Home | Canon | PowerShot SD500 / IXUS 700 Digital Camera | E 18 problem
Canon PowerShot SD500 / IXUS 700 Digital Camera
Problem for Canon PowerShot SD500 / IXUS 700 Digital Camera
E 18 problem
By Freesia on Apr 08, 2006
The lens on my Canon digital camera will not close... i am unable to take a pciture and do not know the reason for this....when the camera is put on i am able to see my old pictures but when i click to take a new picture the screen is blank..i dont know what to do...please help...i have the canon power shot sd 500 camera and the problem that appears is the E18...... please help me
Clarification Request
Posted by sjjoyce on Sep 23, 2008
i have a lens error restart camera message on my canon powershot SX100IS.
have switched batteries. no go. help, please.
Same Problem
May 25, 2009
-   Same problem, Ixus 800 IS. Tried all violent tricks at least 40 times and finally got it to work. Don't know exactly what did it, but try to move the lens in all ways you can think of (not all at once) while turning the camera on. The only thing is that now it sounds like the gears are worn and I managed to push the lens so hard the LCD got a little permanent discolouring on one corner. -   Guest
Apr 22, 2009
-   error -   mof_khazakeh
Apr 11, 2009
-   I also have a POWERSHOT SX100IS, and I wanted to plug it in a wall power so I had rtied a cell power plug that's when it all went wrong the lens opened halfway thn it shut off had that error displayed and thought great now what can I do. I had it for 1 and 1/2 year so the waranty had expired but I called the so support line for canon not much help only you can sen it to them fot the cost of $119 plus shipping I thought well I paid $239 so I looked online finly found this site thanks alot after reading it I tried the lens movement did not work the I tried tapping it on the table did not work so I tried the tapping again only with my hand around the lens part while turning it on... and Walaaaa it worked this saved me alot of money ... thanks to this site and all your comments -   cosi_cosi_se
Apr 11, 2009
-   I am having the same problem. I did everything on this page: http://www.e18error.com/repair.html
but nothing seems to be working,
-   Guest
Apr 11, 2009
-   I have a 3 year old Canon PowerShot SX100 IS. While testing an external battery power supply I built, the external power connector pulled out while the lens barrel was extending just after I turned on the camera. Power to the camera was lost before the lens barrel fully extended and wouldn't reset when I repowered the camera. The dreaded error message "Lens error, reset camera" appeared and the camera shut down. I restarted the camera over and over and over again but the lens wouldn't reset. I was extremely lucky to find the information here and read various fixes. I didn't want to take the camera apart so I tried various fixes others have successfully used. The one which worked was smacking the camera on the side immediately after I pushed the on/off switch. I smacked it quite hard twice then, suddenly, the lens barrel began to move and the lens reset itself back to its starting position. Thanks to everyone who has posted here!-   Golem
Best Solution
posted on Apr 03, 2008
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
tried this with S500....and my camera is now in a million pieces...if you do this be very careful when disassembling the lens because the parts can easily break. Now the lens slider mechanism does not work at all. Its a little bit more complicated with the later models becauses some ribbon cables are saudered and easily break...plus disassembly is a bit different....but should work if you are very cautious...label all screws.. Good luck!!! If can get a hold of lens paper it is better than cotton swabs for cleaning the lenses.
Peace
Solution #2
posted on Sep 30, 2008
Very Helpful)
kragom
Rank: Apprentice
Rating: 100%, 22 votes
I had a very similar problem on an IXUS 60. Lens had stopped retracting and the monitor said Lens error, restart cam. It made a noise every time I tried to start camera, but the lens did not even move.
If this is the case, there may be a problem with the motor or cogs. You can see in the first screens hot in this page where to find the motor, but I am re-posting it here:
Sometimes you get things going by moving this.
In my case, it did, but immediately after it was stuck again. I then looked just below this motor on the side of the camera, there are two cogs there, one black and one white. When I rotated the motor, these cogs were moving, and I could see there were loads of grains of sand stuck in them.
I proceeded to take a needle and carefully dislodge and remove grain after grain. This is a precision job, and it may also work using a vacuum cleaner with a narrow nozzle, but rotating the cogs from the motor, or by zooming once I had it cleaned enough for it to move, and removing all grains I could see with the needle left it working perfectly again!
Was this helpful?
Yes
No
16 people thought this was helpful
Solution #3
posted on Jul 06, 2008
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Had this problem - tried many fixes, then doused the lens and surrounding area with rubbing alcohol on a Qtip and a few minutes later, VIOLA! it worked again. Worth a shot ...
Solution #4
posted on Jul 23, 2007
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Had a lens error, "restart camera" message on an SD600. Read the posts. Took the case off the camera. Rotated the position sensor disk. Flexed everything that could flex. Didn't disassemble further as the camera started working. Seems OK now. Total time 20 minutes.
Solution #5
posted on Jan 06, 2008
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I have a power-shot A70 and got the E18 error. I tried what I read on some web-site. Just gave the camera a sharp rap on the USB side (rubber pad) against a pad on top of a table! Didn;t have to take a thing apart and so far it works fine. Go figure!
Solution #6
posted on Nov 02, 2007
Very Helpful)
Tharamal
Rank: Apprentice
Rating: 96%, 39 votes
Hi... As simple it mind sound, but hitting this on the palm a couple of times solved the problem. The lens began to retract but continue with the E18 error. Now on continual basis, 5-6 times, while retracting I kept on the heavy palm tapping, and the problem got resolved. Pls try this elementary method first. Worked for me.
Was this helpful?
Yes
No
22 people thought this was helpful
Solution #7
posted on Nov 11, 2006
Very Helpful)
gtoews
Rank: Apprentice
Rating: 95%, 183 votes
gtoews indicated that his solution for
IXUS V2 Digital... Problem
is valid for all Canon Digital...
Yesterday my SD300 gave me the E18 error after about 2 years of service. I wasn?t using the case that day and when I turned it on then switched to capture mode, I heard the motor tighten up the gear assembly in an attempt to open the lens. I tried pulling on the lens while powering on without success. The following are photos and comments of my efforts to correct the problem.
If all else fails, you should first try to manually move the lens assembly by rotating the position sensor disc shown at A.
To expose this part of the camera remove the plate on the side of the camera, remove all other exposed screws. Remove the back and front cases. Leave the battery in so you can test if you were successful.
Comments:
Nov 11, 2006
- If the above procedure doesn't solve your problem please look at procedure 2 of the following document.
<a href="http://members.shaw.ca/gregs_space/Canon_E18_repair_guide_for_SD300.pdf
">Canon_E18_repair_guide_for_SD300</a>
Dec 01, 2006
- Link to PDF document describing detailed fix.
http://members.shaw.ca/gregs_space/Canon...
Was this helpful?
Yes
No
13 people thought this was helpful
Solution #8
posted on Jul 31, 2007
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
this worked for my SD600 I just got in November which I was really sad about not working anymore! THANK YOU SO MUCH for taking the time to do this!
