Question about Xerox Phaser 8400 Laser Printer
Dark streaks There are dark streaks in the printing that show especially in the yellow. I've done all the cleaning protocols and replaced the maintenance kit. Help!?
  • avaterlaus Oct 02, 2008
    I have dark streaks across the printed areas, especially on the complex images. Also, most images are slightly darker. I have cleaned the printer and it has recently been serviced by a Xerox dealer.
    Novelist:
  • Xerox Expert
  • 297 Answers
Dark streaks are an indication of "burned" or overheated ink. This will occur when the printer sets for a long period of time and nothing is printed. The problem will usually disappear after 50 pages or so, unless the printhead is damaged.
If the print remains dark, the printhead will need replaced.
(Very expensive)
(Dark print can also be caused by using Non-Xerox ink)
Posted on Jan 17, 2009
C252 streaks
Check your consumables. Press utility then check consumables. If anything is at the end of life, it needs replaced. It sounds like your drums are not cleaning properly and need to be changed. If they are fairly new, then I would suspect the transfer belt. If you know hoe to get into service mode you can go into test mode. Then run your halftones on each color. If it moves around, its your drums. If it stays in one spot, its your transfer belt. Also you could check your drum units. If they have streaks going across the green drum, like its dirty, then its coming from the drums.
Apr 17, 2014 | Konica Minolta bizhub C450P Laser Printer
Have an Everest III disc printer that is not printing good labels. Seems the blue prints OK but the are streaks on the disc where the red and yellow should be printing. Changing the ribbons didn't
First thing is to completely CLEAN the printer. All rollers and any point that contacts the ribbons or transfer material.
John Norman
Max Optical llc.
www.maxoptical.com
Aug 08, 2012 | Rimage Office Equipment & Supplies
I have a LG 42LB5D 42" 1080 LCD television that
hi, usually you can correct this issue with only a few system checks, dark streaks can be caused by damaged pixels on the screen, in which case you need to replace the TV.
  • Inspect where the dark streaks are on the television. If the streaks occur at the same place on the top and bottom of the screen, they are due to the formatting of a movie or television show you are watching. This is normal. Also, if the streaks appear on the left and right of the screen, they are due to the show being filmed in full-screen instead of wide-screen. This also is normal.
  • Change the input setting so you are viewing the contents of a different device. If the dark streaks are gone, you know they are due to the device connected to it. However, if the dark streaks remains no matter what input the TV is connected to, the problem lies with the television.
  • Inspect the cable connection. Oftentimes when connecting a computer to an LCD TV, you can have strange dark streaks across the screen. Use a DVI-to-HDMI cable connection when plugging in your computer, then press the "Menu" button on your TV remote, select "Picture" and chose "Square Pixel." See whether the image adjusts and the dark streak goes away.
  • Contact the manufacturer of your LCD television if the dark streak remains. This streak can be caused by a defect in the television; if the TV is still under warranty, you can have it replaced.
  • Feb 02, 2011 | LG 42LB5D 42 in. LCD Television
    Have a canon c130.changed toner and still getting dark streaks on copies. Have cleaned all I could find inside still dark streaks
    Try doing a "stop test." You would induce a jam before the paper reaches the fuser.
    Just open a cover while printing and hopefully some image has been transferred to the paper. If the defect exists already then the laser unit, or document scanner may be causing it.
    If that eliminates the dark streak, then obviously the fuser FG6-3720-000 should be changed.
    Whit
    Item, Inc
    Aug 18, 2010 | Canon C130F Black and White Copier
    The left hand side of each page prints some streaky dark lines. I've tried to clean it and put it in cleaning mode but nothing works. Help please!
    Remove the toner cartridge. Turn it over and slide open the gate that covers the drum. Do you see streaks on one end of the little colored cylinder? (drum)
    If so then the streaks are coming from the cartridge.
    90% or better of the time, especially on HP's the print quality issues are coming from the cartridge.
    Good Luck and Thank You for using Fixya.
    May 13, 2010 | HP LaserJet CP1515n Printer
    Dark black streak down the middle of the page
    sounds like your cartridge is leaking. I'd try replacing the cartridge
    Apr 30, 2010 | Canon PIXMA MP830 All-In-One InkJet...
    Dark streaks
    You need to remove the maintanence kit and clean the wiper blades there and where the paper comes out of the machine at the top. See below and check when your maintenance kit runs out and how to replace it!
    http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=389,E=0000000001343282793,K=7185,Sxi=9,Case=obj(947)
    http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=389,E=0000000001343282793,K=7185,Sxi=9,Case=obj(1031)
    Nov 03, 2008 | Xerox Phaser 8500/DN Printer
    Lexmark X83 printer has streaks printing color pictures (but text is fine)
    This is the problem with the cartridge if you brought original Lexmark cartridge you can get it exchanged as the cartridge is nay be defective and the cartridge comes with one year warranty...........................................
    Jun 02, 2008 | Lexmark X83 All-In-One InkJet Printer
    Sharp AR BC320 not printing correct colors
    sounds a lot like the print heads are clogged. Can you print a test page, and how does that come out?
    Feb 19, 2008 | Sharp AR-BC320 All-In-One Led Printer
    Dark toner streaks
    can only be toner, drum or fuser, pull out drum and look at surface are you streaks present? usually drum.
    Stop a print half way threw machine and then remove drum and look at print, pre hot bit (fuser) are you marks there? If so it is drum, if not fuser.
    Nov 21, 2007 | Brother IntelliFAX 4100 Laser Fax
    Xerox Phaser 8400 Laser Printer Logo
    362 people viewed this question
    Top Xerox Office Equipment & Supplies Experts
    Michel
    Xeroxrep
    Level 1 Expert
    Philip Hughes
    Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
