Question about Toshiba MV19N2 19 in. TV/VCR Combo
IR REMOTE 123475322-AA
Hi;
I have a IR Remote 123475322-AA and i don´t know haow to program my Samsung Tv. I hope you can help me. My email address is bustamante_43@yahoo.com.mx
Thank You
Sergio Bustamante
3 Suggested Answers
premtech
  • 934 Answers
SOURCE: captions
Carol I'll try sending the owner's manual to your personal addy... On the remote, in the center field area there are a row of three buttons, the center button larger than the rest. And right below that a row of four buttons. The one on the right is the CC button. Press that and see if the message disappears... Again I will try sending you the manual.. Bill
Posted on Jun 04, 2007
  • 4 Answers
SOURCE: Need help to re-program Toshiba remote that came with MW20FM1
Check out Toshiba Customer Support. They e-mailed me the instructions to reset the V-Chip.
customer_support@tacp.com
Posted on Sep 14, 2008
SOURCE: Toshiba md12m1 tv/dvd, original remote needs reprogramming
i have a toshiba tv how do i reprogram it ,evry time the electric goes out the tv goes out to be reprogram and i for got how and do not have i book.
Posted on May 12, 2009
Remote doesn't work. have purchased after market units and they don't sync up either? What to do?
Return the tv universal remote where u bought it,get ur money back.If none of the tv univeral romote programming codes on the owner manual codes for ur tv make and model don't even work and don't have any responses for ur tv make and model functioning all.Try website like Remotes.com to buy the tv original remote or a very closed compatible clone one.
Sep 03, 2011 | Toshiba MW24FM1 24 in. TV/VCR/DVD Combo
No Remote control
A fairly common problem with these sets is that the connections to the IR receiver inside the set degrade. Quite often all that is required is a resoldering of the pins of the receiver. This is a 3 legegd part within a small metal box located near the fron of the TV. If you have no experience with TVs, do not attempt this. I would guess that a TV shop would be willing to resolder the pins on this for not much money. Call and ask. It might be a cheap fix for you. Cleaning the lens of the remote will have no effect.
Dan
May 03, 2010 | Quasar VV1309 13 in. Combo
I bought a replacement remote control for my tv and doesnt work, how do i get it work? I put fresh batteries, reset the remote, and pressed the tv/dvd button. model MD14FP1
Have you make sure you were sent the correct one, according to the info for the model you give the replacement remote should be a 72796929 and it's available through the partstore.com for about 10 dollars. If you got a universal or programable remote then you'll have to try the code search procedure listed in the instruction manual. If you have the correct remote(part number) then there is a problem in the IR receiver panel or the IR receiver itself. If you have a universal remote you might want to try the dvd codes also because you have the combo/TV
Apr 07, 2010 | Toshiba MD14FP1 14 in. TV/DVD Combo
Sylvania srcd227 remote code/tv/vcr/dvd combo
hi! i have here a couple of codes for your tv! just try them 1004, 1007, 1018, 1027, 1047, 1056, 1057, 1059, 1060, 1061, 1103, 1124, 1145, 1150, 1153, 1279, 1296, 1387, 1464, 1483,1046, 1465,1150, 2092, 1464, 2408, 1465, 2260, 1027, 2064, 3105, 1124, 2078, 3088, 1296, 2213, 3147, 1145, 3095, hope this helps!!! goodluck!!!
Mar 05, 2010 | Sylvania SSC719C 19 in. TV/VCR/DVD Combo
Remote Control does not work
well probally not dust sounds like a bad reciver i just fixed one about a month ago
Apr 03, 2009 | Sylvania SRC22134 13 in. TV/VCR Combo
Tv not responding to new remote control
Was the replacement remote identical to the original one; or, does it need to be programmed. Also, if your replaced your old remote because it was not working, it might be that the IR sensor on your TV is bad.
Nov 04, 2008 | Aiwa VX-S205 Combo
21" Panasonic TV W?DVR
Hi : if you're having problem programing the philips remote, you can you used the search option to find the right code for your Panasonic TV. In order to search by auto without a user guide please follow the step below.
1.Turn the panasonic tv on.
2. On the univercial remote control there a button mark code search or search.
Pressand hold down the code search button until the LED light come on steady.
3. Press the TV button onthe univercial remote one time.
4.Press the power button on the univercial remote severail time until the tv turn off
When tv turn off press the OK or ENTER button on the univercial remote control to save the setting.
Good luck.
Dec 13, 2007 | Televison & Video
Remote Control Won't Work
Could be the IR detector or something in the support circuit for that sensor - it's a bit like sayin my car goes thump, thump, thump what's wrong.. :) Ahh better not go for laughs here...Let me ask, Do all the rest of the functions of the TV work okay? (ie volume, channel, power on/off)? Did you purchase the original remote, as a replacement, for that TV or some universal? When the remote quit working - was it working one-day and then just not working the next? Have you recently moved the TV, one-room to another, out of the way to clean underneath or moved it in any way? Let me know. Bill my private email is premtech@willapabay.org
Jun 10, 2007 | Toshiba MW24FM1 24 in. TV/VCR/DVD Combo
Can't program the channels
Here is where I found the remote code (1256) for the TBX-2000AF and it has many more codes for Polaroid models. Good luck (copy and paste this link) http://polaroid.custhelp.com/cgi-bin/polaroid.cfg/php/enduser/popup_adp.php?p_sid=fPLB5Gzi&p_lva=&p_li=&p_faqid=2854&p_created=1116267791&p_sp=cF9zcmNoPSZwX3NvcnRfYnk9JnBfZ3JpZHNvcnQ9JnBfcm93X2NudD0xOTk0JnBfcHJvZHM9JnBfY2F0cz0mcF9wdj0mcF9jdj0mcF9zZWFyY2hfdHlwZT1hbnN3ZXJzLnNlYXJjaF9ubCZwX3BhZ2U9MQ**
Apr 15, 2007 | Polaroid TBX-2000AF 20 in. TV/VCR/DVD...
Remote control codes
Please give us the make and model of your universal remote and we may be able to help more other than that the best i could find were 195 and 196 - try them out Hope this Helps:)
Mar 18, 2007 | Aiwa VX-S205 Combo
Toshiba MV19N2 19 in. TV/VCR Combo Logo
413 people viewed this question
Top Toshiba Televison & Video Experts
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
