Question about Cuisinart Coffeemakers
Cuisinart grind and brew
Fill with beans and water and start the grind process. coffee grinds and starts to brew then machine turns off. I push the "grind off" button and start button and it will continue for a little bit and stop again. after about 3 or 4 times doing it will finally finish. Any help would be appreciated
  • stevesport Sep 10, 2008
    The model is a DCC-390PC
SOURCE: Leaking cuisinart grind and brew
Our Cuisinart grind and brew was leaving a puddle under it after making a pot of coffee. I called Cuisinart this week and it turns out the handle of the carafe has to be lined up in the middle of the opening for the carafe. It will be under the word Cuisinart, in the middle.
We have now made several pots with NO residual puddle of water or coffee. It also seems to be making the pots quicker.
Before trying this I had run 2 pots of water with 1/2 cup white vinegar in it also. But it still puddled until we lined up the carafe as noted above.
Posted on Jan 16, 2009
SOURCE: I Have a Cuisinart Automatic
I do love our Cuisinart pot...but find they only last 2-3 years...so my suggestions is: if the pot is still in warranty, call Cuisinart for a new one...they are great about it. If you don't know if it is still in warranty, call them, give them the number and they will tell you.
jlo
Posted on May 31, 2009
co7196
  • 3433 Answers
SOURCE: I have a cuisinart with brew and grind coffee
Stuck? how stuck can it be when it is supposed to be removable? Try turn ing it,
Posted on Sep 24, 2009
  • 464 Answers
SOURCE: My Cuisinart 10 cup Grind & Brew does not
you need to run a few pots of straight white vinegar through the machine to clean out the lime build up in the tubes. the first time you do it, after it starts to pump the water, shut it off for a few hours and let the vinegar sit in the tubes. after doing this run a few pots of cold water through before making coffee.
Posted on Nov 08, 2009
SOURCE: Saeco Incanto S-Class Sirius coffee machine not sensing beans.
I have had the same problem the only way I could get it to brew would to use the program quantity feature every time. I was going to take it in today and decided to restore the factory settings and now its working like it should. This seems to be a circuit board issue Ouch! I have another issue with the steam, if I take the knob off it works if I don't it doesn't glad I bought a 2K model GRRRRR!
Posted on Jan 25, 2010
Hi, My machine starts the process allright. It grinds and starts brewing. A few drops comes through, then it just stops and a red light shines up. I have tried to remove some parts and cleaning them. It...
Sounds like the grind is too fine. If its (the big knob) below 8 in the bean hopper, turn it to 16. You can turn the knob to a larger # anytime but you have to be grinding to turn to a smaller #. Make 3 coffee but push the button when it starts to brew to stop the brewing until you get to the third coffee and just let this one brew. If it brew correctly then turn the knob down to a # a couple higher than you had before.
Sep 21, 2010 | Saeco Vienna SuperAutomatica Coffee...
I can't remember where to put the ground coffee. Is it in the same place as the beans but with the grind off?
No, ground coffee goes directly in the filter.
Fill the water to desired cups, and turn grinder off.
Thanks for using Fixya - a FixYa rating is appreciated for answering your FREE question.
Jun 18, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Cuisinart grind and brew 10 cup grinder stopped working
My grind and brew is a little different, but when I have this problem, I havve to remove the beans and vaccuum out the bean reseviour. It gets clogged and then it won't grind.
Mar 23, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Beans ground but continuous grinding but not brewing
The grind switch is stuck. Try to free it and clean it.
Mar 15, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Coffee grinder clogging
Remove the grind chamber.
There is a black plastic pice sticking up in the area underneath where the grind chamber would sit. Lift it up, and you will see it is sort of like a hatch. It is probably clogged with coffee grinds.
Go ahead and clear out this chute, and see if it resolves the problem.
-Tha Mp3 Doctor
Mar 01, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
This happens when the machine needs cleaned. Fill coffee maker with white vineger instead of water. Turn grind off, make sure empty pot is in place. Brew a pot of hot vineger. Repeat. Brew a pot of hot water. Repeat. This process removes mineral buildups inside machine. If you have access to filtered water, start using that to brew your coffee. I do and probably do this process 1 per 6 weeks.
Oct 07, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Cuisinart Grind & Brew not using all the water in the reservoir
I was having problems like this and then I read on a different string on this website that people have had success by flushing the system numerous times (sometimes up to six times) with vinegar. I took out the charcoal filter and flushed once with vinegar but only saw a small amount of improvement. I was out of vinegar so I used Lemishine mixed with water and it went from making one cup to making a full pot with one flush.
Jan 10, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Cuisinart Coffeemakers Logo
76 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
