Mitsubishi VS-70707 70 in. Rear Projection Television
Problem for Mitsubishi VS-70707 70 in. Rear Projection Television
Mitsubishi model vs-70707
By rdale00 on Apr 08, 2006
screen is demolished damaged while moving where do i purchase one ? i would like to buy a used one i am in columbus ohio or a new one. thanks roger
Same Problem
Oct 30, 2008
-   i have damaged all 3 screens on my mit-ws 55809 where can i find more-   skone27st
Best Solution
posted on Apr 09, 2006
Helpful)
techman
Rank: Guru
Rating: 86%, 7652 votes
You can contact mitsubishi At 1-800-332-2119 and they will direct you in the right direction. Good Luck
Was this helpful?
Yes
No
Solution #2
posted on Apr 10, 2006
Somewhat Helpful)
BowerR64
Rank: Wiz
Rating: 80%, 980 votes
Have you tried e-bay? tobad you could use a white sheet or somthing. Ive read those tvs can go out of focus when you try and transport them. The lenses and stuff get hot them work loose then when you move them they are all out of whack. Would be the pits to spend some big bucks on a new screen then find out its not even in focus anymore.
Was this helpful?
Yes
No
Solution #3
posted on Mar 08, 2008
Not Rated)
dmichie
Rank: Wiz
Rating: 83%, 58 votes
For all Projection Televisions:
I replaced the screen on my 62 inch projection TV for about $50 and the the picture quality is good! Have a sheet of plexiglass cut to the EXACT size needed. BEFORE installation it MUST be frosted on both sides by either a fine particle sandblaster or by sanding it VERTICALLY on BOTH sides with a power sander and a fine grade paper.
If this is only an OUTER protective screen and the image is projected on the inner screen then DO NOT frost the replacement screen, just install it.
Was this helpful?
Yes
No
Popular Solutions for Mitsubishi VS-70707 70 in.
Questions and Unsolved Problems for Mitsubishi VS-70707 70 in.
Do you recommend Mitsubishi VS-70707 70 in. Rear Projection Television?
Answer
Answer
I have a Mitsubishi VS7004R with no picture but I do have sound. No warning signs, just turned it on... (More)
Answer
when i trun it on the screen moves up and down for ten minutes till it warms up then works fine
Answer
I purchased from a couple the Mitsubishi Projection TV 70" Model: VS- 70707 Serial (if this... (More)
Answer
I need a control circuit board for a mitsubishi 70707 tv. Anyone know where I can get 1?
Answer
I am thinking of purchasing a MAYFLASH - TV AV Video System Converter PAL to NTSC.The product says... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Projection... Experts
Top TV Repairmen
in , OH
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