Solution #9
posted on Feb 26, 2008
Helpful)
mikeysweet
Rank: Apprentice
Rating: 94%, 15 votes
I have an Canon SD700 IS and got the infamous "Lens error, restart camera". Before this error though, my camera stopped focusing. It would just grind and stay blurred. Then today I turned it on and the lens did not retract and stayed in the open position. After banging, puling and prodding, nothing gave and my lens did not retract. I decided to try banging it while it tried to move the camera. So I pressed the On button and gave the camera a good wack against my palm and the lens began to act normally. It retracted as it should. It also began focusing correctly. Problem solved!!!
Was this helpful?
Yes
No
8 people thought this was helpful
Solution #10
posted on Jan 04, 2007
Helpful)
Picsgirl
Rank: Apprentice
Rating: 94%, 6 votes
I have had this problem a couple of times with my Cannon. If you plug your camera into your TV to view the pictures on TV, turn the camera on and off a couple of times and it should get working back to normal right away. Also, try and gently blow out dust around the lense.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #11
posted on Apr 09, 2007
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Thank you for your help. These instructions were great in helping us sort out the E18 problem with our Powershot A60. We were devastated when it stopped working this morning - especially since it is only just over a year old, and we can ill afford another camera right now. We tried tapping the USB cover on the desk. This did not work. But when we studied the lens, and saw a bigger gap on one side than the other, we then tried to twist it back in to the camera. We were worried about breaking this function, but thought that we had nothing to lose. After three attempts, and using quite a bit of hand power to turn the lens, the lens finally retracted into the case and the E18 message disappeared. Hurrah!
Solution #12
posted on Jun 13, 2007
Helpful)
Tovawe
Rank: Apprentice
Rating: 93%, 15 votes
After I experienced the E18 error and reading all the posts on the web, I examined my IXUS400 thoroughly. When looking to the front of the camera, it looks like the lens is not really centered.
The distance between the body and the lens is not equally everywhere.
I tried to press the side where the distance was the biggest and at the same time pressed the ON/OFF button. The lens came out and it came out completely!
After that I have frequently turned the camera ON and OFF. After that I have never experienced the E18 error again and the camera keeps taken pictures as before. Worthwhile trying!
Was this helpful?
Yes
No
Solution #13
posted on Apr 09, 2006
Helpful)
silly girl
Rank: Wiz
Rating: 81%, 3603 votes
EXTREMELY common, its a problem with the lens mechanism, and one that is very easy to get. cannon will fix this problem if you're within the 1 year warranty. but will not replace or refund for this specific problem as they should.
you can get this by dropping the camera, or by simply not being totaly gentle with the lens when its out. Very very very delicate.
I'll post a guide here on fixing the problem, but you should know what you're doing.
good luck!
E18 - Repair Guide:
With a little fine motorical luck and some patience, following this guide can help you repair your camera. The repair costs with Canon amount to approx. 260, - EUR and aren't worthwhile themselves in most cases. One should, however, check whether the warranty for the camera still is in effect and whether Canon would cover repair costs.
It cannot be guaranteed that the camera will be 100% functional again after the repair.
Necessary Tools:
- screwdriver Philips size 00
- cotton swabs
- alcohol
- NO grease, silicone spray, etc.
The removal of the error E18 is demonstrated with a model of the digital IXUS. The internal structure of other models of the IXUS (like the USA ELPH) series differs slightly, so that the steps made here can serve as basis for all models.
all text refers to the picture above it.
Comments:
Apr 09, 2006
- Here's the camera to be repaired. In the display we can see clearly the reference to the error E18.
Apr 09, 2006
- First, unscrew the housing rear wall, then the front part and afterwards the middle framework with trip etc. (except IXUS 400) can be removed. Preserve screws well!
Apr 09, 2006
- This ring protects the lens of the IXUS against penetrating dirt (missing with IXUS 300/330). Wave well!
Apr 09, 2006
- The motherboard is shielded with a coated foil. Now the two screws are removed and the screen is opened by unfolding the foil off of the motherboard.
Apr 09, 2006
- Now the two remaining screws fastening the motherboard can be removed.
Apr 09, 2006
- Now we must detach this cable. Pull (or push) the "key" for the connector out (as shown with the arrows). Once that's been released, the cable will just slip out of the connector.
Apr 09, 2006
- Next, remove the screw marked by the arrow...
Apr 09, 2006
- ... and the top buttons are gone...
Apr 09, 2006
- To remove the tripod mounting screw, remove these two screws.
Apr 09, 2006
- Next, the remaining plug connectors on the front and back of the plate are disconnected. (pointed out with the arrows which ones have been disconnected)
Apr 09, 2006
- Do not forget the plug on the back (it's missing with IXUS 300/330)!
Apr 09, 2006
- Now the motherboard is carefully removed.
Apr 09, 2006
- Now, turn the camera over, remove the screw below the display and carefully unfold the screen!
Apr 09, 2006
- Now remove the marked screw under the display and srew on the display again (see previous step).
Apr 09, 2006
- Unscrew both bolts on the lower surface and just loose the black one on the top side of the camera.
Apr 09, 2006
- Now remove the foil plate stuck together with the accumulator case carefully.
Apr 09, 2006
- Turn the accumulator case away and remove the CompactFlash slot.
Apr 09, 2006
- Remove the two remaining screws of the lens unit on the back of the camera.
Apr 09, 2006
- Now remove the status leds ...
Apr 09, 2006
- ... and move the lens unit carefully up (pay attention to bottelnecks).
Apr 09, 2006
- Remove the lens unit.
Apr 09, 2006
- For removing the optical viewer loosen and pull the marked screw upward.
Apr 09, 2006
- Press the autofocus light with a screwdriver out of the optical viewer.
Apr 09, 2006
- Remove the slide for the optical viewer. In addition it must become completely strained and pulled upward from the guidance. Unhook the spring.
Apr 09, 2006
- Move the lenses in the optical viewer into front position.
Apr 09, 2006
- Open the lens unit . Don't oben the "gear box" at the moment!
Apr 09, 2006
- Take off the flat cables from the mounting plate.
Apr 09, 2006
- Slightly open the case and simply remove metal cogweehl by removing the axis.
Apr 09, 2006
- Move out the lens a bit by manually pushing the gear rim. Then open it. Take care of the ribbon cable.
Apr 09, 2006
- Retract the lens again completely.
Apr 09, 2006
- From the front of the lens press and the individual building groups will come apart.
Apr 09, 2006
- Clean the guidance track in the lens to be free of sand etc.
Apr 09, 2006
- Outside ring: take apart and clean.
Apr 09, 2006
- Engine and transmissions: examine the whole bit. Make sure the engine contacts are clean and if necessary, the "gear box" to ensure it's clean as well.
Apr 09, 2006
- The gear wheels are clean. Finished!
The assembly of the camera takes place in reverse order. After a successful repair, the IXUS is then again completely operational.
Was this helpful?
Yes
No
25 people thought this was helpful
Solution #14
posted on Oct 06, 2007
Helpful)
KRDH
Rank: Apprentice
Rating: 93%, 25 votes
Thanks to gtoew (solution 1); your solution got me on the right track, and I was able to fix a stuck-closed lens on my wife's Canon SD400, but did not need the full amount of disassembly, although moving the position sensor wheel did not work; it was stuck.
When looking at Fig. 9 of solution 1 from gtoew, you can actually access the nylon cogs from the side without having to remove the cog assembly cover; i.e., imagine an arrow pointing up from the bottom of Fig. 9 towards the camera, and look the same way. You will see the edges of several cogs; in my case, moving the white nylon one solved the problem.
