Question about Samsung SV5000W VHS VCR
No power I have Samsung SV5000W VCR. There is no power when I turn it on. I don't know how it happen but it has been like that for about a month now. The fuss seems to be good. I suspect the filter capacitor and IC controller or powr regulator. Can I get an assistance please? Want to fix it myself. Thanks Ben
  • Anonymous Jan 02, 2008
    The power all of a sudden didnt go on. I dont know what happened it worked perfectly for a while. Please help me if you can.
    Thank you
    Novelist:
  • 130 Answers
Check the mode switch. There is a motor or 2 that drives the mechanical parts somtimes its in the back with a small belt and a little worm drive. You can somtimes spin that with your finger then it will power up again. The mode switch rotates in different positions and it controls all the motors and tells the machine where its at in the load and unload position. Somtimes they get dirty from use and then find dead spots. You can clean them with a pencil eraser and they will work again but its just a matter of time they will fail again. The motors get old and start to draw more curent then the switch was designed to handle thats when things start to fail. I really believe they are only designed to work for a short period.
Posted on Apr 10, 2006
    President:
  • 3,130 Answers
Well first thing you need to do if you know how to troubleshoot the power supply is to get a service manual or a schematic diagram. Then go from the front to the back as some techs start from the end of the supply to the front.. To each his or hers own I guess. Not much to tell as these vcrs have been very reliable and I havent gotten one in yet for service . sorry Good Luck
Posted on Apr 08, 2006
Stopped working, cannot even turn it on and casette is still inside. Please help
The vcr has a power supply problem, the repairs will run the cost if not more than a new machine, if the tape is precious and you want to save it, the top will need to come off 2 to 6 screws to access the cassette tape, sometimes you can manually unload it by turning the gears towards you on the side of the basket, but if the tape is spewed or you are not sure how to proceed take it to a shop to have them deal with it.
Feb 14, 2011 | Samsung SV5000W VHS VCR
Can this unit be plugged into a 220v power supply overseas? The manual says it accommodates 100v-240v.
Yes! If you look on the back it should say the voltage ratings. Beside that UK voltages can be as low as 220 at times and in some areas!
Nov 30, 2010 | Samsung SV5000W VHS VCR
VCR can not be turned on, no any light on. Tried to unplug and plug on again - no result.
The problem has been solved. The failed electrolytic capacitor (1000uF x 16V) in the power supply circuit was found. The VCR was functional after the failed capacitor replacement. This filter capacitor needs to be high ripple current part, so, hopefully the new part (with unknown ripple current capabilities) will work fine.
Jan 09, 2010 | Samsung SV5000W VHS VCR
Samsung SV-5000W VCR. Voltage regulator?
This unit has a universal power supply that automatically detects proper voltage. No buttons or adjustments required, just plug her in.
Jan 04, 2009 | Samsung SV5000W VHS VCR
Tape stuck, no indicators lit
check the tip in my profile
Sep 01, 2008 | Samsung SV5000W VHS VCR
Power light is on, but nothing happens.
Two questions, Are you able to load a cassette?, and are you able to watch TV through your VCR? These two questions are vital to further analysis. if the answer to both is no then you will have to take the VCR to a TV repair shop because it will require internal repairs that you may not have the equipment to perform. Please get back to me with the answers to these two questions Thank you,
Aug 28, 2007 | Samsung SV5000W VHS VCR
Faintly blinking power light
This may indicate power supply problems, or perhaps an overload condition, causing the power supply to go into overload protection. If you have a voltmeter, schematic (helpful but not 100% necessary), you could check voltages. You should see at +5 volts, +12 volts, and one or two others. A frequent power supply problem is one or more electrolytic capacitors go wacky, and cause the voltages to be way off, and a non-operational unit. If this is one of the newer low cost rigs, then taking it to a service center isn't cost effective. Toss it and purchase a new one.
Mar 14, 2007 | Samsung SV5000W VHS VCR
VCR Samsung SV-5000W
You should take off the top cover with the set unplugged and see if there is a main fuse that popped. If there is, put in another fuse,. If that blows, then your going to need to have the power supply in this unit repaired. Good Luck
Dec 28, 2006 | Samsung SV5000W VHS VCR
Doesn't power ON
If you have no indication of power at all,(no lights,no display)the fuse is the first component to check but the vcr has be unplug from the wall when you remove the top cover and remove the fuse to check it.Be carefu.
Sep 25, 2006 | Samsung SV5000W VHS VCR
No power
Is it plugged in?? When was the last time you used it?? Did this happen after a storm?? What make and model of vcr?? How old is it?? We need more info if you want help on your troubles then it dosent work.
Apr 08, 2006 | Samsung SV5000W VHS VCR
Samsung SV5000W VHS VCR Logo
239 people viewed this question
Jerry Greenberg
Jerry Greenberg
