Question about Kenmore Elite 45986 Front Load Washer
Kenmoore wont spin front end loader
Kenmoore he 5t wont spin
Won't spin on the spin cycle it just has a grinding sound
Posted on Feb 24, 2009
Samsung wf8750lsw front loader door wont open
Not sure if you mean when it is fully off or operating, but if you mean that once it is operating the door won't open, then the following applies...
Once a front loader wash cycle starts, the door on a front loader is physically (electronically) locked until the full cycle ends after spin dry. This is to prevent anyone opening the door and letting all the water out in the middle of the wash cycle, which a lot of people try to do to put in more clothing etc.
Apr 11, 2014 | Zanussi F1045W Front Load Washer
Kenmoor elite he 5t steam washer 47787 leaking from bottom. cant tell where leak is origanating from
Check your incoming fittings at the back of the machine-then if they aren't leaking your going to need to do a tear down and check inside machine-if you can't see anything going on you may need to hook water back up and run to see where the leak is-cheers Denny
Oct 26, 2013 | Kenmore Elite 45986 Front Load Washer
I have a kenmore smartwash quietpak 9 HE 5T front loading washing machine for about 2 years. Today I did a load and the water will not drain from the washer so I had to pull the clothes out and wring the...
Likely the drain hose is kinked or blocked...Or the pump filter blocked or pump is faulty. Most likely the filter needs to be cleared. This should be accessed via a small hatch at floor level. Or behind the kickplate. unscrew filter and clean. Make sure the machine has no water in it. Leaning it back against the wall will help with visual inspection as well. Make sure coins haven't jammed in impeller. Good luck.....Nomess
Apr 18, 2010 | Washing Machines
I have a mo# FTF2140ES0 front loader washer that won't spin
check the pump for a blockage,if the water cantget out of the wash tub,the machine senses this and wont spin out the load,also make sure to check both sides of the pump from the tub to pump and pump to house drain sides
Mar 12, 2010 | Frigidaire GLTF2940ES Front Load Washer
My Kenmore HE 2 Plus front end loader washing machine has a load and when I open the door water pours out. It will NOT spin
since front loader wont spin till its empty
id be willing to b et you have a clog in the pump
get a few towels
and spread em out in front of the machine
take off the fron toe kick 3 T-20 screws on front lip bottom
you should see the trap cleanout dead center
turn the handle 1/2 tun and pull straigt out...
be advised the washer will dump
you now have the sump in your hand ensure it and the pump inside are clean
reassemble and test
use 1 tablespoon of soap no more
suds will mess this machine up
Oct 06, 2009 | Kenmore HE2 Plus Front Load Washer
Simpson Esprit 6.5kg front loader wont spin
Try these steps
  1. Test the lid switch
  2. Test the timer control
  3. Test the centrifugal switch
  4. Test the water level switch
  5. Inspect the motor coupler
  6. Inspect the drive belt (belt drive only)
  7. Inspect under the washer for soot (clutch)
  8. Test the motor
  9. Inspect the pulley
  10. Test the transmission
pls rate my suggestion
Jul 06, 2009 | Washing Machines
During spin cycle washer spins fine but toward the end of the cycle it spins out of control like it is out of balance? Any help is greatly welcomed.
Some front loaders have a super high speed at the end of the spin. Front loaders don't like small loads, the laundry does not spread out evenly enough for a balanced spin.
May 08, 2009 | Frigidaire ATF6000ES Front Load Washer
Front load washer wont spin
yes. the solinoid or wax motor (depending on which switch you have) has fail and is not telling control that the door is locked. replacing the switch will fix it
Nov 20, 2007 | Kenmore 44102 Front Load Washer
LOCK AND LOAD ISSUE
can you be more specific about the funny noise. When does it occur, during agitation or during spin? something might me stuck in the drain area of the tub and as the tub rotates it rubs against it.
Jun 28, 2007 | GE WSXH208A Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
165 people viewed this question
Sal De
fordexpert
Robert Rankin
