Car Video Players
Problem for Car Video Players
Generic problem for all Car Video Players
Jensen UV8 wiring issues
By crazybrit318 on Sep 10, 2008
I bought a phase linear UV8 in dash dvd player made by jensen and wired everything up myself. I connected all the neccessary wires to the harness then connected the two harnesses together and the player worked fine except for the dvd aspect which was only because i had done nothing with the parking brake wire.
then when i put the unit in the dash, it stopped working. it simply wouldn't turn on. The light on the power button was still there but nothing happened when i pused it. There also used to be a ding my car made when the driver's door was open, now instead of that, my clock resets itself and so does the unit (light flashes ona nd off ) in tune to what the ding used to be.
I'm really hoping this is just a simple wiring mix up even though i've checked and rewired it twice. Pleas help me.
thanks
alastair
Comments:
Sep 11, 2008
- the four wires you were speaking of:
  • Yellow (with the filter/fuse) - always on B+12
  • Red - ACC +12 (ignition switch)
  • Black - car body ground/negative
  • Pink - Handbrake switch
are all in the proper places except for the pink/handbrake wire. they're connected color for color to the harness i bought and i verified the position was correct on the descroptions the product gave for the wire colors. Now the problem must lie in the stock harness and whether or not those wires are in the correct place for the new harness. The car is a 1986 subaru GL. Concerning the B+12 current you were speaking of, it must still be present in some shape or form because the clock's memory stays intact unless i put the key in while the door is open. Do you have any idea why the unit would function as expected then suddenly makfunction?
Sep 15, 2008
- It was nothing more than i blown fuse. Thanks for the help though. you guys are great :)
Solution #1
posted on Sep 11, 2008
Somewhat Helpful)
Benimur
Rank: Guru
Rating: 88%, 3829 votes
Appreciate the direct "Ask Me".
I am assuming that by your post "...the player worked fine..." refers to the unit operating as expected. To your concern:
  • clock resets;
  • dvd player light flashes on and off;
  • missing ding driver's door open.
All of the above indicates a wiring error or at the very least a loose connection more particularly to the mains B+ (always on). The always on B+12 is directly tied to the + battery terminal and as the name implies, with or without the key in the IGN SW, there is a +12. This always on B+12 is responsible for the clock to maintain its time, the memory of the headunit to retain presets tuner stations and all other settings. It is also responsible for providing the power to the "ding" circuitry and sensor. Pls re-check that the following wires are connected as indicated:
  • Green/White (if present) - reverse switch on the gearbox
  • Brown (if present) - mobile phone in use mute trigger (if used)
  • Blue - to power a motorized/amplified antenna (if needed)
  • Blue/White - to power an external amplifier (if used)
Additionally, if I may inquire, year, make and model of the car it was installed in.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Comments:
Sep 13, 2008
- Hi,
For some reason, I did not receive any notification that you posted back/commented. Our apologies for any inconvenience.
To your concern, pls confirm if the Jensen's below listed wires are connected to the Subarus' similarly listed wires:
Pls note that there are two (2) wiring versions for the Subaru presented (and possibly several more) depending on the country of assembly/manufacture. Additionally, may I pls inquire if you used a harness/connector adapter, something similar to this? Further, with the use of a DVM, pls check the presence of:
  • +12 on Yellow at any condition: IGN SW off or on, door open or closed, Jensen on or off; and
  • switched +12 on the Red (that is when the IGN SW is either at ACC or ON/RUN) at any condition: Idoor open or closed, Jensen on or off.
Hope this be of additional help/idea. Pls post back how things turned up or should you need additional information.
Cheer.
Sep 13, 2008
- If I may add, there are some Subaru GL versions that uses White as the always on B+12 while Black as the IGN B+12. Both may be found in the ignition harness.
Was this helpful?
Yes
No
Popular Solutions for Car Video Players
Questions and Unsolved Problems for Car Video Players
Answer
boss bv9560 - can I hook up my subwoofer to this?
Answer
I have a 2wd, no sunroof SR5 sequoia and would like to install a dvd/video player on it. Are there... (More)
Answer
will the rosen z10 fit an xj jag 54 plate and what colour and price please
Answer
I need advd lens compatible for the processor sphe8202r
Answer
some one can i help me? i have one car stereo clarion vz409 locked,thanks.
Describe your Car Video Players problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Car Video Player Experts
Top Audio & Video Equipment Repairmen
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
(785) 842-6626
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