So my advice is to disassemble only as much as is necessary to be able to access the cogs this way.
Was this helpful?
Yes
No
Solution #15
posted on Aug 27, 2007
Helpful)
paulj
Rank: Apprentice
Rating: 93%, 3 votes
re greg toews solution...
I followed it and it worked. Greg, thanks very much for the pdf with enough detail to feel confident enough to attack the problem. It was very helpful to have all the pictures and text.
1. As greg suggests, you probably don't have to remove the LCD. The key is to remove the flash to get at the gears. You probably only have to loosen the board on the front side and work the flash out. However, a first timer would not know how much force to use to remove the flash.
2. to fuel the fire...for me the problem was gunked up gears. The "white worm gear" attached to the motor was filled with salt-size plastic junk. Most likely from wear and tear. It looked like bits of the worm gear. I used a tootbrush to clean it up and then the gear and lens assembly moved freely. (Greg gave me this clue in his procedure 1.)
Was this helpful?
Yes
No
Solution #16
posted on Mar 11, 2008
Helpful)
shrini_b
Rank: Apprentice
Rating: 93%, 7 votes
ref: http://www.e18error.com/repair.html
This one really worked like charm -
Another method is to tap the padded USB cover part on a hard surface, for example, a desk. It sounds so simple, but very often in works.
Was this helpful?
Yes
No
Solution #17
posted on Jul 11, 2008
Helpful)
vrodray
Rank: Apprentice
Rating: 92%, 29 votes
Just had the "Lens Error, Restart Camera" on my SD700 - lense would not come out, and the shutters in front of lense were partway open. This happened after camera was in full knapsack in a softcase (probably tried to turn on and could not extend lense due to tight packing - then jammed gears). I ended up powering on the camera while thumping it facedown on a pad of paper and the lense hanging over the edge so it could extend without hitting anything. After two cycles of this, TADA!! It works perfectly, focuses perfectly in all modes and macro, lens extends all the time, etc! I have abused this camera (dropping on road while taking pictures on my Harley, dropping on floor, etc). Still keeps ticking!!
Was this helpful?
Yes
No
4 people thought this was helpful
Solution #18
posted on Jun 17, 2007
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I had a problem "lens error, restart camera"
I used the first solution of rotating the assemsbly manually and it worked. I used it on Powershot SD-600. Saved myself a lot of money. It took 15 minutes to repair it.
Great site and thanks for the help.
Solution #19
posted on Apr 30, 2007
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Used Silly girl's photos to help do it on my SD630. worked great, camera works great. Wasnt the exact same camera, but close enough. the only thing I had a pain with was putting the lens back together and getting the shutter back in place, was a bit of pain i should have paid better attention to how the parts all lined up at the start. Oh and I have an extra screw, lol no idea where its from but i'll just assume it wasnt really needed.
Solution #20
posted on Jan 20, 2007
Helpful)
dr_dr
Rank: Apprentice
Rating: 89%, 6 votes
Beware of High Voltage source by the charged capacitor!! And Static damage to chips!
Was this helpful?
Yes
No
Solution #21
posted on May 23, 2008
Helpful)
cannonsucks
Rank: Apprentice
Rating: 88%, 6 votes
Just hold tight and buy another camera to get you buy for time being.. the law suit is in the works and Cannon will be reimbursing customers soon if they cannot repair. They will give the option to do this once or refund 75% of the camera's original value. Whoo!!!
Was this helpful?
Yes
No
Solution #22
posted on Mar 30, 2008
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
My Powershot S400 was working fine until the other day when the lens would not retract, the camera beeps when powered ON, and the screen is blank w/ E18 showing as the error code. The camera is several years old and has never been abused, dirty, or dropped. I did some research on the Ineternet and found that it looks like a common issue w/ Canons. My research also indicated that it doesnt look like something that can be easily fixed. I figured that the camera was toast, so I decided to do an autopsy to find the root cause of the E18 lens malfunction. First of all, I do not recommend opening up the camera body if you have any hope to repair it. It is highly complicated w/ many small screws. It is not made to be tinkered with by the average consumer. I carefully removed screws and pulled parts away from each other as to not cause more physically damage. The lens assembly is in the center of the camera, and everything must be completely disassembled to get to it. I knew that there was no way for me to reassemble this thing and make it work again. Anyway, I took apart the lens assembly and found that the gear set that moves the lens in and out is made from a brass drive gear moving the plastic gear on the lens body. The plastic gear on the lens body had about a 1/4" section that had broken gear teeth. So this looks like what caused the lens to malfunction, stop moving, and give the E18 error. It may be due to a fatigue or wear out of the plastic gear teeth. Everything else looked ok. I have several pictures showing the defect. It was rather fun to dissect the camera. I am amazed on how compactly it is put together.
PS...If broken gear teeth on the lens is the root of the E18 errors on other Canon models, MY OPINION is that this IS NOT a repairable problem. It would not be economical to pay a technician to disassemble and fix the lens assembly. This is basically a disposable camera (at least for the S400 model).
Solution #23
posted on Nov 15, 2007
Helpful)
timeblade
Rank: Apprentice
Rating: 83%, 12 votes
I have a Canon A610 my 8yr old son was taking a picture and after set the front lens area of the camera on his skin and then turned it off, a bit of skin was pinched in the lens ring and then locked up the camera followed by the infamous E18 error. I figured it was a goner and set it aside for a few weeks, then googled the error and found this site. I have tried 1 method to attempt to fix the camera. A few hard fast smacks on the camera solved the problem!! I have a padded foam mouse pad not the Gel wrist rest kind just a plain rubber padded one, I firmly thumped the camera on the left side of the camera, not the side with the USB/ memory card port. With Fresh batteries I pushed the on button and bam the lens opened! I put in a memory card and took a few pictures all is well, no problems.
Was this helpful?
Yes
No
Solution #24
posted on Mar 08, 2008
Somewhat Helpful)
Arnoud
Rank: Guide
Rating: 91%, 10 votes
Manually rotating sensor rotor and cleaning gear fixed the Canon "lens error" for me.
I placed instructions with photo's here: http://www.avh.dds.nl/Fix-Canon-SD600-Lens-Error/
Was this helpful?
Yes
No
Solution #25
posted on Feb 18, 2007
Somewhat Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Might want to make sure your camera is the same as in the pics, my camera is now ruined after trying this.
Solution #26
posted on Mar 13, 2008
Somewhat Helpful)
sks939
Rank: Apprentice
Rating: 70%, 2 votes
My S400 lens was stuck about 10% of the way out. I noticed a gap on one side that was slightly more than the other side. I tried pushing the lens in on the side with the bigger gap and also banging on my palm, but those ideas did not work. Finally, I got the idea to use my fingernail to pull the lens towards the bigger gap side immediately after pressing the power button. My leverage allowed the lens to extend successfully. However, it then retracted and I still have the E18 error. Rrrrrggggh!
Was this helpful?
Yes
No
Solution #27
posted on Feb 19, 2007
Somewhat Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
It's a Canon. Throw it in the garbage and buy a real camera from a real company.
Jeez. Just google E-18.
