Question about JVC GR-D250 Mini DV Digital Camcorder
Safe guard mode
I dont know what happened i turned the video camera to record and this screen pops up and says that the camera is in safe guard mode and i removed the battery and nothing happened ...please help me
    Problem Solver:
  • 11 Answers
Turn off the camera and put it in a cool, dry place for about 30 minutes, then turn it on again.
Posted on Sep 10, 2008
JVC Camcorder Error code E 01
Your camera can not load mechanism completely(E01). Could have problem with mechanism or the mode motor itself fails. By the way, serial number is not necessary. Good Luck
Mar 20, 2010 | JVC Cybercam GR-DX95 Mini DV Digital...
When i switch on my JVC GRDVX9 it says on the screen E04 unit in safe guard mode remove and reattach battery
Following are the solutions:<br /> 1. Through your camera in dustbin;<br /> 2. crush it with hammer <br /> 3. Put it on fire
Nov 09, 2009 | JVC GR-DVX9 Mini DV Digital Camcorder
I get out of my system after getting 2010 on my r52
Do you have a reliable and updated virus guard? This might be virus.
Try booting in safe mode and install Avast! (or any other virus guard). Make sure you start computer in safe mode each time it restart. (Press F8 before windows logo appears and select 'Safe Mode' and press Enter)  Update the virus guard, run it (and shcedule a boot-scan if you installed Avast!).
Let us know what happens.
Apr 30, 2009 | Computers & Internet
Lost Instructions for Little Tikes My Real Digital Video Camera
I also recieved a prompt reply, with attachment - here's paste of the text only:
INTRODUCTION
CONTENTS
Item no.: 608728
Ages 3+
ADULT BATTERY INSTALLATION REQUIRED
Get ready to make your own movies with the Little Tikes™ My Real Digital Video Camera! This
durable and fun camera is easy to use and really records video and takes pictures, even up to a
depth of three feet under water!
Illustrations may vary from actual contents.
IMPORTANT: An adult must remove and discard the plastic label from the LCD Display before use.
• Little Tikes™ My Real Digital Video Camera
a. Microphone
b. LED Light
c. Lens
d. Power Button/Mode Selector
e. Mode Display
f. Edit Button/Edit Mode
g. Trash Button/Delete Mode
h. Volume Selector
i. Zoom Button
j. Record/Confirm Button
k. Speaker
l. Left Button
m. Right Button
n. LCD Display
o. USB Port
p. TV Out Port
q. SD Card Slot
r. TV Out Cable
s. USB Cable
t. Adjustable Neck Strap
u. Carrying Case
WARNING
Constant, competent adult supervision
is required at ALL TIMES when small
children are near or in water.
m
g
t k
a b
c
j
d f i
hl
e
p q o
(inside the cover)
n
s
r
u
BEFORE YOU BEGIN
Battery Installation
An adult must install batteries. Here’s how:
1. Using a Phillips screwdriver (not included) remove the screws and Watertight Cover from the
bottom of the camera.
2. Remove the screw and Battery Compartment Cover .
3. Install two (2) AA alkaline batteries (not included) making sure the (+) and (-) ends face the
proper direction as indicated inside the battery compartment.
4. Replace the Battery Compartment Cover and tighten the screw.
5. Replace the Watertight Cover and tighten the screws firmly to ensure a good seal.
Optional SD Card
Your Camera will hold approximately 10 minutes of video or 250-1000 still photos. Since portions
of the free memory space indicated in the Menu Mode are used to store the photo program, the
available space for storing photos etc., may be reduced. These numbers may also vary depending
upon the camera mode settings and the images being captured. To enlarge the memory, an
SD card (not included) may be purchased from your local camera store. To install the card an
adult must:
1. Make certain the camera is turned OFF.
2. Using a Phillips screwdriver (not included) remove the screws and Watertight Cover from the
bottom of the Camera.
3. Slide the SD card (not included) into the slot until it clicks. (DO NOT force the SD card. If you
feel resistance, remove the card, make sure it is facing the correct direction, and try installing
again).
NOTE: SD card label must face toward the Camera Viewfinder and the edge of the card with the
copper contacts must be inserted first.
4. Replace the Watertight Cover and tighten the screws firmly to ensure a good seal to keep
water from entering the card slot.
