Question about Kenmore 23822 Top Load Washer
Kenmore elite washer
How does the control panel come off? it seems the big control knob is screwed on????? i cannot get this knob off; it looks like it must come off in order to get the control panel off. help.....
  • Anonymous Mar 16, 2014
    kenmore 70 control panel turned knob backwards
  • 958 Answers
Nope, the knob does not come off in order to remove the panel off.
look at the edges of the back of the control panel, you should find philips screws at the back. if not then figure out how to remove the plastic edges of the panel. they are covering the screws.
if you found the screws, remove them then pull the panel towards you and the plastics hooks at the bottom of the panel would slide out towards you.
then you were able to open the control panel..
hope it works..
tnx 4 using fixya,
drcool
Posted on Sep 11, 2008
I have a Kenmore 8o series model 11024892 washer. How do I remove the very right hand control knob so I can get behind the front panel to replace a part?
If this is a top loading machine; remove the trim strips on the left and right ends of the dash. Then you'll see a screw at the bottom of each corner(left and right). remove (AND KEEP) the screws. Now the dash will lift and fold back.
Aug 27, 2014 | Kenmore Elite 45986 Front Load Washer
We need to replace the lid switch on a Kenmore Elite Washer...how do you do that?
Look on the back side of your control panel.Remove the screws from that panel you will find documents about your Kenmore..
Sep 17, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
Where can I find a diagram to show me how to unclog my drain pump on My kenmore elite he4t washer
Their are unfortunity no video or drawing online that i know of,i have tried to find some to show people how to do that. However this is how you do it. Remove the small front panel below the main one where the door is at the bottom of that panel under it their will be 3 screws (one one each end&one in the center),the pump will on the right side,unscrew the big white knob justa little bit and have some towels to catch the water that will come out.Once all the water is out unscrew completly and pull it out.
Gene
Aug 07, 2011 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE4T Washer
This advice is for Kenmore Elite and Whirlpool Duet model front loading washers. If you experience a problem where the door becomes jammed and will not unlock or open, here's an easy way to gain access inside your washer WITHOUT calling the repairman.
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Sometimes these doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" "DLE" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Oct 13, 2009 | Kenmore Washing Machines
Removing front panel from kenmore elite HE-3 front load washer?
If you've removed the screws and the panel sticks, tapping on each side will knock it loose. The panel should drop down, then off. You can also try propping the two front feet of the washer up slightly for better access. A 2x4 works real well. This will allow more room for the panel to drop and gives better access to the screws. The washer is very heavy, so you may need some assistance to lift the front. Either lift from the bottom, or place your hands on the front facing of the cabinet to push the washer back. DO NOT push on the door or control panel.
If you still need assistance, please let me know. I hope this helps you.
Jul 05, 2009 | Kenmore Elite 45986 Front Load Washer
I have a Kenmore 'Elite' front loading washer that stinks
Have you been leaving the door cracked open after washing a load? If not, mildew will form and smell. If you have, then it would be something else. Respond with any questions.
Jun 12, 2009 | Kenmore Elite 45986 Front Load Washer
Taking bottom panel off kenmore elite front load washer
theres three screws at the bottom,,of the bottom panel,,its easier with a torexs head driver,,,onthejob
Jan 23, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE4t Washer Control lock lit, door locked
121 MINUTES USUALLY DRAIN CYCLE PLZ REMOVE 3 BOTTOM PANEL SCREWS 7 MM SCREWS, TO OPEN DOOR SLIDE RIGHT HAND TOWARDS DOOR LOCK ,THERE WILL BE A SMALL LEVER TOO PULL DOWN ,NOW ITS OPEN,,, SINCE U HAVE BOTTOM PANEL OFF PUMP IS RIGHT IN FRONT REMOVE PLASTIC HOUSING CLOCKWISE ,,,REMEMEBER HOLD 3 GALLONS OF WATER STILL ,HAVE BUCKET READY ,NOW CLEAN OUT PUMP AND DEBRIS ,, CLOSE IT UP SHOULD BE FINE NO MORE PROBLEMS ,,,,,
Jan 01, 2009 | Kenmore Elite 45986 Front Load Washer
He 3
I had this problem once before have you tried removing the front bottom access door(do this by removing the screws under the front panel) then opening up the cleanout it is a big white knob and has a screen in it try that
Oct 08, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore elite dryer
can you spin the drum by hand? if not,pull front panel off by removing three screws on bottom, remove lint screen, then remove three screws holding inlet housing ( the big brown thing in front) check to make sure not clogged with sock, panty hose ,bra underwire ,etc.
Feb 17, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore 23822 Top Load Washer Logo
Sal DeAngelo
fordexpert
Ed Mac