Solution #28
posted on Nov 07, 2007
Not Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
If you are fustrated at your camera and have tryed all suggestions to repair and nothing has worked ,a very simple solution that never fails is to place camera on a large ,then take 10 steps back ,aim your 12 gauge shotgun loaded with 3 1/2 magnum load buck shot ,aim carefuly so as not to miss, then "FIRE". problem solved,now go and buy a real camera.
Solution #29
posted on Apr 11, 2009
Very Helpful)
Golem
Rank: Apprentice
Rating: 100%, 10 votes
I have a 3 year old Canon PowerShot SX100 IS. While testing an external battery power supply I built, the external power connector pulled out while the lens barrel was extending just after I turned on the camera. Power to the camera was lost before the lens barrel fully extended and wouldn't reset when I repowered the camera. The dreaded error message "Lens error, restart camera" appeared and the camera shut down. I restarted the camera over and over and over again but the lens wouldn't reset. I was extremely lucky to find the information here and read various fixes. I didn't want to take the camera apart so I tried various fixes others have successfully used. I first tried smacking the bottom of the camera hard with the palm of my hand just after pushing the on/off button but that didn't work. The one which worked was smacking the camera on the side immediately after I pushed the on/off button. I smacked it quite hard twice with the palm of my hand then, suddenly, the lens barrel began to move and the lens reset itself back to its starting position. Thanks to everyone who has posted here!
Was this helpful?
Yes
No
Solution #30
posted on Dec 15, 2008
Very Helpful)
jaccktar
Rank: Apprentice
Rating: 100%, 4 votes
I was about to give up with my Ixus 75 - had tried all the suggestions listed but what worked for me was to strongly tap the unit on the palm of my hand immediately after turning it on. I had it lens facing upward and probably hit it 5 times during a second of time and hey presto... now to see how long it stays operational - good luck!
Was this helpful?
Yes
No
Solution #31
posted on Aug 04, 2008
Very Helpful)
lebowo
Rank: Apprentice
Rating: 100%, 1 votes
I have a canon powershot SX100 with the "Lens Error, restart camera" message. I tried wacking the camera as noted above while turning it on and it worked!! Thanks a lot.
Was this helpful?
Yes
No
Solution #32
posted on Aug 15, 2009
Helpful)
suzi_sema
Rank: Apprentice
Rating: 88%, 2 votes
Hiya. I had the similar problem. Canon IXUS 950 IS. The camera hasn´t been taken out in like 2 years,when I first experienced the e18/lens error problem. The lensshutters got stuck halfways closing, and whenever pressing on/off, the famous ticking sound appeared and after a few second: lens error/restart camera. I have tried to manually force/push the lensshutters together with no luck. After reading here, I tried the tapping (perhaps a bit too hard), a last time before dismantling the camera. And to my surprise the lens went out!!! Taking photos and videorecorder still works perfectly.
A million thanks to all you who has posted here for your help! My husband laughed at me when I said I would try to fix the problem, and his mouth was wide-open when he saw that I actually did fix it (for once ;).
Was this helpful?
Yes
No
Solution #33
Somewhat Helpful)
jessroxx
Rank: Apprentice
Rating: 75%, 1 votes
my suggestion is to buy a new camera and give this one to a bear at the zoo...jkp
Was this helpful?
Yes
No
Solution #34
posted on Oct 29, 2009
Not Rated)
jmulchan
Rank: Apprentice
Rating: 0%, 0 votes
I own the POWERSHOT SX100IS. I had the "lens error, restart camera". But I had success in applying what I have read here. I was able to see that the lens door was cocked open slightly and that one part of the lens seemed slightly higher than the other when looking from the top. But when I put pressure on one side of the lens that was higher, the door wanted to close. So I started the camera with the view photo button (blue triangle on the back) and held down or put pressure the side of the lens that caused the door to want to shut. When I noticed that the door shut comletely then I knew the camera had been fixed. I turned it on and the camera started normally. All solved. SAVED $120. Thx for all the suggestions.
Joel M.
Mardela Springs, MD USA
Was this helpful?
Yes
No
Solution #35
posted on Oct 10, 2009
Not Rated)
thedudeloves
Rank: Apprentice
Rating: 0%, 0 votes
Same E18 Error. I tried pulling dirt from the gears (A LOT) but it still didnt work. So I attemped to fix it myself by pulling it apart and following the directions. This was a disaster. There are so many reasons why this didnt work. 1st I have meat hands. They are made for grabbing lumber and cupping fine girls booty's, not for this. I think that i need little Asain hands to do this right. I had a hell of a time with the 4 different sizes of screws that went into the whole thing. I dont know why they cant just use one type. also getting the crcuit board strips out was really hard. How do you even grab it? I used a lil piece of metal to do the job and tore a hole in the strip! OMG! Then getting it back togheer was a *****. i even took detailed notes. Overall i wouldent suggest doing this unless you are the type of person who does this kinda thing for fun or a living. If there is anyway that you can have someone else do it its probably worth your time. Over all it took me about 3 hours to break it even more than it was to begin with. In that ammount of time I could have made enough $ to buy a new camera. oh well. good luck!
Was this helpful?
Yes
No
Solution #36
posted on Aug 25, 2009
Not Rated)
sjwalters
Rank: Apprentice
Rating: 0%, 0 votes
I have a Canon Powershot SX100IS with the lens error message. After reading the replies on FixYa I tried the gentle tapping on the side of the camera (with the palm of the hand) whilst powering up method and it worked.
Was this helpful?
Yes
No
Solution #37
posted on Aug 09, 2009
Not Rated)
Pen and Max
Rank: Apprentice
Rating: 0%, 0 votes
Thank god for this page, after a brief read we were still sceptical that anything could help, especially when banging your camera doesn't really sound like a great idea, however trust me it works a treat!
A friend dropped the camera and our lens had completely detracted into the camera body and wouldn't budge no matter how many times turned on/off, battery removed/reinserted etc so my boyfriend held the camera at an angle and banged it on its side (obv not on lens itself!) whilst turning it on at the same time. After a few hits we could see that the lens starting to move out ever so slightly so at this point increased the strength of knocking it until....sorted!!! Don't give up hope and end up smashing it out of frustration, it takes a while of bashing to get it to move.
Was this helpful?
Yes
No
Solution #38
posted on Jun 18, 2009
Not Rated)
cheerchamp32
Rank: Apprentice
Rating: 0%, 0 votes
i was taking pictures with my sx100ls and accidentally dropped it. when i picked it back up, the upper lense was tilted to the right. i tried turning it on and off but it just kept beeping at me and wouldnt move. i thought for sure i was in trouble, because it's my mom's camera and she loves it. and i was home alone and didnt know what to do.
-x-
if any of you had my same problem, do this: take out the battery for a couple of minutes, then replace it. find where the lense is sticking out the most,and tap it on your palm a couple of times. it should pop back into place. do this before going to a repair shop. if it works, it could save you a lot of money.
Was this helpful?
Yes
No
Solution #39
posted on May 04, 2009
Not Rated)
sookjinjo
Rank: Apprentice
Rating: 0%, 0 votes
The problem was solved!! I have powershot S70. I dropped the camera while I was taking picture. The lens was stuck so I got the E18 error. I did retract, tap and push more than 20 times, but no luck. I almost gave up. Finally I pushed the whole lens really hard while the camera was turned on. The lens was back into the camera completely and it works!!!