IMPORTANT NOTES:
• If the Watertight Cover is not completely sealed, water may enter the compartment causing
irreparable damage to the camera.
• USE CAMERA IN FRESH WATER ONLY. DO NOT USE IN SALT WATER.
• Using the Camera at a depth of more than 3 feet is not recommended.
TIP: Keep an eye on your battery level by checking the Battery Gauge in the top-right corner of
your screen. If the Gauge is red, new alkaline batteries need to be installed.
1.5V AA/LR06
1.5V AA/LR06
unscrew
TV Out Port
USB Port
SD Card Slot
unscrew
unscrew
1.5V AA/LR06
1.5V AA/LR06
Battery
Compartment
Cover
Watertight
Cover
IMPORTANT: To save your photos and videos directly to an SD card, you must go to the Storage
Section of the Menu Mode (see Page 5) and change the setting from internal memory to external
memory.
NOTE: Never insert anything other than an SD card into the card slot as doing so may damage the
camera and the SD card. To remove the card, press in on it and it will pop out.
IMPORTANT: Should water or any foreign object get into the Battery Compartment or the Card
Slot, turn the camera off immediately, remove the card and/or batteries, and allow the camera to
dry out completely before attempting to use again.
QUICK START
ATTACHING THE NECK STRAP
An adult must attach the Neck Strap. Here’s how:
• Place the clip on the end of the Neck Strap into the
opening in the connector which is attached to the camera
and press firmly until it clicks into place. (Fig. A)
• Repeat the instructions above to attach the remaining
end of the strap. (To detach the Neck Strap squeeze the
clip edges and pull apart.)
• Adjust the length of the Strap by using the plastic buckle
located along the strap.
NOTE: To attach or detach camera portion of connector,
see Fig. B.
CAUTION - DETACH NECK STRAP FROM CAMERA
BEFORE ENTERING WATER.
CAMERA MODES
VIDEO MODE
In this mode the Viewfinder will show what the camera sees in real time.
• Set up your shot in the Viewfinder then press and release Record to take a video.
NOTE: A red “RC” icon will appear in the top-left corner of the screen, and the elapsed time will
appear in the lower right corner.
• To stop recording and store what you have recorded, press the Record button again. The screen
will switch to the beginning of the film you just recorded with a big red Play arrow in the middle.
• Press the Record Button and the video will play back.
• Press the Left Button (or wait 5 seconds) and the camera will go back to the live image.
TIP: You can zoom the camera in and out by pressing the Zoom buttons! The Zoom Indicator on
the right side of the screen will tell you how far you are zoomed in or out!
NOTE: There is no zoom function in 640 X 480 video mode.
Video Mode
Still Picture Mode
Playback Mode
Fig. A Fig. B
ADDING SOUND TO YOUR VIDEO
• Before recording, press the Edit Button. You will see Sound and Image icons. (Fig. 5)
• Use the Left or Right Buttons to select Sound then press Record to confirm.
• Press the Left or Right Button again to hear the available sounds. (Fig.6) Stop at the one you
like, then press Record to add it to your video. The camera will then return to the live image.
Press Record to record your video with the sound included. Press Record again to stop
recording. (Press edit to exit edit mode.)
NOTE: Turn the Volume up high so the microphone can hear and record the sound!
ADDING IMAGES TO YOUR VIDEO
• Use the Left or Right Buttons to select your choice then press Record to confirm.
• Press the Left or Right Buttons to see the available images. (Fig.7) Stop at the one you like,
then press Record to add it to your video. The camera will then return to the live image with
your selected graphic. Press record to record your video with the image! Press Record again to
stop recording. (Press edit to exit edit mode.)
IMPORTANT - images on videos will only appear when viewed on camera viewfinder or on
TV screen.
Fig. 5 Fig. 7
L R
Fig. 6
L R
Construction
TURNING THE CAMERA ON
Once an adult has installed the batteries:
• Press and hold the Power button for 2 seconds. The Little Tikes™ logo will appear on the screen.
• Once the logo disappears the camera will automatically be set to Video Mode.
NOTE: To change modes, press and release the Power button. To turn the camera off, hold down
IMPORTANT: Before making videos or taking pictures, see Page 4 (MENU MODE) to set picture
quality. Also, camera must be at least 2 feet away from subject for best focus.
1 2 3
Jan 03, 2009 | Little Tikes My Real All-Ter Digital Video...
