Question about Bissell 7901-1 ProHeat Scotchgard Upright Wet/Dry Vacuum
Bissell Proheat wont spray soap with uniformity
My Bissell proheat will not dispense soap when the trigger is pressed. I have taken this thing apart from top to bottom and can't find anything wrong with it. I have even used my shop vac to blow into the soap dispensing hole while on water only at the same time i am vaccumming out the hole where the red spinner is. When i vaccuum it out it will spray but when i turn the soap dispensing knob to high traffic or the medium setting it stops working after a few seconds. I have reversed the blow/**** thinking there might be debris in the line and it works for about 20 seconds or so but then won't work again. I love this cleaner but am thoroughly disgusted with its performance at the present time. Please help
  • Anonymous Sep 15, 2008
    See above
  • Bissell Master
  • 43,501 Answers
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
jhkl
Posted on Sep 30, 2010
Bissell 9500 proheat 2x wont spray liquid to the floor
heatman101
ghhdg
May 29, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell ProHeat 8910 wont spray water or solution
heatman101
sgb
Mar 18, 2010 | Bissell 8910 ProHeat Clear View Upright...
Machine will not dispense water even though reservoir is full. Soap is not dispensing either.
check the spray nozzles on top of the brushroll. these often clog. If those are clear could most likely be the pump as they fail frequently.
Jan 29, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Why wont my bissell proheat clearview dispense soap?
heatman101
rw
Nov 17, 2009 | Bissell 1699 ProHeat Clear View Upright...
Wont spray soap
Please look at my other posts for this solution
Aug 24, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
No solution is spraying out when i press the trigger
I had somewhat the same problem.... I had water comming out but the solution was not comming out.... I called bissell and the woman talked me through it.... first put in water only mode,,,,, then Fill water tank with fresh water and put back in place,,,, then remove soap dispenser put to the side,,,, now , power on your cleaner,,,, for the next steps, do this exactly as I tell you >>>>>>hold down the trigger that releases soap the whole time you do the following>>>>>> switch between water only and heavy traffic four times,,,, all while while holding the trigger, then still holding the trigger, stop on high traffic the fourth time, leave it there,,, now put the soap bottle back in,,,,, still holding the trigger and hold the trigger down for exactly one minute after you replace soap bottle,,,, you should start seeing the soap come out........ (make sure its on floor cleaning and not TOOLS) Hope this helps and if it does,,,, give these instructions to someone else in this help area.........
Jul 04, 2009 | Bissell 8910 ProHeat Clear View Upright...
Bissell proheat
First is the smart mix valve turning like it should? If it is then replace the soap dispensor. Also is the gasket on the valve at the bottom of the bottle?
May 28, 2008 | Bissell 1698 PowerSteamer ProHeat Upright...
Bissell 7901-1 ProHeat Scotchgard Upright Wet/Dry Vacuum Logo
606 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