Was this helpful?
Yes
No
Solution #40
posted on Apr 25, 2009
Not Rated)
DeeceJ
Rank: Apprentice
Rating: 0%, 0 votes
I read all the blogs which told me how to take apart my camera to fix the problem - and it's allot more difficult than they say !
And then I gave the lens a little twist anti-clockwise and hey presto ! Problem solved. No E 18 error code and my cameras working perfectly again.
Try it. I hope it works for you too.
DeeceJ
Was this helpful?
Yes
No
Solution #41
posted on Apr 16, 2009
Not Rated)
Michael63543
Rank: Apprentice
Rating: 0%, 0 votes
GREAT! Solution #3 fixed my problem. Lense was not able to close, display stated "E18"... I manually moved the linse as shown on picture A in solution #3.. it worked!
THANK YOU, gtoes!!!
Michael
Was this helpful?
Yes
No
Solution #42
posted on Mar 29, 2009
Not Rated)
-TNN-
Rank: Apprentice
Rating: 0%, 0 votes
I had a similar problem with my lens not opening and my screen was black when i turned it on. My camera is a Samsung L210. I solved this problem by pushing the lens back into place then i took out my battery(the time doesnt really matter how long you take it out for). I put the battery back in the camera and then i turned it on, the lense made like a knocking sound and then my camera was back on, but everytime i turn the camera on the lense gets jammed again so i just repeat the same thing i did to get it on and it works everytime. :P
Was this helpful?
Yes
No
Solution #43
posted on Aug 21, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
We started this procedure but found it too intense and super complicated. So I hit the lens with the base of my palm while turning it on and it worked!!!!!!!!!!
Solution #44
posted on Aug 10, 2008
Not Rated)
henry95
Rank: Apprentice
Rating: 0%, 0 votes
When the E18 error is present and that the lens system is out to the “off”, but retracts and go out with “on”, it acts can be of a blocked problem focussing.
The following links is interesting for the Canon Ixus 750 or similar:
http://tumbleweed.org.za/
As it is known as: to check that the focussing system functions perfectly.
The screw below A being difficult to turn to make move the lens of focus, it is enough to dismount the metal plate hiding the gears on the outlet side of the actuator of focus (metallic cylinder to the top of the red circle) and to make turn the gears on the outlet side of the actuator with a small screwdriver and go up the lens to half the height.
Then, to make leave the objective (if it is in retracted position) while turning the large gears the zoom, released of the actuator for more facility,
To connect the ribbon connectors of the ordering of the objective on the mother chart, to start, the apparatus posts E18 once again, to again restart, the lens of the focussing system finds its place, E18 disappears.
As it is known as, it is not necessary to assemble for testing, the connection of the ribbon connectors of the lens system on the mother chart is enough.
Thus I solved E18 on my Canon Ixus, after 3 dismantle / reassembly
Sorry, I am French and I do not speak very well English.
Was this helpful?
Yes
No
Solution #45
posted on Aug 06, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
My E18 problem was resolved by, as turning the camera on, let the lens go in, but prevent it from going back out again, by a firm handhold.
Yngve
Solution #46
posted on Jul 01, 2008
Not Rated)
theonlyone78
Rank: Apprentice
Rating: 0%, 0 votes
Moving the sensor wheel fixed my camera!
Thank You to all who have posted here; saved me $150 in 10 minutes!
Was this helpful?
Yes
No
Solution #47
posted on May 25, 2008
Not Rated)
heliodor
Rank: Apprentice
Rating: 0%, 0 votes
Take a look at my guide on how to disassemble the Canon Powershot A650 IS camera with pictures.
http://heliodorj.blogspot.com/2008/05/disassembling-canon-powershot-a650.html
Was this helpful?
Yes
No
Solution #48
posted on Mar 23, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
It did not work on my camera. Finally I had to through it away.
Solution #49
posted on Mar 03, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I took my Canon IXUS SD700 apart and found a tooth broken off a gear.
Solution #50
Not Rated)
uclapt
Rank: Apprentice
Rating: 85%, 3 votes
My eleven year old accidentally knocked the camera over while it was in video-mode. Lens was stuck in the half-extended position and when I tried on/off it made a grinding sound and the screen started up but then defaulted to "Lens error, restart camera". After perusing this website, I took hold of the extend lens and manually wiggled it. Tried on/off and the grinding noise stopped, but still got the error message and no operation. So, I tried a quick rap on the leather armrest (lens side down) and the lens retracted and the screen turned on, ready to go! Enjoyed watching the video of the ball hitting the camera and my son's stricken expression into the camera lens right before the fade to black....Thanks for saving me $125.00 in repair costs and shipping!
Was this helpful?
Yes
No
Solution #51
posted on Feb 06, 2008
Not Rated)
Dmitry-GDT
Rank: Apprentice
Canon A610, full-size photos with comments in Russian.
Reassembly of lens unit was very inextricable for me...
Comments:
Feb 06, 2008
- Canon PowerShot A610 with E18. Full destroy and renewal. Full-size photos with comments in Russian.
Lens module is very sophisticated and its reassembling was awfully inextricable for me...
Was this helpful?
Yes
No
Solution #52
posted on Dec 30, 2007
Not Rated)
Muarrij
Rank: Apprentice
This is my 4th Ixus in 7 Years. The last one had an E18 error as it was dropped, I opened up the entire camera including the lens casing, on the Ixus 500 model and managed to fix the solution to a degree where everything worked fine except zooming inwards, which required a shutdown.
I upgraded to the Ixus 750 and the day I went on my holidays the same problem happened with this one. The auto lens cap is slightly open when camera shutdown. When you turn it on the picture is blurred. THis is definitely down to the motor that feeds the lens out. Needs to be opened carefully and calibrated. I can post a review online on how to do this if anyone is interested. muarrij@hotmail.com
Was this helpful?
Yes
No
Solution #53
posted on Dec 02, 2007
Not Rated)
S60093
Rank: Apprentice
Gtoews's solution also worked for my Canon SD400 when the lens would not extend. I had already taken it apart looking for a mechanical solution but was unable to force the gearing. Unsticking the position sensor disc did the trick. Saved me about $25 in shipping charges for extended warranty service. By the way, I encourage anyone who buys these gadgets to consider a Mack Camera extended warranty. A five year warranty cost me about $40 on eBay.
Was this helpful?
Yes
No
Solution #54
posted on Oct 21, 2007
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
WD-40  camera works great now
Popular Solutions for Canon PowerShot SD500 / IXUS
Questions and Unsolved Problems for Canon PowerShot SD500 / IXUS
Do you recommend Canon PowerShot SD500 / IXUS 700 Digital Camera?
Answer
Answer
Canon powershot sd500 stopped working and displays an error e18. lens no longer closes.
Answer
I have a Canon S80 that I inherited in semi-working condition. Previous owner replaced a damaged... (More)
Answer
s2is e18 problem lens is stuck and won't go in what can i do
88 Other Users Have The Same Problem - Continued
Comment by sabrinamvonb, posted on Apr 07, 2009
hi
my camera was working just fine the day befor, and then the next day i went to turn it on and the lens would open part wat then close again! the screen just said lens error...??? wat do i do?
