Question about HP Compaq Evo Notebook N410c
Memory upgrade Hi, hope you can help me, when i fit the memory upgrading from 256mb and adding a 512 to the bottom slot nothing happens when i try and boot up nothing at all
    Novelist:
  • 116 Answers
There is many things that can happen with RAM that end up with this issue.
First I'd try removing the 256 and just place the 512mb stick into the first slot and see if that works. If it doesn't there's one of three problems occuring.
Incompatible RAM (which may fit and lock in place but still not meet the requirements systems BIOS, so it will not function)
Oversized RAM Stick (some models will only use single sided sticks of ram, where most of the newer sticks are double sided. This can actually cause problems like this and even sometimes work but only show half of the ram on that stick)
Dead Ram (It's possible and I've had it happen a few times, that you could have a dead stick of RAM. If the 512 stick works alone without the 256 in there; the the problem lies elsewhere.)
Each manufacturer has different specifications on their systems and the ram that they can use. Believe it or not, one laptop I had would only work if you had two matching sticks of RAM in the slots. So, I could use the two 256mb sticks together; but I couldn't use a 512 and a 256. I couldn't run the 1gb stick and a 256 or a 512 stick. It had to be two matching sizes. So, make absolutely sure you have a compatible stick of ram for the laptop (I suggest calling HP/Compaq and asking them if it is the correct chip as you can never be too sure). If it still will not work, then either the laptop won't support all of the 768mb, or you have a dead stick.
Try these things and see what happens. If you still have a problem, by all means, ask away. :)
Posted on Sep 10, 2008
What is the max ram for toshiba laptop model #
Hi Fhiken!
That modell comes with 256mb rab and supports up to 512mb ram.
The ramtype on it is SDRAM
I hope the info helped you
Nic
Aug 20, 2009 | Toshiba Computers & Internet
Hi, Replacing my 256mb ram (1 slot) with 1Gb (2x512). The computer would not boot. Removing 1x512 memory the computer works fine. I put my old 256Mb back with the 512 Mb and the system only reported 256Mb....
Is the speed of the RAM the same mixing PC 133 and PC100 ram can cause problems working together. Also it sounds as if your board will only upgrade to a maximum of 512 MB total.
Aug 15, 2009 | AOpen Computers & Internet
I have a Easy Note M5 280DW and would like to know if I can upgrade the RAM?
Standard Memory 256 (256MB x1 Removable) Maximum Memory 1 GB The standard memory of your system is 256 Mbytes and the maximum memory it supports is 1 Gbytes.
So you can either upgrade the RAM by adding 1 stick of 256 Mbytes (for a total of 512 MB) or buy two sticks of 512 Mbytes each (for a total and maximum memory of 1 Gbytes).
You are looking for PC2700 DDR Memory.
In any case, check the memory you have installed.
You can download a free utility like CPUZ that will give your information about your system, including the number of memory slots available and used and the memory (amount and type) installed: http://www.cpuid.com/download/cpuz/cpuz_152_setup.exe
Aug 03, 2009 | Packard Bell Computers & Internet
I want to upgrade my ram what type of ram should i use and how what is the maximum amount of ram i can upgrade to?
Memory Upgrade for Sony VAIO PCG-K35 Laptop, the Sony VAIO PCG-K35 Laptop takes the PC2100 DDR SDRAM SODIMMs Memory Type, and comes installed with 512 MB = 256 MB (removable) + 256 MB (removable) of Memory. You can upgrade your Sony VAIO PCG-K35 Laptop to up to a maximum of 1.0 GB Memory, the system has 2 sockets to install Memory, already with 512 MB = 256 MB (removable) + 256 MB (removable) standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
Regards
Jun 29, 2009 | Sony VAIO PCG-K35 Notebook
Adding memory to a a75-s211
How much memory did it have before you removed the 256Mb RAM?
If it had 756Mb RAM then the memory in the laptop has 512 Mb plus 256 Mb RAM modules, the 256Mb in the slot you can see and possibly 512Mb in a slot under the keyboard or soldered on the motherboard.
Therefore by removing the 256Mb and replacing with 1Gb memory module will give you a total of 1.5Gb
Jun 22, 2009 | Toshiba Satellite A75-S211 Notebook
Sir,i would like to upgrade my memory(256MB DDR2)for acer travelmate 4061nwlci pls inform if 1GB is compatible.pls help
Your System memory is upgradeable:
256 or 512 MB fitted as standard upgradeable to 1 GB of DDR2 533 memory, or 2 GB using two soDIMM modules.
Regards,
Mike.
Feb 23, 2009 | Acer Computers & Internet
Ram upgrade
Its support "DDR SDRAM"
Max Supported Ram is "1GB"/"1024 MB".
Ram Speed: 266 Mhz..
Good luck...
regards,
Dec 04, 2008 | Toshiba Satellite A65-S1068 Notebook
Ram memory Problem?
Go to http://www.memoryx.net and run the 'Identify my computer' bit, clicking on 'Scan my system' and follow instructions.
The other thing is that if the MAX is 512, you'd want low-density memory.
Sep 10, 2008 | Computers & Internet
Problem upgrading RAM to Intel D845GLLY
Most likely the memory is incompatible or in the wrong configuration. Check here to see the proper configuration for this motherboard.
Jul 16, 2008 | Intel D845GLLY Motherboard
HP Compaq Evo Notebook N410c Logo
112 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
