Question about Gateway M275 Tablet PC
Black Screen When i turn the computer on the fan runs, the lights on the screen turn on, it sounds like it is working but the screen is black. What could the problem be.
  • 4 more comments
  • webb337 Sep 11, 2008
    Same thing here - When i turn the machine on, the computer fires up, but the screen is black and I cant do anything.... ...motherboard?
  • gbp_424 Oct 01, 2008
    Everything fires up except the screen and stays fired up. Nothing shuts off until I hold the power button down. So the only thing that seems to not be working is the screen.
  • hsorensen11 Jan 11, 2009
    My computer froze up so I held the power button back to shut it down. Then tried to restart it but the screen stays black.
  • Anonymous Jan 11, 2009
    My screen is super dim. You can just barely see the screen dispaly operating, but not bright enough to be of any use. It's like a dim control got stuck on the lowest setting, but nothing can get it to go brighter.
  • Anonymous Apr 12, 2009
    Originally mine wouldn't boot into anything but safe mode. Then I tried doing a system restore to an earlier date. Removed the HDD to recover some files, and planned to reinstall windows from the recovery CD.... then I started having the same problem described above: Fan stays on at full speed, but nothing shows up on the screen or from the VGA output.
    Not sure how the **** a motherboard randomly dies, but that does sound like the likely cause.
  • ron0932 May 11, 2010
    Mine does the same thing...turn it on, fan runs for a couple of seconds, hd light lights for a couple of seconds, then screen flicker, no screen light...ect. I even went into a closet so it would be completely dark, but nothing.... ??? Video Card? or MB?
Pretty sure it's the motherboard.. i'm in the process of replacing mine
Posted on Oct 21, 2008
My Gigaset tablet just goes black and I can't turn it on. I wait a day, plug it in. Gigaset comes on screen then goes black. How do I get it to turn in?
Sounds like the battery has failed. The battery must be good for the wall charger to run the computer, it will not run solely on the charger.
Jan 23, 2017 | Tablets & eReaders
Why did the screen turn black?
Hook it up to your pc and try to run an update, or take it in to a local repair shop.
Jul 03, 2015 | Tablets & eReaders
Hp entertaiment pc problem display STAYS BLACK BUT ALL LIGHTS COME ON
If the Video Controller fails, the screen will stay black when the rest of the computer runs as it should. To test this, look to the side of the computer and locate the external Monitor attachment. It is a nine pin male outlet. Take a regular computer monitor and attach it to the connection and turn on the computer. If the Monitor acts like your normal LCD screen, then the main LCD screen is bad. If Neither the Monitor or LCD works, then the Video portion of the computer may be defective.
Apr 15, 2014 | HP Pavilion Entertainment tx2500 Tablet...
Replaced digitizer now black screen only
If the LCD was working before replacement, the most likely suspect is a loose cable connection. It is also easy to crimp those tiny flat cables, or to break the locking mechanism so the cable can work its way loose. Sounds like you booted to a black screen after repair, so I would walk back through it and double check every connection, then look at all cables closely in bright light and with a magnifying glass, to be sure nothing sustained damage (twist, crimp, etc.). Remember to check the power cable to the LCD, as well. No power, no backlight, no video.
Mar 22, 2014 | LG Electronics Unlocked Optimus G Slate...
I have a tx1410 touchscreen hp laptop I have a black screen when i turn on my computer and all the buttons are lighting up. Everything works but the black screen. I put a dvd disk to boot it up and then...
First you need to check if you did not have any flash drive or device attached to your laptop when you turned it off. Because if you do, your system will not booth completely, you will only be having a black screen, and to solve that, you just remove your battery and insert in back then try to turn it on.
Ensure you have the battery fully charged. Then turn it on. If that does not help, then the problem could be a hardware problem, which could be that the module is faulty and the screen is not lighting up or the hard disk is disconnected or the RAM is not connected properly.
The module is like the flex on the laptop that assists the information from the motherboard be read on the screen. So if it is faulty then you will not be able to see anything.
For that, you need to open it up and replace the module. If it is the hard disk, just tighten the connection and the RAM too, then try to couple it back together and turn it on.
Try to hold down control+alt+delete to see if the task manager comes up, if it does, then you know it is not the module, then you select task manager and run an operating system disk, to format your hard drive and run a new operating system.
These are a list of most likely problems that can affect the screen of your laptop.
If you are not familiar with such technical activity (loosening the laptop), i will strongly advice you seek technical assistance from a professional, to avoid shock or further damage in the unit.
Take care and good luck
Oct 18, 2010 | HP Pavilion tx1410us Tablet PC
Hardrive won't run, screen is black
Most possible one of your Toshiba Tecra m4 driver is not working properly, but don't worry give me a call at +1 (833) 493-0111 so that i can suggest you the right way to fix it!
Apr 13, 2017 | Toshiba Tecra M4-S435 Tablet PC
Black screen at power on
I had the same problem. I pull of battery and then immediately reattached and ta-daaaa! Windows came right up!
Hope this helps!
Jun 23, 2008 | Samsung Q1 Tablet PC
Samsung q1 black screen
That would be normal, as the variable speed fan comes on only when the computer is under load.
What is not normal is that the fan is not coming on when the computer overheats.Or that the fan is not cooling enough when computer is overheating.
Monitor computer temperature using a software, check if Fan is coming up when temperature gets critical.
If fan comes up but does not cool enough, then replace the fan, it is not efficient anymore because of a bad bearing or dust. ~Also ensure that fan is well mounted, if fan has poor contact with CPU surface , cooling will be poor.
If fan does not come up, and critical temp is not detected, then the sensor on motherboard is bad, this is very uncommon. When this happens the problem is usually related to system or power settiings , rather than overheating.
If fan does not come up and temp is critical, then fan is faulty, replace it.
There are also more than one fan on many laptops, check that one of the fans (CPU fan, video fan) is not completely ded, and therefore cause for the problem.
By using the software below you can also find out if the problem is really overheating. If temperature results within normal range, then usually it is not overheating.In that case test systtem and check power saving settings.
Here is the software to control your fan and temp. sensor state:
Download SpeedFan - Access temperature sensor in your computer
Download SpeedFan 4.38
SpeedFan - Free software download
Mar 12, 2008 | Samsung Q1 Tablet PC
Gateway M275 Tablet PC Logo
505 people viewed this question
Top Gateway Tablets & eReaders Experts
Ricky Ostrom
Ricky Ostrom
Are you a Gateway Tablet and eReader Expert? Answer questions, earn points and help others
