Question about Samsung Maxima 22S QD Point and Shoot Camera
Flash won't stop flashing by itself
When the lens is uncovered, the flash will just keep cycling and flashing by itself. What's the best solution?
    Champion:
  • 277 Answers
Hi your light sensor is gone bad there is nothing to do but replace it go to any photography store and fix it good luck
Posted on Apr 09, 2006
Battery is fully charged, lights flash, securty lights won't stop flashing but bike won't turn on?
Hi Maritza, for more information about your question please visit the website below. Good luck and have nice day.
Set Change Override Transport Harley Security Alarm PIN Code No Key Fob...
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jul 11, 2012 | 2009 Harley Davidson FXDC Dyna Super Glide...
My GE quiet power 1 dishwasher has flashing lights and won't stop cycling, what do i do?
I have had this problem with this dishwasher in my rented apartment occasionally since I moved in. It would usually reset itself if I let it sit a while, but not today. Today all it would do is flash and beep and I finally just unplugged it. I stumbled across this page and read the post by Dyons above and it worked. Close the door, let it grind away and within 2 minutes it will reset itself. Thanks, Dyons!!!
Sep 28, 2011 | GE Dishwashers
Can we use a Cobra Auto 150S Compact auto/manual flash and slave unit on a Nikon 5000 SLR
As a slave, yes, though you won't get any of the features of a Nikon CLS-compatible flash unit. You would be shooting in manual flash mode. Due to its higher trigger voltage, I would NOT put the unit onto the camera itself.
May 23, 2011 | Nikon D5000 Digital Camera with 18-105mm...
A red lightning arrow keeps flashing on the screen and the camera isn't doin anything,what can the problem be?
Hi.
A red flashing lightening bolt can mean different things on different camera's. The most common are that you are too far away from the object you want to take a picture of. That the flash on the camera needs to be turned off and that the flash itself is charging up and won't allow a picture to be taken.
Try turning the flash off and see if it will let you take a picture.
Regards.
May 01, 2011 | Cameras
Canon Macro Settings for 100mm lens and Sunpak 12R ring flash
Firstly, be sure to check flash voltage. Your 30D may accept max 6V so that your camera can be shot if the flash unit has higher voltage than 6V.
1. Use low ISO to keep low noise....around f/8 or more depends on your need and how much DOF you want.....Set the shutter speed around 1/125 to your max speed to stop any movement (your subject or camera itself shaking).
2. Above is set in Manual mode (iso100, f/8 1/125 or 1/250), then you just need to leave the flash to work in TTL mode.
3. It needs battery, the connection is for syncing to trigger and release a proper flash power (in TTL mode).
Hope this help!
Mar 26, 2009 | Sunpak DX-8R TTL Ring Light Flash
Sony cybershot dsc 707 'Pop up' flash does'nt flash when it pops up. Have purchased camera 2nd hand, and was aware of the issue before purchase.
SIMPLE Fix. I have mended about 5 of these with the same fault. It is a very common fault. Basically due to the way the flash has been designed the flash pops up far too violently, this causes a lot of stress within the lens. This in time causes the Flash cable to come loose from the socket. Simple repair, just insert the cable back into the socket. Also causes the screws at the front of the lens to come loose too. To repair, simply, remove the extenal flash bracket and screws, and remove the screws to the Left of the lens (As you are looking into the lens) This will remove the LEFT pannel on the lens. Towards the back (Camera side) of the lens there is a socket arpprox 10 Pin and a ribbon cable, It may look like the cable is in the socket but normally it is just sitting on the edge. Push this cable back in. FLASH should work again, Best to tape this down to stop it happening again. GOOD LUCK.
Aug 21, 2008 | Cameras
The flash keeps flashing
hi sneakers
the camera is firing the flash to help it auto focus,the only way to stop it find an area of the picture that has more light/contrast or switch to manual focusing.
regards
ian
Dec 27, 2007 | Canon EOS 400D / Rebel XTi Digital Camera...
Red eye problem
The best way is to keep the flash as far away from the lens as possible. If you have the option of using an external flash, that would be a great solution. You can also use ?Bounce Mode? to change the light dispersion around the lens. Another possible solution would be to bypass the use of flash by giving more exposure time or opening the shutter. In a case where the lighting is marginal, these actions can replace the use of flash.
Feb 22, 2006 | Canon PowerShot A510 Digital Camera
Samsung Maxima 22S QD Point and Shoot Camera Logo
73 people viewed this question
Top Samsung Photography Experts
Marvin
Marvin
Lawrence Oravetz
Are you a Samsung Photography Expert? Answer questions, earn points and help others
