Question about Car Audio & Video
I have a 2000 Honda Civic DX value package that had the battery cable replaced. As a result of loosing power, the radio/CD player requires a activation code for use again. Where do I get this information?
    President:
  • 1,450 Answers
You will need the serial number off of radio and have to call honda. if you bought new the dealer may have on file
Posted on Sep 10, 2008
I have a 2000 Honda Civic sedan. The radio quit first, then the wipers, then the lights, then everything. This happened before and it was loose battery cables. The cables are fine. Someone mentioned...
I would have the alternator checked. I would also have the battery checked because if the alternator is bad it could have caused the battery to go bad too. Most auto parts stores will do the testing for free, but you can check it yourself if you buy a voltmeter. I can help you with the testing if you need help.
Sep 21, 2011 | 2000 Honda Civic
I have a 2003 Honda Civic EX coupe. Installed aftermarket radio cd player and the cd works but the radio does not. The issue is not with the new unit as the previous player's radio would not work either....
If you're getting power to the CD player then there's power
to the radio. The antenna involves the grid on the rear window,
an antenna coil and cable to the radio. You can check the
grid for a break and if it's small you're auto parts store will
have a repair kit. My 05 Accord rear window defogger did
not work and it took Honda 2 attempts to repair it. Other
than checking the grid I would bring it to the dealer.
Feb 03, 2011 | 2003 Honda Civic
Honda 1992 Civic DX 1.5L water pump diagram on How to take off. Do you have any FREE please
In order to replace the water pump you would have to do the timing belt. Don't know if you are aware of how involved and the kill level it requires.
Nov 05, 2009 | 1992 Honda Civic
Replace a starter
1999 Honda Civic DX 1.6L MFI SOHC 4cyl
Starter Removal & Installation
Fig. Starter wire connections
Fig. A ratchet and long extension may be needed to remove the starter
The factory sound system has a coded theft protection system. It is recommended that you know your reset code before you begin.
  1. Disconnect the negative battery cable.
  2. Remove all wiring from harness.
  3. Remove the lower radiator hose from the bracket on the starter motor.
  4. Remove the starter cable from terminal B located on the back of the solenoid.
  5. Remove the black/white wire from the S (solenoid) terminal.
  6. Remove the two bolts that mount the starter to the transaxle assembly.
  7. Remove the starter.
To install:
  1. Install in the reverse order of removal.
When installing the heavy gauge starter cable, make sure the crimped side of the terminal end is facing out.
  1. Enter the anti-theft code and radio presets.
I hope help you with this (rated this help). Good luck.
Sep 09, 2009 | 1998 Honda Civic
My 2000 Honda civic cd player says error what should i do to fix it so that it works...
If the radio does not want to work at all neither on CD or radio tuner mode, then the radio ran out of power for a while or was improperly disconnected. Those models had a theft protection that renders them useless after disconnection from power, unless you have the code to reactivate it. Unfortunately, the only to get the code if to go to your honda dealer and pay for them to plug their machines and get the code and reactivate the radio. If you don't wanna hassle with that every time you unplug the battery, just take the radio out and replace it with an aftermarket unit like a Kenwood, or Sony, or Alpine or any of the like. None of those will ever give out errors like that and require a costly code to get working again.
Jul 08, 2009 | Sony Car Audio & Video
Car wont start same click new alternator and battery
take to a local rebuilder most likely starter common honda problem
Jun 21, 2009 | 1994 Honda Civic
New Radio too powerful for 15 Watt speakers?
Hello mike_mccuske,
The OEM speakers will still work OK with your new Pioneer. Just don't turn it up too loud. Of course you'll get improved sound if you replace the speakers. Your Pioneer's RMS power is 14 watts, and the peak (maximum) power is 50 watts. The door speakers in a 2000 Honda Civic are 6.5" and you can get a set of Pioneer speakers, the TS-G1642R's, from Crutchfield for less than $50. Their RMS power range is 2-30 watts and they can handle a peak power of up to 180 watts.
Hope this helps.
May 22, 2009 | Pioneer DEH-2000MP MP3 CD AM/FM Car Stereo...
Honda civic 2000
check in drivers door jam , glove box there should be a little sticker somewhere there with a 5 didgit code that will be youre code or in with youre owners stuff,once you try putting the wrong code in three times it will show error then you will need to disfconnect the - battery cable to try again, if you fcant find the code you will need to take to dealer and ask them for it they should have it if not you will need the serial number off the radio and they can get it with that
Sep 25, 2008 | 2000 Honda Civic
Car Stereo will not turn on
Most headunits (cd players) have fuses of their own. If those are are not blown, connect a simple test light to ground and with the ignition on, test your constant (yellow wire) and accessory (red wire) for power. If all fuses are good and you still have no power you can connect your red and yellow wires (whichever shows no power on the test light) directly to your vehicles fuse panel.
Jan 08, 2008 | Sony CDX-F7710 Car Audio Stereo CD MP3...
Car Audio & Video Logo
129 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
