The EC1 error code means "Incorrect Printhead". Try to follow the steps below to identify and fix the issue:
1.
Make sure the printer is on. 2.
Open the printer cover. The print cartridge carrier moves and stops at the
loading position, unless the All-in-One is busy. 3.
Remove both cartridges from the carrier. 4.
Close the printer cover. 5.
Rebrick (pull out power supply, black box where the
power cord is plugged in at the back of the printer, and put it back after 30
seconds). 6.
When the printer turns on, reinsert one cartridge first. 7.
Close the printer cover and check for any errors. 8.
If no error appears, reinsert the other cartridge. Close the printer cover. 9.
Replace whichever cartridge is causing the error to appear with a new
cartridge.
1. Make sure the printer is on.
2. Open the printer cover. The print cartridge carrier
moves and stops at the loading position, unless the All-in-One is busy.
Note:
If the carrier does not automatically move to the center, turn off the
printer/unplug the printer from the power source and then slide the carrier to
the center.
3. Remove both cartridges from the carrier.
4. Close the printer cover.
5. Re-brick your printer.
Pull out the power supply, black box where the power cord is plugged in at the
back of the printer, and put it back after 30 seconds.
6. When the printer turns on, reinsert one cartridge
first.
7. Close the printer cover and check for any errors.
8. If no error appears, reinsert the other cartridge.
9. Replace whichever cartridge is causing the error to appear with a new cartridge.
2. Open the printer cover. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
Note: If the carrier does not automatically move to the center, turn off the printer/unplug the printer from the power source and then slide the carrier to the center.
5. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
6. When the printer turns on, reinsert one cartridge first.
8. If no error appears, reinsert the other cartridge. Close the printer cover.
