 Shelf System
Questions and Unsolved Problems for Sharp CD-C3800 Shelf System
Do you recommend Sharp CD-C3800 Shelf System?
Answer
Answer
how do you program cds on the rca cd mini system rs2693
Answer
In CD player mode, display states "TOC READ" . Cannot get past this and play CD, any...
Answer
3 cd player rotates but does not stop;spindles on cassette player do not turn;
Answer
when i turn it on and i have the speakers plugged in there is no sounds no mater what i do not a... (More)
Answer
my stereo is plugged in theres speakers hooked up and no matter what it just wont make a sound....
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Audio Shelf... Experts
Top Audio & Video Equipment Repairmen
in , CA
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
(785) 842-6626
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
