Question about Toshiba 43H70 43" Rear Projection Television
Toshiba 43H70 convergence
It seems in the "S" mode i get to the grid and the color red will not move in every direction. the blue and the green move just great, but i have to align them with the red which does not always line up in a straight line as far as the grid is concerned. also how do i know i have lined the grid correctly? it seems like i can make the corners of the grid go beyond the picture of the screen. another thing, i was the guy messing with all the numbers in the top left hand corner of the screen in "S" mode and i didnt write the numbers the t.v. was calibrated at. does anyone have a list of what theres is set at? i am very desperate to fix my t.v. call me if you need futher information or suggestions on what i should do.(520)256-4568
    President:
  • 3,130 Answers
You will have to contact toshiba at 1-800-457-7777 and get a service manual to adjust the on board menu and adjustment.. I do not or ever ever recomend that an unexperienced person mess with the sets alighnments unless they have the service manual and understand all of the teminology as I've seen several sets that cost the customer 4 times what it would have if they didnt mess with the service menu and knock all the alighnments as this is not the time to adjust someting just to see what happens.
Posted on Apr 09, 2006
My Toshiba 43H70 started having the blue bow up at the bottom. Green and red are good. Convergence will move it a little, but not enough. Any ideas?
Your convergence has failed and needs to be repaired. Once quick test is to goto your convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed. You can call in a repair shop or you can get the parts and instructions from www.TvRepairKits.com and do the repair yourself. Its a fairly easy DIY fix.
Jul 18, 2011 | Toshiba 43H70 43" Rear Projection...
I HAVE A TOSHIBA 43H70 I BOUGHT IN 2001 AND THE RED AND BLUE ARE OFF ON THE RIGHT SIDE. I HAVE TRIED TO USE THE CONVERGENCE BOARD TO STRAIGHTEN BUT MY RED WILLNOT MOVE TOWARD THE BLUE OR GREEN. ON NUMBER...
This tv the convergence board are dead.Any colors R,G,B mis alignment,don't matches any colors lines.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts are dead,must be replaced to solved convergence problems.The Shop will cost u $300-350 for parts and labors.
Jul 08, 2010 | Toshiba 43H70 43" Rear Projection...
Picture seems sunk in and the color distorted with doubleing effe
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Jun 01, 2010 | RCA HD52W58 52" TV
There is a wave/bow in the bottom and top of the picture on the screen of my Toshiba 70HX50. When I am in the grid screen in the service mode it looks like the center is 'bowed' out. How do I adjust this...
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 15, 2010 | Toshiba 43H70 43" Rear Projection...
My tv seems out of focus and has green shadows as well....do you have any idea what could be wrong?
  • Screen looks 3D
May 15, 2010 | Sony KP-53V80 53" Rear Projection...
Picture on screen doubles and there's red highlights at the bottom of the screen. Tried to fix with convergence but did not work. Model # TZ50V61. Please help me.
  • Screen looks 3D
Toshiba 41h81 green convergence problem
Below are two of the most common problems encountered with projection TV sets.
Problem #1 - CONVERGENCE PROBLEM
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
  • Screen looks 3D
  • TV shuts off after powering on - TV may also make a chirping noise.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
Apr 07, 2009 | Toshiba 42H81 42" Rear Projection...
RED Convergence Alignment issue
Replace both STK392-110 Convergence IC's with Toshiba or Sanyo quality................No cheap IC's !!!......................T.
Aug 16, 2008 | Toshiba 43H71 43" Rear Projection...
CONVERGENCE PROBLEM IN TOSHIBA 43H70
Replace both STK392-110 convergence IC's with Toshiba or Sanyo brand........no cheap junk IC's !!!.................T.
43H70 Blue Convergence out of line and will not line back up
If the blue colors will not line up, and the blue appears to sag inward from one or more sides, then you can bet that one of your convergence IC's has either cracked loose or burned out. The IC should be resoldered or replaced and the convergence realigned by someone experienced with projection TV convergence circuits.
May 21, 2007 | Toshiba 43H70 43" Rear Projection...
Toshiba 43H70 43" Rear Projection Television Logo
121 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