Comment by jonesdel959, posted on Mar 30, 2009
Yeap. I have a powershot which starting doing this spontaneously. Probably not repairable economically; Canon doing their bit for the environment and landfill..
Comment by Guest, posted on Mar 01, 2009
I have a two year old SD550 with the E18 error-
I tried disassembling and now have what will be a future art project in thousands of parts.
Do all Canons have this problem?
Comment by Guest, posted on Feb 24, 2009
it is the same it turns on but beeps 3 times then turns off
Comment by Guest, posted on Feb 22, 2009
SO ANNOYING
was half way thru holiday and my camera lens was stuck and e18 came on screen - now it wont open at all
seems alot of people have e18 issues! CANON should deal with them
Comment by trumpet78gee, posted on Jan 21, 2009
Hi all ... I'm not sure how this site works so I'll give this a try ...
I have a Canon PowerShot SD550 which has (had) the E18 problem. So, first, thanks to all who posted this thread. I managed to synthesize a lot of the posted solutions and get the E18 error to go away. Much to my surprise, I disassembled the camera (perhaps more than I needed to). In the end, I think the solution was getting to, what looked like, the encoder for the lens mechanism motion. This was a little set of gears hiding under a little metal cover, hiding under the LSD. Basically I "exercised" the gears by manually moving them around a couple of rotations.
After miraculously getting all of the flat/flex circuit connectors back together and not loosing any screws ... I got the camera all back together. Now, the E18 error is gone ... the camera goes through all of the motions (focus, red eye LED, etc) and takes a picture. The problem: it doesn't really ever focus. The LCD shows a blurry image and that's what's recorded.
So, I'm not ready to give up on this thing yet; so any help/insight would be greatly appreciated.
Oh, one last question: after I got it all back together, I noticed a little (1mm x 5 mm) spring laying on the desk. Maybe that's the whole problem or maybe not.
Help ! (please),
Daniel
trumpet78geek@yahoo.com
Comment by Guest, posted on Jan 20, 2009
when i turn my camera on the lens bareley opens and then closes and the LCD says "LENS ERROR"
Comment by bepl, posted on Jan 18, 2009
The lens on my ixus 30 Canon digital camera will not close... i am unable to take a picture and do not know the reason for this....when the camera is put on i am able to see my old pictures but when i click to take a new picture the screen is blank..i dont know what to do...please help... the problem that appears is the E18.....
Comment by Guest, posted on Jan 03, 2009
My canon powershot has the e18 error
happened on both my S5Is and G5 - both were quoted at $260 to fix - both were thrown in trash. I will recommend to you, as I have to everyperson that I meet when the subject of pictures or photography comes up, to NEVER BUY CANON!! They are sub par mechanically, and insulting when attempting to aid the people who buy their products when they invariably break down. They truely do not deserve our money anymore - I will try any other brand now, not sure anyone can possibly be worse...any suggestions?
Comment by amywolfie, posted on Dec 30, 2008
I have the Canon Powershot SD400 and the lens is extended and does not react at all when turned on. Plays pictures I've taken but on Movie and Shoot mode, no response at all. Does anyone have any suggestions besides taking it apart myself? Thank you!
Comment by kekhongtan, posted on Dec 05, 2008
Faced this E18 a week ago on my 2 years old IXUS i Zoom.
Tommorrow will have my family tour. Too bad that still can't solve this issue. Very frastruating with this product. Losing confident on this brand. Just dragged out my old NIKON coolpix2500 from the store. It is still functioning very well except with 2.0 megapixels.
What to do?
Comment by Guest, posted on Nov 20, 2008
RegCure licence number
Comment by Guest, posted on Nov 17, 2008
My Sd450 was dropped not even 2 feet to the ground and the lens can no longer retract, so I got the E18 error. I've read on other sites that you can wiggle, push, or smack it back into place while its off or on. You will hear a click. This has not worked for me though. I've also read that connecting the camera to the tv resets it. I have not tried this yet, but I will. This camera is way too fragile if you ask me!
Comment by alanjraffert, posted on Nov 13, 2008
Canon Ixus 400 camera. This has just developed exactly the same problem with the E18 error showing.
Comment by Guest, posted on Nov 05, 2008
SD450....E18 ERROR
Comment by beanhead_pin, posted on Nov 01, 2008
A70 with E18 error code
Comment by Guest, posted on Oct 27, 2008
I also have the same exact problem. The lens is stuck.
Comment by luciarossini, posted on Sep 21, 2008
i have a asus a410 the display show me error e18.
no solution i have find
Comment by Guest, posted on Sep 07, 2008
yes same lens problem
Comment by Guest, posted on Sep 02, 2008
lense stuck
Comment by sardina77, posted on Sep 01, 2008
Powershot A630 got frozen with lens stuck out, green power light blinking but did not respond to pressing on/off button when i was trying to power it down. I took the batteries out, put the new ones, and it never came back on at all. Lens out, completely dead.
Comment by jpk320, posted on Aug 30, 2008
The problem started with the computer being stuck out and getting the lens error. sometimes the lens would move but would never close the whole way. now it just stays out. the problem did not respond to compressed air, forcing the lens or massaging the lens.
Comment by fn-missy, posted on Aug 28, 2008
my Powershot A560 fell down while i was taking a picture,the lens has failed to close.It gives me a LENS ERROR RESTART CAMERA.help me
Comment by hughesplace, posted on Aug 18, 2008
I have a Canon SD300 camera and for no apparent reason it just started to make this funny noise when in picture record mode. The lens will protrude, make that funny noise and then make 6 quick beeps, then display a black screen with E18 in the bottom left corner. After a few seconds, the camera will turn off, leaving the lense protuded from the body. Turning the camera back on will cause the lense to close, then open back up, produce that funny noise (the noise happens after the lense looks fully expanded), produce the 6 beeps, show E18, and shut down. If I switch the camera to review mode, the camera turns on and I can view pictures stored on my SD card just normally (except the lense is still expanded out).
Comment by Anooshik, posted on Aug 15, 2008
How to dismount powershotSD500, to clean it, please help me.
Thanks
Comment by Guest, posted on Aug 13, 2008
the lens doe
snt close
Comment by Guest, posted on Aug 06, 2008
Yup, me too.
I dropped my SD500 (while turned on) from about 6 inches off the coffee table and it immediately turned off but the lens was still out. Now everytime I try turning it on, it beeps a few times, flashes the display screen quickly, then goes black and leaves the "E18" code in the bottom left part of the screen.
I tried taking the battery out for a few minutes...nothing.
I tried gently manipulating the lens...nothing.
I tried not-so-gently manipulating the lens...nothing.
I even tried swearing at it...and still nothing.
Short of taking the camera apart, any suggestions?
Comment by malcolm4, posted on Aug 04, 2008
Canon SD200, 3 years old, always worked perfectly then today will not turn on, displays error code E18. It has not been dropped or exposed to sand, water, or dirt.
Comment by --michelle14, posted on Aug 01, 2008
my lens will not close and will not go in all the way in when I turn it on it says "Lens error, restart camera"
Comment by Guest, posted on Jul 30, 2008
is basically the same but i have a powershot SD450 so please help :]
Comment by Guest, posted on Jul 29, 2008
la camera mea digitala au iesit din functie arcurile si au sarit lentilele.obiectivul a ramas dezgolil,dar oricum nu se inchide si nu poti face poze,pe ecran E18. astept raspuns,mersi.
