Question about Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
Brother MFC 9840CDW
I'm trying to get my Brother MFC set up to scan directly into my e-mail and open a new e-mail with the scanned document attached. It is set up to do this to another computer in the company and I want it do also scan to my e-mail
  • Anonymous Jan 23, 2009
    Did you find a solution? I can't even get my machine to scan or to send to an email address.
  • Anonymous Apr 16, 2009
    How to setup the printer to scan to mail? it just fails when jo type in the email address og press scan.....
I'm trying to get my Brother MFC set up to scan to e-mail and open a new email with the scanned document attached. I am independant and not connected to any other service as I am a one man user operator.
Posted on Jan 30, 2009
How to use the scan ( Brother mfc 420cn ). Thanks!
With printer turned ON, and connected either through a USB cabe or ethernet, open the Control Center CC3. Click the SCAN button on the CC3 widow to select SCAN to Image, Scan to OCR, scan to E-mail, or scan to file. If you have not configured these options yourself, you will find the scanned documents in the user's My Pictures/ CC3/SCAN folder.So with CC3 open, the document on the glass falt bed or in the ADF, select the type of scan and press the corresponding button. A small progress window opens, etc..
Sep 02, 2011 | Brother MFC 420CN All-In-One InkJet...
How do i email a document when i have scanned it?
Make sure you know where the scanned document was saved to on your computer. Normally by default it is in My Documents -> My Pictures -> My scans. Then open your e-mail account, choose a new message and click on Attach. From there it'll prompt you to "browse" to the location of the document, once you point it in the right place, you basically hit OK and it'll upload it to the e-mail as an attachment. From there you can write your message and send it off.
Mar 03, 2011 | Brother Multi-Function Center MFC-3360c...
I am trying to figure out how to use my Brother MFC-8440 scanner. I would like to use it to scan documents to email out. When I go to Brother.com and look at the direction book, it doesn't have directions...
It is part of the Network User's Guide (section 10) and the Software User's Guide (section 3 for a PC using Windows, Section 8 for network scanning), not the User's Guide. The directions below are for XP and Win2K primarily. Slight changes may exist with other OS versions. (Full software is not available for Win7 so the buttons on the unit will not work. You will need to launch scans from the computer only. You can use Windows Paint or Fax and Scan without needing third party software. Then attach the file to an email either in the email software or by right clicking on the file and choosing Send to Mail Recipient.)
For either use, put the document face down on the glass or face up in the ADF.
If you use a directly connected computer, you need to set the destination for the Scan to E-mail in the Control Center (section 4-4 in the Software User's Guide). Open this program and make sure the correct machine is in the drop-down menu. This program needs to be running to hear the buttons being pressed. Click on E-mail to set which program will get the scanned document as an attachment for your e-mail. You can also set the resolution and type of attachment. If you do not want to use available file formats, you will need to scan in PaperPort (or other software) and then use that to attach the file to the e-mail. Then click Scan to launch the scan from the unit. Hit Set when ready to send.
If you have the unit set up on the network, then you can enter the LAN setup in the Front Panel (or a browser). Hit Menu 6 (and then the appropriate number for the next feature), such as TCP/IP, DHCP or Static IP (these are under 1), SMTP, POP3, Mail Address (Menu 6 2). Setup the Scan to email with Menu 6 7 1 for color and Menu 6 7 2 for black and white.
This automatically sends the item to the email server or PDF as either a PDF or JPEG. Then you need register the PC that will get the file to the unit, if you use scan to email (PC). (Your version of Windows will matter for exactly where the information is: Control Panel > Scanners and Cameras or Control Panel > Printers and Other Hardware > Scanners and Cameras.) Right click on the icon for the unit and select Properties to see the Network Properties box. Go through all of this set up including the Scan To Button. Then the Control Center will launch the e-mail program when it "hears" you press Scan, select Scan to Email, press Set, then choose PC and press Set again. (or select the destination PC which has e-mail access and press Set again). Scanning will start.
If you have set the POP3 and SMTP servers and the unit can directly access them, then you can scan to e-mail and enter the recipient address. Press Scan, select Scan to Email, press Set, choose Email Server and Press Set again. Adjust the scan quality as desired pressing Set at each step. Once you go through all of the layers, the LCD screen will prompt you for the recipient's email address. Then press Start.
I hope this helps.
Jul 20, 2010 | Brother MFC-8440 All-In-One Laser Printer
I inherited a Brother MFC-440CN printer with no instructions. How can I scan a document from the printer to my email?
just scan it using the command from the computer ..after that you will find the job into the manager folder..of the scanner..from there you can send it directly ..or edit a little ..and copy into computer and attach to the email..or ..use the feature from the scanner's program to send it ..
make sure you set to scan picture cause scanners have a wizard that you can set to scan image (picture Jpeg ....) or PDF ..document ..
May 18, 2010 | Brother MultiFunction Center MFC-440CN...
How do i scan to my email? I have a brother product MFC-290c all in one with fax and i am trying ro scan to a picture to my email
May 14, 2010 | Brother MFC-290C Printer
How to scan a hard copy, and send in an email?
Install the Control Center CC3, if it is not already installed. Connect the MFC-5460CN to the computer. Open the CC3 software. Click the Scan button. You will have the choice to Scan to Picture, Scan to OCR, Scan to E-mail, or Scan to file.
You click to E-mail. The MFC scans the document and opens the default E-mail program (Outlook, Outlook Express), attaches the scanned picture and all that is left for you to do is to supply the E-mail address where the document is to be sent.
If you have problems doing that, scan to file then open the E-mail client to create a new message and attach the file you scanned.
Hope it helps.
Sep 28, 2009 | Brother MFC-5460CN InkJet Printer
I can't scan
When scanning documents on my MFC 7420, this is what I do. Place document on th scanner bed and don't press any buttons, leave it whatever mode it is in. Go to the computer and click on start> program files> scansoft paperport> open paperport se. When paperport is open click on the scan icon in the upper left corner. A dialog box on the left hand side will ask what you want to scan a picture or document. Select accordingly and press the scan icon.
A new window will pop up and ask what you want to scan and the size. You can either select pre scan or scan. The computer then will send a scan request to the scanner. When it is done scanning close the second window that popped up and the document that you just scanned will be there with a red box around it. Click on the document and it will open, then you can edit and save as needed.
Happy scanning
Hatter1
Jan 29, 2009 | Brother MFC 7420 All-In-One Laser Printer
Scanning with the MCF-8460N
i just download sp3 in my computer and trying t scan and e-mail it does not work now
Dec 13, 2007 | Brother MFC-8460N All-In-One Printer
Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer Logo
573 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
