1998 TOSHIBA TP50H60 THE COLOR WON'T MATCH, LOOKS LIKE 3-D MOVIE WITHOUT THE GLASSES. IF YOU HIT THE SIDE OF TV, SOMETIMES GOES BACK TO NORMAL.
  • mmgarza Apr 20, 2009
    i want to know how to fix this convergence problem. were can i buy it and were is it on my toshiba tp50h60
    Novelist:
    Champion:
  • 203 Answers
Sounds like a classic convergence problem. most likely bad connections on the bottom of the stk's. If a repairman were to do this for you it would run $300-$500, if you were to do it yourself it would run less than $100. Bad connection on the vertical IC can cause something simular to this as well. If you need more help or would like to fix it on your own please let me know
Tim
Posted on Sep 11, 2008
I am having the same problem can you tell me were the convergence board is and were i can buy the part to replace
Posted on Apr 20, 2009
Toshiba cf32h40 started last week the pic would go down to one thin line i would hit it on the side and it would come back ,but now thin line comes back when i hit and then goes away so i took off the back...
that silver box is called TV tuner (see picture ) ............ but in your case that is not the problem ......... after 4 or 5 yrs (depending on usuage ) in some TVs on mainboard & CRT tube's circuit board at some soldering joints cracks develops ... then due to loose contact TV behaves as you have described ........ when you are hitting that lightly on its side then these cracks at soldering joints are getting connected temporarly & for few seconds or minutes you are getting normal picture ....... so solution is most of the soldering joints on mainboard & on CRT circuit board has to be resoldered ....... only good tv service engineer can do this without shorting joints or damaging components..... so that silver box ( TV tuner ) is not the problem because when it gets deffective then you will get picture that comes when tv is switched on ---- usually it will be blue screen ......& also if you connect dvd you will get picture normally ...only thing is that you won't get picture from cable or antenna .............. vishnuswamy_25.jpg
Sep 01, 2011 | Toshiba CF32H40 32" TV
Toshiba 20hlv15 image turns bright colors and will sometimes disappear.
I will check what toshiba says about this problem, but in the meantime, make sure your tv is not overheating, make sure all airvents are open, you said you took it apart so I supose you cleaned all the dust and so on.
Il get back to you.
Mar 30, 2008 | Toshiba 20HLV15 TV
We have a 1998 Toshiba tv. Its a 50" screen with
This is an indication of out-of-regulation in the power supply section. This is cause by leaky/dried electrolytic capacitor in that section. It will dropped the supply from normal voltage and will disable the unit.It needs a little warm-up to make itself stable but the symptom will get worst until the unit will not even power up. Sometimes it has a bulged/dome at the top but not all, it is better that you have acapacitor checker/tester to determine its condition. Your unit will back to normal again if the leaky/dried capacitor is isolated. If you don't have a capacitor checker, replace all electrolytic capacitor in the power supply section, it will not cost you much because this is one of the cheapest part on that board. Watch this video for more info regarding electrolytic capacitor.
If you don't have necessary tools and test instruments, and can't do the job yourself, I would advice you to look for a professional to troubleshoot the problem. Don't attempt to work in the power supply if you don't know the safety precaution of handling it, there some stored electricity enough to hurt you with a little mistake only.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Jdvillanueva
Jul 14, 2011 | Toshiba TP50H60 50" Rear Projection...
Red green and blue colors do not overlap. Looks like a 3d movie without the glasses
Projection TV's sometimes need a "Convergence" adjustment. If you do not have the manual and/or cannot find the option in your TV menu, here is a link to help. Follow up and confirm this was your problem.
http://www.ehow.com/how_2034880_perform-convergence--tv.html
Jun 30, 2010 | Televison & Video
Have colard shadows hit side of tv comes back in focus
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 17, 2010 | Toshiba TP50H60 50" Rear Projection...
My Toshiba 42H83 has developed a color problem. The color blue is about an inch off the other colors, the picture looks like a 3d movie without the glasses. I have used the touch focus button on the...
Alot of rear projection t.v.'s have a convergence option in the menu on the t.v. There you can set the try to set the colors back how their supposed to. Mine has a cross in the middle of the screen and you just have to try to get all 3 colors to line up. Unfortunately, the actual lens inside mine has to be aligned so it doesnt work. Just something to try though, hope it helps.
Jan 05, 2010 | Toshiba 42H83 42" Rear Projection...
Shrinking Picture
problem is bad soldier on the vertical IC , this part needs to be resoldier to solve your problem, its a simple job for any tv repairman.
Jan 10, 2009 | Toshiba 36A40 36" TV
Clear picture is gone looks like watching a 3-d movie without glasses
sorry i am new at this but have had the same problem with a toshiba and it was the IC chips which control the converigence which is lining the colors back up
or it just may be as simple as converiging the colors in your case if you have not trided to yet
Aug 08, 2008 | Hitachi 55FX48B 55" Rear Projection...
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.eserviceinfo.com/
Nov 20, 2006 | Toshiba TP50H60 50" Rear Projection...
Televison & Video Logo
116 people viewed this question
Top Televison & Video Experts
Electro Med Services...
