Question about Panasonic Home Theater System System
Panasonic Home Theater system SA-HT 1500
Base unit will not switch on.
When mains power is applied standby indicator flashes and so does clock display.
Obviously the fault is in the power supply system. Does anyone have any experience of this happening to them and a possible solution?
  • Anonymous Dec 12, 2008
    I have simillar problem and the unit stays on the stand by... Once was repaired while under warranty and they said it was power supply. I guess it is same problem again.
Not sure this will work for you, but it did for me. Really simple. Unplug the unit for 5 minutes. Started right up.
Posted on Dec 01, 2008
Why does the standby light either remain on or fail to turn on?
Hi Alan, the standby light should be off when the unit is up and running and be on when the unit is powered off indicating that the unit is on standby, Thanks, JT
May 25, 2015 | Onkyo HT-S6200 7.1-Channel Home...
My SA HT 730 displays INIT on main unit and tray will not open. Can you help me? I love my panasonic.
INIT = Initiate, reason why you cannot open it is because it is having an error starting up and it is not completing
Oct 20, 2014 | Audio Players & Recorders
Standby led but cant on power
Look like malfunction AMP PCB Board.Please open top cover, unplug flex cable attached to connector AMP PCB. Try now power- ON the unit.
Jul 24, 2014 | Panasonic Home Theater System System
Have a Panasonic SA-BT100 which now will not power up, there is no red standby light, have swapped the power lead to check the fuse and still no power - any suggestions ????
These unit have an internal fuse. This will mean removing the power lead, opening the case and replacing the fuse. Probably best to have a professional do it. Sorry, Shouldn't be expensive though.
Apr 04, 2011 | Panasonic Home Theater System System
I have a panasonic dvd home theater sound system SA-HT930, and the dvd player, is broke can do nothing with it, need a new one but the plug between the ampli and the dvd wont fit on any new dvd theater...
Believe it or not there is a seller on eBay who offers a one-price fixit solution for your unit for $100.
http://cgi.ebay.com/Panasonic-SA-HT930-SA-HT940-Repair-Service-/360178573162?pt=LH_DefaultDomain_0&hash=item53dc50df6a
That aside, these types of systems are designed as a package to be used as a unit. Otherwise they might have standard connectors. Another closely-related Panasonic SA-HT system might work for you but I doubt anyone manufactures anyhting to adapt non-standard speakers to standard electronics.
They actually say on page 9 of the manual:
"Use only supplied speakers
Using other speakers can damage the unit, and sound quality will
be negatively affected.
I would interpret that to mean 'use these speakers only with similar Panasonic electronics'.
Jan 15, 2011 | Panasonic sa-ht930 Home Theater Audio...
I have a Samsung HT-z510 home audio and the wireless receiver for the back speakers stays in standby mode. I have set the mode to cinema but it still stays in standby. What can I check next?
Here is how I reset. Key terms to identify: Main unit, remote unit, transmission card, reset button on remote unit. 1. Unplug both units and remove transmission card from rear of Main unit. 2. Wait five minutes. Insert transmission card in rear of Main. 3. Turn on both units. If units do not communicate, there will be a solid red indicator on remote unit...In this case continue with 4. Use remote and turn off main. 5. Point remote at main and enter the following four digits, holding each down for about a second:  0   1   3   5 6. The main unit should turn on. 7. With remote unit on, press and hold down the reset button for 5 seconds.
Nov 29, 2008 | Audio Players & Recorders
Unlock code for Panasonic SA-HT 340
i have the same problem .. somebory can help us? thanks
Jan 05, 2008 | Panasonic sa-ht930 Home Theater Audio...
Panasonic Home Theater System System Logo
168 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