Comment by figacat, posted on Jul 28, 2008
canon a95 error e18
Comment by vpdeguz, posted on Jul 27, 2008
I have managed to fixed the E18 error using the guide above. The camera is PowerShot SD450. The tools: small positive screw driver and a toothpick. The toothpick is for the pulling out the plastic flat wires.
Tips on disassembling the digital camera:
1. Take note on locations and sizes of screws. I have used another camera to take the locations of the screws but I still end up with one extra screws and white rubber thing(not sure what it is called) at the end.
2. Be very gentle on pulling out the parts with plastic flat wires. Below is the LCD with plastic flat wires.
3. Encircled below has 3 gears. It took me another disassemble because I have forgotten a gear.
4. I didn't find any broken/dent parts on the lens assembly. But it took me a while to align the guidance track of the extending cylinders.
5. To remove the plastic flat wires, flip the lock up and pull out the wires with a toothpick. To connect it back, fully insert the wires and flip the lock down. The camera's motherboard has several of these connectors. I think there are 3 connectors that you just need to pull it out (without lock). For me, it took me another disassemble of the camera because some connectors were not fully inserted -- upon powerup of the camera, the LCD are all white.
Finally --- After 4 dissassemble of the camera, I saw the date prompt of the camera and able to take pictures again... :)
I hope someone can reply or me email about the white rubber plastic that I have missed. My guessed is that it is near the power button but I am not sure how to put it there... vpdeguz@gmail.com
Comment by Guest, posted on Jul 26, 2008
starview codes for teloewest 26 july 2008 lost
Comment by sprtygrl181, posted on Jul 26, 2008
Lens wont go back to place
Comment by Guest, posted on Jul 25, 2008
e18 error
Comment by leightellier, posted on Jul 22, 2008
I am having the same problem...the lens will not close and when I try to take a picture the screen is blank except for the E 18 script
Comment by Guest, posted on Jun 30, 2008
I have an sd700 that I dropped and it wouldnt fold up.  My brother popped the lens to what seemed to be straight, and now it acts normally, except only the middle of the picture is in focus.  I believe the whole lens in no longer aligned on the right tooth/etc.  I will probably try to take the camera apart and see if there is a way to realign it.  I hope there is a way.  If now I'll but another one on ebay, this is the best compact digital made to date.  The lens and sharpness of the pictures outperforms all the newer of canons sd's as well as all the other brands.
Comment by gigipigi, posted on Jun 28, 2008
I had the problem on a powershot s50.. thanks for all the suggestions.
The lens was stuck in a nearly completely retracted position (the battery ran out while retracting).
What worked was to press on the lens and apply a bit of twisting...
great!
But I will be sure not to buy canon again !!
Comment by Guest, posted on Jun 26, 2008
I dropped my powershot a410 on cement while the lens was out and get an e-18 warning with grinding noise....nothing works.
Comment by laura465, posted on Jun 24, 2008
My lens on my SD300 wont open at all. Beeps a couple of times and goes directly to E18. i don't use the camera that often and im finding it quite annoying. What do i do from here?
Comment by marei27, posted on Jun 23, 2008
my camera is a canon IXY 400, days ago it took two misty pictures then stopped. the lense since then is open and when I press the turno on off button it sounds as if it was sending a fax, then bips like a bomb about to blow and E18 appears on the screen. I have tried to put the lense back to its place, but do not want to make it worse. What can I do ?
Thanks
Mariana
Comment by Guest, posted on Jun 23, 2008
I have the Canon IXUS V2 Digital Camera and the problem that appears is the E18. The lens opens and extends, beeps and then closes moments later. The error message then appears.
Comment by phowa6, posted on Jun 19, 2008
My camera lens will not open.When I turn it on it make a whiring noise as if it is trying to do something and then in the left hand bottom corner the letters E18 appear. Can you help me?
Thanks
Comment by marquinho, posted on Jun 08, 2008
I have a Canon SD700, and am experiencing the same problem. Originally the lens was stuck out, so I pushed it in - however, now whenever I try to turn on the camera, I get the "Lens Error, Restart Camera" message.
I am technically saavy enough to open the camera, and tried to do it - however, my model is significantly different from the images shown here, and although I was able to get the external casing removed, I could not figure out how to remove the lens.
Anyone know where I can get a service manual for the camera, or could anyone help with some diagrams? Thanks so much!
Comment by Guest, posted on Apr 20, 2008
E18 appears at the bottom left of the screen
Comment by Rostlk, posted on Apr 14, 2008
We first encountered this problem on a trip in Costa Rica where the weather is very damp. Wishful thinking on our part made us believe the error was due to air moisture. For over a year this problem has been appearing during zooming in/out (not very quickly or very slowly... just zooming in and out) and lately is has been that we encounter the error more than use the actual camera. (The batteries are not to blame as we tried various things with different batteries when the problem begins).
I have contacted Canon now (today) to see what they can do since this seems to be an actual camera problem. I have had the powershot S40 (very old) ever since the first 4mp came out and it still works... it's sad that this new camera that was much more expensive is showing such a poor performance.
Comment by pierreh, posted on Apr 12, 2008
This occured after pressing by inadvertence the power-on button while it its case (not a Canon one).
The objectif (lens) tried to open (go out), but was blocked by the case, then the internal focus lens moved internally into the objectif that was supposed to be open, but was not (or only a little). The lens itsef could go into, but not the small "LUG" (plastical part outside the lens ring) which was blocked by the objectif ring, and fold. So, when closing back, because the lug was fold (toward the body), it was detected as "back in place" when in fact it was not yet. Then the objectif itself goes back into the body, but was blocked by the focus lens, not completely "rewind".
I took me a while (hours, couple of disassempling / mounting) to see that very small part folded, but after putting it back in place, some glue, my IXUS 750 was back to live!
First time I reassembled it, I just put the focus lens back into its position, but because the lug was folded, is was "over" the cell (detector of "back in place" postition), so it considered the lens NOT in place and tried to move it back ... strange noise of the motor not able to move it more, and the objective kept open.
Hope this helps,
Regards, Pierre (pierre.hardy@swing.be)
Comment by Hoolio222, posted on Apr 03, 2008
I have a SD550 Elph and it has the exact same problem.  Canon is only offering to upsell me on a new Camera.  Ridiculous, I paid $400 for this Camera just over a year ago.
Comment by vasanth_sit, posted on Apr 01, 2008
mine is Canon PowerShot A410 Digital Camera once i switch on the power on button... the lence came out and got struck... from than i am not able to close the lence... strarting of that problem i cant able to take new pictures ut able to see stored pics in memmory card... but after some time now i could not able to see the stored pics also. it is showing " MRMORY CARD ERROR"" also i showing""E18" dont know what to do. plz give me a solution................ to mymailbox83@gmail.com
Comment by Guest, posted on Mar 29, 2008
Turn camera on and lens cover partially opens. No picture on LCD ....eventual e18 shows in lower lect corner, camera turns off. I have tried to blow out any dust with compressed air but nothing seems to change result.
