Cable connector broke off rear of tv - Televison & Video
  • Anonymous Mar 23, 2009
    Do they sauder it?I paid $80.00 last year to get one fixed
  • rage of war May 19, 2009
    I have a 25" tv that the cable connector on the back was broke off I took back off the tv and it was a metal box that had to be replaced to. were it connected to the cable connector. Just need to know how much it would cost to replace it.
  • 4,234 Answers
This is a common problem and as long as the internal PC board inside the tuner is not broken, the connector can be replaced. The connector should not cost more than about $5. ANy local service shop should be able to replace it for you.
Dan
Posted on Sep 10, 2008
I have a RCA 52"
This happens all the time. It just might be fixable. This connector is known as the "f" connector or female coaxal connector. Most average electronics technician can fix them. This connector is attached to a component called the tuner. The tuner is what takes the signal and selects the channel the tv recieves. To replace the connector it means removeing the cuircit board that the tuner is on and then removeing the tunner, disasembling the tuner. Now until you find a good tech, there is another option... take an vcr and use the rca inputs on set. essitally tunning the set through the vcr. Now you will have to change channels through the vcr. but it will work. also there is a chance that the tuner might be damaged. just depends on the damage that occured when the connector was broke off..,let me know if you need any more help
Jun 03, 2011 | RCA HD52W56 52" Rear Projection HDTV
I have this tv and the antenna wire got stepped on and broke, is there a solution wth going in and replacing the connector. I was thinking and adaptor fron antenna cable to rca connector? is thiis...
well yes and know...let me explain.at theshop this is a very common occurence that we see alot... this connector is atached to a thing called a tuner. the tunner is what the tv use to select the channel. withhout this you cant change channels what can be done is atach a vcr and then use the rca inputs.. you will have to change channels using vcr.some cable boxs do this also again chaning through the cable box. this can be repaired depending how much damage has been done our shop ussaly charged around 85 dollars to repair the connector.
Dec 30, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Yea i have a 52 in rear projection hdtv and i went to move it and the cable piece itself broke off and now the tv power light blinks three times and jus shuts off how can i fix that
the cable connector being broke more than likely has damaged the tuner. sometimes the tuner can be rebuilt depending on the damage. since the set is shutting down there may be more damage. if the set stayed on you might be able to bypass it using vcr. the worst case the small signal board might need replaced that cost aroun 300
Oct 19, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
The cable hook up on the TV broke off.
Yes...You may have to buy a new RF connector and replace. This will take some very good patience or purchase a new complete tuner. If you are not in a hurry for the tech shop. Use the rca jacks on the tv to a cable or satellite box. Just be sure when you power off you tv, that the tv is really off. A blank raster will look as if it is shut down for the time being! Good Luck!
Nov 29, 2009 | Panasonic PT-50LC14 50" Rear Projection...
The metal part on back of Sharp Aquos TV where cable connects broke off. What do I do?
If you have a cable or sattellite box I would use the HDMI, Component, or audio/video cables instead. If you don't, you will have to have a new RF connector put on.
Jul 09, 2009 | Philips Magnavox 51MP392H Rear Projection...
Cable connector broke off in back of tv
had same problem virtually impossible fix if broke off if you have rca plugs use vcr thats what i did!
Jun 30, 2009 | Televison & Video
The female cable connector on the back of the tv broke off
yes,you could also use RCA cords from the cable box to the tv and bypass that by selecting the video channel that you hook the rca's to
Jun 02, 2009 | RCA TruFlat 27F520T 27" TV
Cable connection in rear of TV broke off.
This problem will have to be taken or shipped in to a service center for repair or replacement of the cable connector on the main board. The telephone number for Insignia customer support is 1-877-467-4289. and the website is www.insignia-products.com. You can also call the Best Buy customer support telephone number. 1-888-237-8289. Give them you make and model number of television and the problem you had with the broken cable connection.They will be able to tell you how you can get service for your television. I hope this information helps you with your problem.
May 02, 2009 | Insignia IS-LCDTV32 32 in. Television
Tuner is broke off D56W20
Cost of that board is 352.00 if they are even available First CK 2 fuses thereis one on each of turner small brown rectrangle looking caps/but they arre fuses/ if they are open set will not startup.Also replace IF connector.to turner.
Dec 27, 2008 | RCA D56W20 56" Rear Projection Television
Main cable connector broke off back of TV
Maybe so. Sometimes the connector is fed by an RCA connector which just plugs in inside the TV and sometimes it needs a little solder work. Sometimes you have to solder on the circuit board and if it's a multi-layer board you want an expert to do it but from the manual it doesn't look like that is the case with your TV.
I'm pretty sure Radio Shack stocks such connectors with maybe a little hardware to get the fit right.
Dec 17, 2008 | Televison & Video
Televison & Video Logo
244 people viewed this question
Top Televison & Video Experts
