Rear left break light is out. blinkers and lights work fine. its only when i break my rear back light does not turn on.
checked fuses and replaced blubs.
still no good
help?????
yes I have the same problem left side brake light does not come on every thing else works on that side change bulbs that seem work until I got home check the brakes again and they were not working again please help thanks in advance.yes I have the same problem left side brake light does not come on every thing else works on that side change bulbs that seem work until I got home check the brakes again and they were not working again please help thanks in advance.
AnonymousMar 12, 2014
blown fuses has short, water in back drivers side rear break lightsblown fuses has short, water in back drivers side rear break lights
You can't post conmments that contain an email address.
Check the BULB socket to see if it has 12 volts when the brake is applied, test the ground at the socket as well, use a 12 volt test lite from Kragen or a store like it.
check the light bulbs (filiments can break and touch the other filament in the bulb and backfeed other circuits) if they appear ok remove the non working bulbs and swap positions with the working bulbs and see if anything changes
When a turn signal bulb is blinking fast, it is an indicator that a bulb is bad in the system. Replace the left rear turn signal bulb, then see if the left front blinker has gone back to normal. This is most likely your problem. Let me know if it is still a problem and i will help you fix it. Good luck
Everything works, more or less, so you know that the switches and fuses are good. That means that you've got either bulb problems or power/ground problems. First, try swapping the bulbs around to see if the "bad" lights will work with the known "good" bulbs in them. If so, you just need to replace some bulbs. If not, check the sockets inside and out for corrosion, clean them (wire brush, steel wool, sandpaper, etc.) if necessary, and use a voltmeter or automotive tester to make sure that you have power and ground to each socket. The fast flash on the turn signal is just an indicator that a bulb is out.
It's the bulb. There are two filliments in the bulb. One is for when you turn your lights on and the other is for breaking and blinker flashing. When the break filliment goes bad it causes the blinker to flash very rapidly. 100% the bulb. Change it and all will be good again. P.S. if it were a fuse none of the break lights or blinkers would work.
Usually a fast turn signal means that there is a light out. You should probably check all of your lights, including back-up lights, and turn signals. If there is one out then replacing the burnt out bulb should fix the problem.
