Question about HP Compaq nc6320 Notebook
HP Compaq nc6320 PC bios password
Can u help me please to remove this password?
  • duqkiii Sep 11, 2008
    ill try thank you.
  • bluebase Dec 21, 2008
    Hi i have the same problem on same laptop, but i have removed the little battery and plugged it in again but still it comes up with sayin in a blue box "Power on pasword" i cant even enter anything into that box...
    Please could u help ?
    thanks
  • 91 Answers
Ok, as long as the high security level has not been set in the bios then the following will work to reset / disable the bios password.
1. Remove the battery and mains adapter.
2. Remove the memory cover on the back of the laptop and remove the 2 keyboard screws.
3. Open the laptop and at the top of the keyboard you will see 4 sliding tabs. They are located between the 'Esc & F1 keys' 'F4 & F5 keys' 'F8 & F9 keys' and 'F12 & delete keys'. Slide these down and lift the keyboard up and pull forward slightly so as to disengauge the bottom lugs. Be carefull as there is a ribbon cable at the bottom that does not need to be tugged or removed.
4. You will now see at the bottom behind the keyboard a small battery connected to the motherboard. Gently pull the small white plug upwards untill it is removed from the board.
5. Wait 5 minutes and re-connect the small battery plug.
6. Re-install the keyboard and push back the clips. You do not need to replace the screws yet.
7. Apply the DC jack and power on - DO NOT INSTALL THE MAIN BATTERY.
8. Turn the laptop on while pressing f10 repeatedly but slowly - Do not hold it.
9. If high security is disabled you should now be in the setup screen, select 'Restore Defaults' and press F10 to save.
10. The password is now removed.
If this does not work then HP say that there is no other way to reset it. Im not sure about that, there probably is by some method of de-soldering the bios chip. However the above method worked for me so I hope it does for you. Please rate if you have any luck.
Sparkyuiop.
Posted on Dec 03, 2008
    Novelist:
  • 130 Answers
For removing the BIOS password we need to remove the RTC Battery from the notebook. after removing the RTC battery from the motherboard turn on the notebook without the RTC battery.
I will provide you the service manual for thiese steps.
Here is the link for service manual:
http://h20000.www2.hp.com/bizsupport/TechSupport/CoreRedirect.jsp?redirectReason=DocIndexPDF&prodSeriesId=1839146&targetPage=http%3A%2F%2Fbizsupport.austin.hp.com%2Fbc%2Fdocs%2Fsupport%2FSupportManual%2Fc00805752%2Fc00805752.pdf
Please check the pagenumber 137.
Posted on Sep 11, 2008
  • Jaipal Reddy
    Jaipal Reddy Sep 11, 2008
    Sorry about the above link. Here is the direct link:
    http://bizsupport.austin.hp.com/bc/docs/...
3 Suggested Answers
SOURCE: HP Compaq nc6320 PC Notebook Problem
unplug the internal battery for 5 minutes, then reboot with power battery out (only on mains). It is documented in the manual.
Posted on Nov 03, 2008
  • 98 Answers
SOURCE: crack bios password on compaq nc6320 - please
My best suggestion is to call Compaq or HP for assistance regarding on this. Thank you.
Posted on Oct 09, 2009
Testimonial: "thanks - I like to do things myself, but I will call them - "
How to remove bios password hp compaq nx9030 device
Hi Adel,
I am afraid there is no way still to retrieve BIOS password but you may want to contact HP Support to check if they have ways to check that for you. Usually for the case you have it is replace MOBO already. Please check the number on the link below base on your location.
Contact HP Phone Assist HP Official Site
Apr 26, 2014 | HP Compaq nc6320 Notebook
Password
open laptop, remove cmos baterry and leave it out for at least one hour , this will clear the bios password.
Jun 03, 2013 | HP Compaq nc6320 Notebook
How to recover the bios/cmos password on my hp compaq nc6320 t5600 1.83ghz ?
To reset the BIOS password read the information from this link.
In case of your HP Compaq laptop the easiest method would be using software from Hiren's Boot CD as it's pretty hard to open it up and reach for the CMOS battery or the jumper.
Oct 26, 2010 | HP Compaq nc6320 Notebook
Crack bios password on compaq nc6320 - please
You can crack dell bios password with Windows Password Recovery Tool 3.o . Here is a good post to help you:
http://www.windowspasswordsrecovery.com/crack-dell-laptop-password.htm
Oct 09, 2009 | HP Compaq nc6320 Notebook
HPnc6320 Bios lockout.
download the manual from the internet, it will give you all that information.
Feb 14, 2009 | HP Compaq nc6320 Notebook
Pl,ease help....
plz check the website for more information
http://www.tech-faq.com/reset-bios-password.shtml
Sep 03, 2008 | HP Compaq nc6320 Notebook
Try unplugging internal battery for a minute or two it worked for me.
Sep 01, 2008 | HP Compaq nc6320 Notebook
HP nc6320 BIOS Power on Password
You Have to Remove RTC battery ( Cmos ) battery.
Wait approximately 5 minutes
Replace the RTC battery and reassemble the computer
Connect Ac Power to the computer. Do not reinsert any batteries at this time
Turn On the computer
all the passwords and all the cmos setting have be cleared.
Aug 12, 2008 | HP Compaq nc6320 Notebook
Big problem
to clear cosmos(reset bios) remove rtc battery for a few minutes then replace ;restoring bios to factory set.
battery looks like large digital watch battery.usually located(but not always) underneath keyboard.
Mar 18, 2008 | HP Compaq nc6320 Notebook
HP Compaq nc6320 Notebook Logo
7,864 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
