Question about Microwave Ovens
WHERE CAN I PURCHASE A GRILL STAND FOR A PANASONIC MICROWAVE MODEL NN-K627MBBPQ ; SERIAL NO. U88200943 IN IRELAND OR UK.
MicrowaveSvc
  • 9098 Answers
SOURCE: Need door assembly diagram to
While I don't have that model's diagram, normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
Normally the problem is not the spring, but a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
If it's the door panel, it's usually easier and cheaper to use epoxy and some kind of hardware to fashion a new spring mount.
The door latch head (hook) is easy to replace or repair if that's the issue.
You can order Panasonic parts here.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Jul 23, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Setting time on Panasonic NN-CD748B microwave
Panasonic's UK site is here and you can choose Support, then search for spares, servicers, downloads and contact info.
Posted on Jan 09, 2009
SOURCE: Panasonic NN-H264 1200...stops after 3 seconds
I found sufficient information elsewhere.
Posted on Feb 13, 2009
  • 178 Answers
SOURCE: Can't open microwave door
It sounds like the push to open lever is cracked or broken. You have to remove the 'wrapper' to open the door manually from the inside to check the 'door keys' or door hooks to make sure that they are in tact. Then, check the door opening lever between the 'push to open button' and the lower door key.
Posted on Sep 13, 2009
Testimonial: "Thank you for replying! You really seem to know what you are talking about!"
  • 178 Answers
SOURCE: Need a users manual for a Panasonic Dimension 4
http://www.retrevo.com/samples/Microwave-manuals.html
Hope this helps!!
Posted on Sep 14, 2009
It just beeps when plugged in cannot press anything to start it timer menu does light up model # nn-sn960s panoasonic micro wave
Panasonic Microwave - ConsumerAffairs.com
www.consumeraffairs.com > Homeowners > Microwaves
Rating: 2.6 - ‎53 votes
After looking, door was starting to arc and burn around the edges in three places, ...You can't leave this oven unattended for a minute or you could be calling 911! ... In October 2014 I purchased a Panasonic microwave model NN-SA661S. ... The timeremits "4 beeps" when the time is up; other microwaves, continue to beep ...
[PDF]operating instructions - FTP Directory Listing - Panasonic
ftp://ftp.panasonic.com/microwaveoven/.../nn-sn651_nn-sn661...
PanasonicModels no. nn-sn651b ... nn-sn661s .... Use this appliance only for its intended use as described in this manual. do ... Thank you for purchasing a Panasonic MicrowaveOven. ... you press Start. note: The Glass Tray can turn in either direction. ..... If a pad is pressed and no beep is heard, the unit did not or cannot accept the
Jan 19, 2016 | In Microwave Ovens
Need user manual for National model no: NN-8655 Microwave oven user manual...
I would suggest that contact the dealer from whom you purchased the oven or call any number listed on the model tag of the oven.
Jan 06, 2014 | Panasonic Microwave Ovens
Model: NN-SD277W.     serial number: 6A88040672 A.
There is a dead short in the microwave oven that can be any number of things, yes you will need a pro to fix this and I suggest an estimate first.
Mar 12, 2012 | Panasonic Microwave Ovens
Where can I get a manual for a panasonic microwave convection oven serial number 863170033 model number NN-2909 manufactured in June 1993.
Partstore.com has the owner's manual for sale: http://www.partstore.com/Model/Matsushita/Panasonic/NN2909.aspx ; scroll through the parts list in the All Parts section or limit your search to the Microwave documents in the box on the left. http://www.partstore.com/Part/Matsushita/Panasonic/NN2909/Matsushita/Panasonic/OMNN2909/New.aspx is the direct link.
Unfortunately, I do not see the NN-2909 listed at any other site.
I hope this helps.
May 28, 2011 | Smeg FMC24 850 Watts Convection /...
My Panason NN-C994S is on demo mode and I am unable to switch it back? Do you have instructions to convert back to cooking mode. Thank you
If you go to the Panasonic site you can download the manual.
www2.panasonic.com/consumer-electronics/.../model.NN-C994S
Regards
Alan Hood
ami-man
UK
Apr 05, 2010 | Panasonic NN-C994S Convection/Microwave...
Microwave Manual
You can get the manual for this model here:
www.chsinteractive.co.uk
Sep 27, 2009 | Panasonic Microwave Ovens
Jan 05, 2009 | Panasonic NN-S753 Microwave Oven
Operators manual for NN-ST656W Panasonic
Your search is complicated by the fact that this is an Australian model.
Your manual and other documents related to this model can be downloaded from this page.
Aug 02, 2008 | Panasonic NN-T888S Convection/Microwave...
Panasonic Dimension 4 Turbo Bake Microwave oven. Everything works except the microwave element. Why?
Your Magnatron is most likely to have failed, its an expensive part and on a turbo 4 could be 2M236-M42. Unfortunatly this appears to fail due to reduced air flow. So if you do replace it I would clean the rear grills completely to increase the airflow within the oven.
Apr 14, 2008 | Microwave Ovens
Microwave Ovens Logo
52 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
