This happens often. Sometimes your mower will start and run again and sometimes it won't. When it doesn't run it's because your timing is off, caused by a dented or sheared key.
To replace remove top cover to engine, and any other side attachments, this should expose the flywheel. Remove the top bolt and look between flywheel and top of crankshaft, you will see a small square notch. This is where the shear key is placed. Remove the flywheel and replace the shear key. Replace all parts in reverse order and you should be mowing again. GOOD LUCK.
