Question about Campbell Hausfeld Air Tools & Compressors
Housefeld 20 gl blowes fuzes after 60 psi
Blowes circuitbrakers
  • feebackmonik Nov 22, 2008
    each time i plug in this compressor it trows the breaker. it does the same at 3 different shops, so it must be a problem with thr compressor itself. it runs maybe 3 or 4 sec before this occurs.
  • 19,396 Answers
You will need to use a multimeter, and to test voltages coming to circuit breaker, if it keeps blowing, then there is a short or an overvoltage.
Posted on Sep 10, 2008
Why does the fuel pressure tester gauge needle flutter?
yes.. that's normal pressure regulation for the system..
Aug 10, 2017 | Saturn Cars & Trucks
Gould j5s, pump not going above 15 - 20 psi, does this sound like it could be a priming issue or not since it is pumping some water?
how much pressure do you want with a 15 to 20 psi, really what are you pumping house water, you need more pressure to supply a home like a 60 psi with an exterol tank
Nov 18, 2013 | Jet Flo 04325143A Marine Heavy Duty Water...
40 hp mercury
Hi Greg,
You Have A Short!
If You Put A New Fuze Does It Blow When You Turn The Key On, Or
As You Try To Start Or When You Operate The Trim Switch.
Try To Acertain What You Do When It Actually Blows The Fuze
Let Me Know
Cheers
Gordon
May 04, 2013 | Light Outboard Motor Boat Bass Fishing...
Low side pressure specs for 2003 silverado2500hd
Ambient Air Temperature
Relative Humidity
Service Port Pressure
Maximum Left Center Discharge Air Temperature
Low Side
High Side
13-16°C (55-65°F)
0-100%
150-246 kPa (22-36 psi)
730-1190 kPa (106-173 psi)
12°C (54°F)
19-24°C (66-75°F)
Below 40%
150-280 kPa (22-41 psi)
900-1390 kPa (131-202 psi)
14°C (57°F)
Above 40%
179-137 kPa (26-46 psi)
990-1500 kPa (144-218 psi)
16°C (61°F)
25-29°C (76-85°F)
Below 35%
218-328 kPa (32-48 psi)
1240-1640 kPa (180-238 psi)
17°C (63°F)
35-60%
236-342 kPa (34-50 psi)
1290-1680 kPa (187-244 psi)
18°C (64°F)
Above 60%
250-365 kPa (36-53 psi)
1340-1760 kPa (194-255 psi)
20°C (68°F)
30-35°C (86-95°F)
Below 30%
266-386 kPa (39-56 psi)
1500-1940 kPa (218-282 psi)
21°C (70°F)
30-50%
280-397 kPa (41-58 psi)
1540-1990 kPa (224-289 psi)
22°C (72°F)
Above 50%
300-430 kPa (44-62 psi)
1600-2070 kPa (232-300 psi)
24°C (75°F)
36-41°C (96-105°F)
Below 20%
328-439 kPa (48-64 psi)
1810-2240 kPa (263-325 psi)
25°C (77°F)
20-40%
337-457 kPa (49-66 psi)
1840-2290 kPa (267-332 psi)
26°C (79°F)
Above 40%
355-474 kPa (52-69 psi)
1890-2340 kPa (274-340 psi)
27°C (81°F)
42-46°C (106-115°F)
Below 20%
391-491 kPa (57-71 psi)
2130-2500 kPa (309-363 psi)
29°C (84°F)
Above 20%
397-508 kPa (58-74 psi)
2160-2550 kPa (313-370 psi)
30°C (86°F)
47-49°C (116-120°F)
Below 30%
451-552 kPa (65-80 psi)
2420-2790 kPa (351-405 psi)
33°C (92°F)
Jul 10, 2011 | 2003 Chevrolet Silverado 2500HD
Pressure switch, TC2151, on my shallow well system (used for lawn irrigation) needs recalibrating. It shuts off at 60 PSI - I think I can live with that although I would prefer about 55 PSI. I saw your...
It sounds like you BACKED OFF the small not. This is the cut in pressure. If you turn it to the right the Cut In pressure is raised. To the left is lowering the Cut In.
RJ
Jul 09, 2011 | Flotec TC2151 P2 Well Pump Pressure Switch
95 s10 4.3 blazer new fuel injectors(spider) 2 new fuel pumps new filter was getting 50/60 psi on guage but had to start with starting fluid...now only getting 10/20 psi changed fuel pump...
Problem is usually caused by the regulator in the spider head. It may not be installed correctly, not getting enough vacuum from the intake upper manifold or is failing. Start by checking the vacuum at the manifold.
Oct 09, 2017 | 1995 Chevrolet S-10 CA Edition
What is the correct oil pressure for a chevy 2000 3500 vortex engine
Wild guess of 40 to 60 psi at highest, and more like 10 at idle.
May 22, 2010 | 2000 Chevrolet 3500
Fuze #14 blown. this powers back uplamp,daytime running lamps relay coil, a/c pressure switch,cruise control, heated pvc,trailer tow back up lamps, abs, reverse park aid and ec mirror. the fuze blows any...
please give me the year of the f-150 and any added option you have so i can check the schematic's to see if i can pin point something that could cause this issue.
very strange one though. but must have something to do with it going 60... you said you isolated a few thing does that mean you have tested them and ruled them out?
Nov 22, 2009 | Ford F-150 Cars & Trucks
What is the correct fuel pressure on a 96 Dodge grand Caravan?
Don't have access to actual pressure required at this moment but I will tell you that 12-20 psi is definitely not enough. Your probably looking at a minimum of 50-60, and as much as 90-100 depending on what engine. A replacement for a 3.3.L at autozone is rated at 90-100 psi. I'd spend the money on new pump & filter at same time.
Mar 23, 2009 | 1996 Dodge Grand Caravan
Air Tools & Compressors Logo
101 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
