SOURCE: vista compatibility with canon i960 printer
Here is a link to the updated drivers for Vista. You will see in the first section where you can select your operating system (OS). Click the down arrow and select Vista. Now in the box called "Drivers" click on the red .exe file. It will display a new page. Scroll down to the bottom and click on the "I agree" Button. This will start the download process. Click Run, wait for it to download and click run again. This will start the install process. This should fix your problems.
SOURCE: canon pixma i6000d error code 5200
Hope this help. Please
Rate My Response! Thanks!
CF
SOURCE: service error 5200 for my printer Canon S200SPxhow
1. hold RESUME then press & hold POWER
2. release RESUME, then press it twice, the light should go amber then green again.
3. you're now in service mode (you can release POWER now)
for reset waste tank reset is 4 presses of the RESUME button. To confirm, press POWER once
Hope this helps. Please rate my response.
Thanks.
Have a good day.
SOURCE: canon mx330 printer error 5200
Try this: Press the resume button (or cancel).
If not, unplug the unit and plug it back in.
Or, try this: Open the lid so the printer moves the head to the center position and unplug the power cord. Remove the ink and head. Plug the machine back in and let it go through it's startup routine. When it's done, open the lid and reinstall the head/ink cartridges.
If this does not work, you may have a bad printhead. Printheads for Canons cost anywhere from $50 to over $100 depending on where you get them and what model the printer is.
WARNING If, during your testing, the machine suddenly dies completely (no power at all) do not purchase a new print head. Some Canon models have a bad type of failure where the printhead goes bad and shorts, which draws too much current from the main board causing the main board to blow. If you replace the printhead in a machine with a bad main board caused by this failure you will just blow the new printhead. Remember this only applies if your machine suddenly dies completely (no power at all).
Good luck.