Jvc gr-d250ek saftey mode remove battery
battery is dead or dying and not charging up or it just needs to have the battery pulled for a while
Oct 11, 2008 | RCA CC9370 Mini DV Digital Camcorder
JVC gr-d350u camcorder
TRi to check the take up wheel and idler gear or capstan motor is engaged with idler gear.
Jul 15, 2008 | JVC GR-D350 Mini DV Digital Camcorder
E04 unit in safeguard mode
I tried every method I could find from people posting on the web, but the method that worked for me is this.
1. Eject the tape and close the tape holder.
2. Turn the camera off and remove the battery.
3. Put the battery back in. Leave the camera off.
4. Open the tape holder.
5. Slide the tape in, but as you press the holder in to accept the tape, keep your finger pressing in on the holder, being careful not to slow the tape holder from moving downward.
6. Turn the camera on.
7. If it doesn't work the first time, press more firmly to help the tape holder accept the tape.
That's it. This method seems to work for me and lets me use the camera for a long while. If the camera is sitting unused for more than a few hours, I have to do it again. And each time I insert a tape, I make sure that I keep pressing as the tape holder lowers the tape.
Mar 27, 2008 | JVC Cybercam GR-DVL805 Mini DV Digital...
Doesn't record
Camera is in safe guard mode want you to remove and replace battery still in safe guard mode
Dec 21, 2007 | JVC GR-D250 Mini DV Digital Camcorder
JVC GR-AXM17U
In the case the encoder position is not shifted
to the next point though the loading motor has
rotated in the unloading direction for 4 seconds
or more. This error is defined as [E02].
1. The mechanism is locked during mode shift.
2. The mechanism is locked at the mechanism loading
end, because the encoder position is skipped during
mechanism mode shif
Dec 13, 2007 | JVC GR-AXM17U Camcorder
Safe guard mode
Hi my name is Erick . Have you tried ejecting the tape??? Safe mode just means the tape is stuck or something in the mechanicism is not letting the gear works eject the tape. GOOD LUCK!!!!
Oct 23, 2007 | JVC GR-SXM470A S-VHS Analog Camcorder
Open Questions:
Audio drop out and/or static sound Thanks to anyone who has taken a look at my issue with audio cutting out. JVC has always been a brand I have confidence in, and I believe I picked this camera up when those recording to an internal hard drive were out of my range. Last summer, I received a fantastic deal on some JVC Evarios, so GR-D250 duo would be used only as back-up, BUT, I have a ton of old Mini DV tapes -- never recorded over anything. I would find the heads needing cleaning solution highly unlikely. The first 250 recorded the bulk of those 150 or Mini DV's and worked like a champ. Because of legal depositions for lawyers and like, who may not want for me to call time-out in a deposition to switch tapes and the fact that eventually my first was going to give out, having a back-up and eventually multiple seemed like the thing to do. Having a couple of friends film some sports events I could my mix radio play-by-play I could with dual camera angles was cool. This same-year model second buy had sat in storage; The original tape the who sold it to me with 10 minutes of footage came with it. I could tell the battery was so much stronger after a full charge than my old one, but this newer D250 has maybe had 1/10 the recording time as my original. Whether listening to the camera speakers, piping the sound from the rear A/V jack or importing via firewire, it's the same. The video may not be perfect and may "spark" or "flicker" in unison with the audio that drops out,but not always. At times, the video seems just fine but the audio drop-out is akin to a loop and I could probably time it, which was what I termed as cyclical. Could one of my friends have dropped it or tipped over a tripod and not told me? Sure, but I would think they would have told me. One night, follow some high school hoops I was importing, excited at the prospects of some two camera angles mixing. Thought I may have had a bad tape, but ruled that out right away through trying multiple tapes in bother cameras. Apologies for my loquacious follow-up; I suppose if worse comes to worse, I could check eBay for a secondhand model. I've "misplaced" my original, but it will turn up; it's simply a matter of desiring to import all that footage, since 2008, with superior editing software and skill than what I possessed when doing so initially. Thanks so much!
Apr 13, 2014 | JVC GR-D250 Mini DV Digital Camcorder
See all JVC GR-D250 Mini DV Digital Camcorder Questions
JVC GR-D250 Mini DV Digital Camcorder Logo
224 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Steven Wander
Steven Wander
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
