Question about Samsung SV5000W VHS VCR
No power There is no power when I turn on my VCR.
  • RickK Nov 26, 2007
    No storms, no power supply problems, nothing unusual. It was used within the last couple months. Now it is dead. The fuse inside is good and nothing in the power supply looks burned or toasted...
2 capacitors in power supply 10mf 160v & 1000mf 16v, there are cluster of 6 caps on the cold side of power supply, check all, but it is usally those two
Posted on Oct 16, 2007
Hi I have the same problem. No power to the unit. Fuse looks good. Who can repair or replace the power unit? do know any service center near Washington DC? Please advise
Posted on Sep 30, 2007
  • ranjanprema May 23, 2009
    It happened again.... No power to the unit. Samsung service center fixed this only last year and it happened again when there was no storm or thunder. I called Samsung service center and they want to rip me off to fix it again. They also sugested to look for a new one since mine is old and out of warranty. What a poor service/support !!
    President:
  • 3,130 Answers
Is it plugged in?? When was the last time you used it?? Did this happen after a storm?? What make and model of vcr?? How old is it?? We need more info if you want help on your troubles then it dosent work.
Posted on Apr 08, 2006
SOURCE:
Should I turn OFF thew recorder after I set it to time record??
No,u can't turn off power the VCR.Than there no power to the VCR,it not on,only on standby power.
Oct 06, 2010 | Toshiba W522 VHS VCR
Whats the process to change RF to channel 4?
1 Press POWER to turn the power off.
2 Press TV/VCR, current VCR Output Channel will appear on the LCD display.
3 Each time TV/VCR is pressed for 2 seconds, the LCD display changes as follow
clock press tv/vcr RF3 2 secondes later RF4.
• VCR Output Channel is automatically set during EZ Set Up.
1. If Channel 3 (or 4) is an active broadcast channel in your area, the Channel 4 (or 3) will be set.
2. If both channel are the active channel or none active channel, the VCR Output Channel will be set to Channel 3.
• Cancelled the EZ Set Up by pressing POWER during EZ Set Up before setting the Output Channel.
• VCR Output Channel will not change to previous VCR Output Channel if TV/VCR is pressed continuosly for more than 2
seconds.
May 27, 2010 | Sharp VC-H965U VHS VCR
How can i get the code for a ge universal remote?
press your code search button until it blinks red light then press vcr button make sure vcr is turned on. After pressing vcr button press power button on remote repeatedly until power on vcr turns off then press enter on remote should be set for you
Sep 22, 2009 | Universal Remote Control GE174Universal...
After vhs auto rewinds both it and TV power down
some televisions have a feature where the video signal disappears,they power off.when the vcr shuts off,the signal goes and the tv shuts down
Jul 07, 2009 | Emerson EWV403 VHS VCR
VCR runs a few seconds when I insert a tape then shuts off power.
You have to change the two VCR rubber bands
Jc
co6bg@yahoo.com
Feb 02, 2009 | Emerson EWD2202 DVD Player/VCR
Vcr does not run
Try changing the channels on the VCR itself. If you can do that, then it would indicate a problem with the VCR's remote. If you are still unable to change channels on the VCR manually, it could indicate a circuitry problem, for which you will have to get the VCR serviced.
Oct 25, 2008 | Sony SLV-685HF VHS VCR
HR-A37U remote won't work
It's not unusual for remote controls to stop functioning either partially or fully. To determine where the problem is, you will have to go through a process of elimination. The easiest way to find out where the problem lies is to purchase an inexpensive universal remote at a nearby store. Try the different codes and see if you can activate the VCR. If it works, you have the option of keeping the remote or returning it for another one if you cannot access all the functions of the VCR. I have seen exact replacements online for under $20.
If it does not work then the trouble is most likely in the VCR itself, unless the proper code could not be found in the universal remote, in which case you need to try another brand or model.
The only other suggestion I have for you would be to unplug the VCR from the AC power for at least 5 to 10 minutes and then plug it back in and try the original remote again.
I hope this helps, good luck.
Oct 21, 2008 | JVC HR-A57 VHS/S-VHS playback VCR
TV image goes off when VCR power turned on
The vcr is connected in between the antenna (or cable) and the tv, and when it turns on its tuner takes control of the signal. Either:
1) press the VCR/TV button on the VCR to let the signal go stright thru
2) Tune the VCR to the channel you want to watch and set the TV to the VCR's input.
3) If you use a coax cable connection to the TV, try switching the VCR to the other channel (3 or 4, switch in the back)
4) Change the TV connection to RCA cables on the A/V inputs.
Hope Ya Fix It!
Jan 13, 2008 | Televison & Video
My DV-T5DN won't turn on...
your vcr timing is out or mode switch isfaulty.disconect vcr from plug for 20 sec plug back the tape mechanism should reset
Dec 23, 2006 | Daewoo DV-T8DN VHS VCR
Samsung SV5000W VHS VCR Logo
406 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
