Korg D4 4Track Digital Recorder Logo
Posted on Aug 31, 2011
How do i play my recorder through my practice amp?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on May 05, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
53
Points
21
Try using an adapter that fits into the headphone of the d4 and connects to a jack plug like on a guitar lead.most appliance stores should have these.
New strings on acoustic guitar need to reduce the squeaking
Finger noise, whether you like it or not, it's part of the guitar sound. How much or how little is present can be controlled by the player but it is pretty darn difficult to get rid of it altogether. Acoustic string noise, often referred to as finger squeak, is a byproduct sound that tends to occur while changing between chords and notes, and when moving your fretting hand up and down the neck. Some players value this noise as a natural sound that gives a live quality to recordings, while others want clean takes with zero squeak.
Find out where It squeaks most
The first, and most important technique is actually being aware that the finger noise is there. A lot of players have just turned out to that squeaky sound and think nothing of it. So, as a self-diagnosis, grab a recording device like your smartphone, and your guitar will work just fine. When you've recorded the song, playback and see if there are any patterns or any particular chord progressions where the noise is more noticeable.
Learn To Release Pressure Gently
Perhaps the simplest way to get around these string squeaks is simply to lift and shift. By lifting the left-hand finger you are avoiding the drag along the string. Once you have identified the problem progressions, practice playing through them, but slowly. Take your time, and after you have played the chord or note, lift your fretting fingers gently until there's no downward pressure on the string but your fingers are still in contact, this will help to avoid accidental open notes being played.
Practice contactless transition
After you have mastered the slow release of the fretting hand, the next step is to work on contactless transition. While you're practising, make this a slow and purposeful manoeuvre, in fact, think of it as 2 separate actions - lifting your fingers clear of the strings, then moving your hand to the next position. Be careful to lift your fingers directly off the strings in a nice smooth motion - if you make the action jerky, or you remove them at an angle, you may end up playing unintended pull-offs.
Move to the next chord
When your fingers are clear of the strings, move your hand to the next position while consciously avoiding contact with them. Once you're in the correct position, place your fingers directly down on the strings. This can take quite a lot of practice to avoid having to make small adjustments after touching down.
Start Using Pad
More of a noise reduction than noise cancellation, you can help string noise by shifting along the string with the soft pad of your finger rather than the callused tip. The tip of your finger is hard because you have been doing oh so many hours of practice, and that tough skin makes a loud noise on the string. If you try and slide the pad of your finger along the string you will notice that it is actually less noisy. So, if you can't avoid the slide along the string then rotate your finger a bit so that you can shift on the pad rather than the tip.
Moisturize Your Plans & Figures
This one is more so for your hands than your guitar, but failing all else, keeping your hands moisturised will make them softer and smoother, which in turn will reduce acoustic string noise as you transition between notes and chords.
Squeaking happens in every guitar a little less or more, but Make sure you use the best guitar parts which suits your style and body posture.
If you're just getting started in your guitar journey, it should be straightforward to get into the habit of consciously lifting your fingers between transitions, but, if you've been playing a while, it will definitely take a lot of practice to adjust your muscle memory. The key is to start slow, and make every move purposeful.
Dec 31, 2017 • The Music
tip
Studio Recording at Home; Part 1
For all of the musicians who want to record their demo, or even your next album, without paying pricey studio fees, this is the tip for you!<br /><br />First, let me say that it doesn't matter what DAW software you're using, as long as you're familiar with it and can navigate it easily.<br /><br />For that "full" sound that you hear on most recordings on CD and radio, here's a what you've gotta do:<br /><br />4 guitar tracks (two for each side of the stereo image, pan two out just a bit farther than the others).<br /><br />2 bass tracks (one recorded direct in [DI], the other amped)<br /><br />A single drum track<br /><br />Vocals to taste<br /><br />For the guitars, if you don't have an amp, or the equipment to record an amped guitar, there are plenty of amp simulation programs available. If you are using an amp, you'll want to place the mic in front of the amp, slightly to the side, pointed at the midway point between the center and the edge of the speaker.<br /><br />For bass, recording DI without a DI box can be a pain. That's where the amp sims come into play. Record two tracks simultaneously, and only apply the amp sim to one track.<br /><br /><br />That's all for this tip. Stay tuned for part Deux of Studio Recording at Home!<br />
on Feb 12, 2011 • Music
How do I stop my MG100HDFX from picking up radio stations........I CANT PLAY LIKE THAT!!!!!
Have you changed out your guitar cable? Also, if you have a broadcast antenna close to your practice area, that could be your problem. Try moving your amp to another location and see what happens. If it picks up stations at different locations that are miles apart, call Marshall...the amp is defective.
Oct 31, 2012 • Music
Volume issue
Tubes run hot in order to function. They degrade over time unlike transistors which usually work or don't work.
You should keep some spares around especially if you are out doing gigs.
Guessing at which tube is bad will be expensive.
With the renewed use of tubes in amps, there may be some tube testing available at a music store. Call around and see. Pull all you tubes and go test them.
How to transfer recorded songs from ctk 810in to sd card
I want to practice through key board by singing along with with the help of SD card. How can record my favorite songs as karokee in SD cart to play in the instrument.
Oct 22, 2011 • Casio Music
Hello, I have a new black jack interface and Sony Acid studio on my PC with Windows XP. when I plug in an instrument, I can hear it in the headphones of the Blackjack, but not in the computer speakers. but...
Look at the setups for voice and audio in the Windows control panel, "Sounds and Devices". Make sure the devices are set to the sources and destinations you want... This is not automatic and is a pain when you are going back and forth from recording and playing...
My Laney VS30 212 at band practice last week decided to intermittently cut out, but not fully just the volume would drop out then return about 5 mins later. Not sure if this was a common problem. It might...
Sounds like output valve, if the amp is more than few hundred hours then suspect this for sure. I don't know much about this amp specifically but does the sound fade/return suddenly or over a few seconds? Try running it with the back off and fan on the valves etc. Then play at loudness where problem occurs and see if any improvement. Remember that at band practice you always play much louder than you think and put a lot of stress on it.
When i play my bass through my amp it is really loud but when i go round my tutors for lessosns he has to turn his amp way up to get any sound at all.
His amp probably has lower gain. They vary quite a bit. Also the size of the speaker will affect it a bunch. If his is a tiny practice amp your bass will not generate much noise.
1) how to make my amp record....because its not working when i try... 2) do i have to a cord in line 1 and 2??? 3) do i have to plug in the cord in :.....line in or line out??????
You will use microphone with balanced XLR connector into the XLR mic input. Note, the ALpha does NOT have phantom power so you cannot use condenser mics.
A guitar can be plugged into the hi-z instrument 1/4 inch jack on the left front of the unit.
To use the line 1/4 inch inputs you will use BALANCED TRS 1/4 inch cables from your source.for these channels. The level on these needs to be line level.
The line outs are for sending audio out to an amp. There appears to be RCA outputs you can use as well.
I am not sure what you mean by making your "amp record"... An amp PLAYS the audio, usually into a speaker.
If you are trying to play a guitar through your amp AND record, then you will connect your guitar to the Alpha, the amp input will have a cable from say Line 1 OUTPUT and when recording wou will have the echo feature on so your guitar is passed through to the amp.
Top Korg Music Experts
john h
SmartAviator
SmartAviator
ADMIN Andrew
ADMIN Andrew
Are you a Korg Music Expert? Answer questions, earn points and help others