Comment by fuds001, posted on Mar 25, 2008
My ixus 700 flashed up E18 the other day, the image went fuzzy then the lens refused to go back in. I tried to work through some of the solutions on this page - the camera didn't have the foil cover over the mother board though. Eventually i put it all back together again, tested the camera which crunched as the lens went in and out, it then locked out, and the camera wouldn't turn off. I took it into a camera shop today and typically they said it was unfixable and the lens had been squashed - they hardly even looked at it. Any other suggestions?
Comment by katiexxsayss, posted on Mar 22, 2008
My Canon PowerShot A560 lens is not closing all the way. I've looked on other sites and tried there solutions but nothing is working. Every time i turn the camara on it beeps then says "lens error restart camara". Please help me!!!
Comment by Guest, posted on Mar 19, 2008
My camera will turn on, but only allow me to see old photos. The lens is stuck extended out and will not let me take a picture. I have taken the batteries out, pressed slightly on the lens, tapped the usb card, and nothing seems to be working.
Comment by tatersmydog, posted on Mar 16, 2008
my lens won't OPEN. It is so frustrating. I have tried everything.
Comment by alisonlee, posted on Mar 11, 2008
My Canon Powershot lens won't close. I get the e18 message on the screen.
Comment by HAJJS, posted on Mar 08, 2008
The lens on my Canon digital camera will not close, it was droped. The camera is a Canon PowerShot SD550 Digital ELPH. I am unable to take a picture. When the camera is turned on i am able to see my old pictures but when i click to take a new picture the screen is blank and reads E18. I have tried twisting the lens to pop it back in place. This worked on the top of the lens, but the bottom of it will is still uneven and I can't get it to go back in place. I have tried all the suggestions I have found on the repair guide but I still can't get it. Can you please help me fix this problem?
Comment by coollady, posted on Feb 27, 2008
E18 error with lense stuck closed-tried all fixes and removing outer casing and manually moving wheel worked!  Also gently blew out inside with compressor as it had a bit of sand inside.  Probably what caused m E18.  I will be traveling with my mini screwdriver set from now on- and a case at the beach!!  Thank you, thank you, thank you!
Comment by brittany555, posted on Feb 23, 2008
when i got it out of my backpack the lens was out.so i turned it on and a white screen popped up saying lens error. so i changed the batteries.it diddnt work.=/ so i push the 2nd lens back in now the biggest lens is still out and the only thing i hear when i turn it on is beep. please ehlp.its making me super mad.andd on top of that.i just got it!!
Comment by ains bott, posted on Feb 19, 2008
wont turn on except to beep and display e18
Comment by Guest, posted on Feb 19, 2008
Comment by Guest, posted on Feb 09, 2008
I dropped my Canon SD450. I am getting error E18.
Comment by Bianca808, posted on Feb 02, 2008
i won't close and the lens error keeps popping up on the screen
Comment by Guest, posted on Jan 17, 2008
my canonsd400 was dropped on the lens and now it won't open or close, the lens looks as if it is on a slant. Every time I try to put the camera on it beeps
Comment by Guest, posted on Jan 05, 2008
my lens is stuck and i get a focus error
Comment by Robyn_Hood, posted on Jan 05, 2008
I try to start the camera and lens error, restart camera comes up. I have tried to restart it, change batteries and change memory card -all of which none work. I own the PowerSHot A540
Comment by Guest, posted on Jan 04, 2008
I have a Canon Power Shot A520 the lens was dropped on it front while open. I turned the camera off for a few minutes and turned it back on, it made a noise like it wanted to close but the lens stayed half way open then displayed the Error18. Please help. The camera is no long under warranty. Thanks for your advice.
Comment by ruth321312, posted on Jan 02, 2008
it not WORKING
Comment by Tqueen1, posted on Dec 31, 2007
I dropped my camera and when i turned the power button on the power went back off and the lends wont go back in.
Comment by archadd, posted on Dec 27, 2007
the lens does not retract but I can still view the pictures. but when i want to take pics,only a blank screen appears.
Comment by lightning999, posted on Dec 26, 2007
My Canon is an S2 IS, just under 2 years old so the warranty has run out. When I turn it on, the lens starts vibrating, but cannot come out, then shows E18 error after a few seconds.
I suspect this camera, purchased at a Future Shop, never did operate correctly from the start, for three reasons: (1) The lens, even when first new, always seemed to be straining to come out; (2) far too many of my shots, even without using the 12X telephoto, turned out blurred; and (3) I could never use rechargeable AAs in it; I tried 3 different (new) sets of rechargeables, all fully charged, and always I got the 'replace batteries'. These are always lower voltage (1.2 V) than regular double-As (1.5v), and there never seemed to be enoubh power from the rechargeables. I had nothing to compare to know whether these were related problems, or problems at all, but in retrospect, it would seem my particular camera was faulty from the start.
I've tried gently pressing on the lens (it 'appears' to be out of alignment, as not eaqual spacing all around), blowing out with compressed air, all to no avail. Now I'm nervous, because before checking on the E18 error on the internet, I went out and purchased a new S5 IS (however, I did take an extended 3-year warranty this time). Will the same happen?
Anyone else experience these problems with an S2 IS?
Comment by Guest, posted on Dec 23, 2007
Had a similar problem wit my SD600. Lens would not open. I opened the camera as described in this post and jogged the gear at the motor. Lens then cycled normally. Good advice. I sure it saved me some bucks.
Comment by abasiyanik, posted on Dec 22, 2007
Canon powershot sd300
E18 as usual, a headache
once, I tried to solve it by pussing the lens a little. but last summer, ı reappeared again. No solution ı could produced.
I dont want to pay anymoney canon again. If i cant find any guide with pictures to repair it I will throw it away.
Comment by hozefa, posted on Dec 22, 2007
i have same problem in canon camera power shot s500, the error is E18,
plz help me, urgently
tks in advance
hozefa
e-mail : hfaizullah@yahoo.com
cell: 00971-50-2244936
Comment by cleanjohnny, posted on Dec 21, 2007
My IXUS 800IS is showing a "Lens error—Restart camera" message and the lens will not open. Any suggestions?
Comment by tash8, posted on Dec 21, 2007
I dropped my canon on a hard surface from about 3 feet. It will not close and I get the restart camera message...
Comment by boehmm2, posted on Dec 17, 2007
lm,l,n
Comment by janetf12, posted on Dec 11, 2007
I too have the same problem. Looking this error up, I noticed a lot of other people with this e18 error. Its a Canon problem and they should be able to fix this.
Comment by rohitthebest, posted on Dec 03, 2007
I am having the same E18 issue with my Canon IXUS 600
Comment by Copperlion, posted on Nov 11, 2007
Able to use LCD screen to see past pictures well, but lens will admit no light so no new pictures can be taken - the LCD or EVE viewfinder show only darkness.
Comment by Guest, posted on Nov 07, 2007
I have a Ixus 700 Canon and when I turn it on. It appears an E18 error. How do I make it to work?
Comment by ravindrababu, posted on Nov 06, 2007
e18 error occurring, lense is not going inside, trying for solution
ravindrababu.chebrolu@yahoo.com
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Canon PowerShot SD500 / IXUS...:
Top Digital Camera Experts
Rank: Guru Guru
Solutions: 870
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Digital Camera Experts
Top Camera & Camcorder Repair
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
Mikes digital camera repair
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
