Hello: Remove the distributor cap. Check the rotor, see if there is a black spot where the metal piece makes contact with the carbon stick out tha makes contact with the coil. Did you replace that piece when you replaced the coil, it should have come with the new coil? Also did you reinstall the ground strap that was under the coil and went to the stick-out that the black connector plugs into the cap?
