Question about Sony LAMP BLOCK XL2100U Projector Lamp
XL-2100U lamp cycles on and off
I bought a new replacement lamp (XL-2100U) and changed out the old bulb. Now when I turn on the TV the picture comes on and stays on for a few minutes and the bulb goes out. It repeats this for about 15 -20 minutes and then the bulb stays on and the TV is fine for the evening. Any suggestions about what may be happening and how to fix it?
  • wabeech Sep 24, 2008
    I did as you suggested with the non Sony lamp. It still did the same thing, but "the warm up period" didn't last as long. This TV does not get used much. A few times a week to watch a DVD. Could the lamp just need to be broken in? Thanks for the advice.
  • rocky37 Apr 20, 2009
    My Sony KDF-50WE655 would turn on for about 30 seconds and go for 2 mins. and repeat. I have not change the lamp yet. Would this problem be the lamp? It has been a few years already. Thank you.
Hi
I recently had a similar problem after replacing my lamp the set would work for 22 mins then go into standby for 30 sec then come back on, then repeats, I decided to experiment with the lamp housing, I removed the new lamp, unscrewed the top of the lamp that holds the actual bulb then switched out the main housing (bottom part) with the original housing, that seemingly has corrected my problem, you may want to try if the replacement lamp did not come from Sony...good luck
Posted on Sep 22, 2008
  • TAC623 Sep 24, 2008
    Hi
    Sorry it did not work for ya, it is quite possible that there may be a defect in the lamp, If the problem started immediately after the new lamp installation I would def have it exchanged from the place of purchase, just be sure to switch back the casing before returning it. One thing before doing that let your tv run about an hour to be sure it did not take, my method did not take immediately, I don't know exactly the time it took after switching out the box it did still go on standby at least one more time before remaining stable. And the problem seems to have gone away it has not gone to standby since. I suspect that my problem was the actual connection screws it was not the same as the sony lamp. Anyhow just a little food for thought. Good luck }:)
I have a Sony model KDF-50WE665. Made a pop and the picture went out. I think it's been slow to come on now for a couple of weeks, so it's probably the bulb. Can you tell me: 1) Where can I buy...
The lamp you need is Sony XL-2100U ($78 at Amazon) or XL-2100 ($84 at Amazon).
Turn off the TV and wait a few minutes before you unplug it (let the cooling fan run). Then wait at least another 30 minutes before replacing the lamp. There are two screws on the rear panel (left and right sides near the top left of center of the small panels on the on the ends). Loosen the screws and then pull off the front panel (below the screen). The front panel has to be pulled off in stages - start at the right side and pull forward and down, then the left - pull forward and down and then the middle - pull forward and up. Loosen the screw on the lamp cover with a coin and remove the cover. Loosen the two screws that hold the lamp (use an allan wrench) and remove the lamp by pulling it straight out. Slide in your new lamp (handle with care - use a glove to avoid any oil from your skin getting on the bulb). Tighten the two screws. Then replace the lamp cover and tighten the screw. (Make sure that the screw goes into the unit straight - otherwise the safety lock may keep the TV off.) Reattach the front cover and then tighten the back panel screws. Put the old lamp in a box after it has cooled completely for disposal.
Pictures are available in the User manual here: http://esupport.sony.com/US/perl/model-documents.pl?mdl=KDF50WE655 . The appropriate section starts at page 16.
I hope this helps.
Jun 22, 2011 | Sony Grand WEGA KDF-50WE655 50" Rear...
Sony KF-60WE610
Some of the ICs on the power supply block are damaged. This can possibly due to high voltage or defective IC. What you can do now is to get a new PS block. If you can get me the part number i can help you find it..
Feb 23, 2008 | Sony XL-2100U Projector Lamp for...
Samsung hln617w dlp tv won't turn on. Red temp
Had similar problem. Thought it was the lamp. Examined old lamp but it appeared to be good. Ordered a new one anyway. Changed the lamp but the TV screen would not come on. It would make the usual noise as it was going to come on normally but it would cycle 3 times & then turn off. The LED lights in the front panel would indicate a defective lamp. Then read about the ballast. Changed the ballast & still same problem. Tried starting the TV without the lamp installed & noticed that the color wheel did not spin. Removed old color wheel & discovered it was broken. This appears to be the cause of all of my problems. I wish I new earlier of the test-turn on the TV without the lamp being installed & check to see if the color wheel is spinning. Would have save money on the lamp & ballast.
Apr 08, 2010 | Samsung HLN617W 61" Rear Projection HDTV
I have a 2004 Sony LCD projection TV. The set
It is symptom of weak Lamp (bulb) that requires replacement.
You can buy Sony original lamp from Sony Accessories Store.
Lamp required for KDF-42WE655 part number is as follows..
A1606034B LAMP BLOCK XL-2100U
May 02, 2009 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
Sony Grand WEGA KDF-50WE655 50 in picture is dark
I had the same and replaced the lamp - made a big difference. Got the bulb on Ebay for $82.00 with free shipping. Just the bulb without housing, seller has instruction online for changing bulb - very easy. River Valley Electronics
Here's a link
http://cgi.ebay.com/XL2100U-XL-2100U-A-1606-034-B-A1606034B-LAMP-FOR-SONY_W0QQitemZ370154719357QQihZ024QQcategoryZ149975QQcmdZViewItemQQ_trksidZp1742.m153.l1262
Mar 13, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Xl-2100u
  • Installation is Quick and Easy:
    In most cases, replacing your projection lamp is quick and easy. However, it is recommended that you consult your owner's manual for more detailed instructions:
  • Unplug your Projector from your power outlet
  • Allow the lamp to cool for at least one (1) hour before replacing it
  • Remove the Lamp unit cover
  • Unscrew the lamp housing unit
  • Remove the old lamp housing unit and discard
  • Screw in the new lamp housing unit
  • Place the cover back onto your unit Caution: Do NOT touch the bulb directly with your fingers.
  • Oct 19, 2008 | Sony XL-2100U Projector Lamp for...
    Sony kf-60we610 screen in black and white
    Hi there
    Is this a DLP tv ?
    If it is then your colourwheel might need replacement
    Mar 18, 2008 | Sony XL-2100U Projector Lamp for...
    Sony kf-50XBR800 tv turns itself on and off
    I just purchased a replacement lamp off ebay and the TV is working fine now. Color looks better too (which I guess I should have expected). Search for "REPLACEMENT LAMP SONY XL-2100U" on eBay and look for seller "niosales". I paid $129 out the door. Their are other auctions for this lamp you can check out. Make sure you look at lamps that include the entire lamp housing, not just the bulb.
    Jan 24, 2008 | Sony Grand WEGA KF50XBR800 50" Rear...
    Won't piwer on
    Tried to turn it on? Sounds like you need to replace the lamp. However, I got an additional week out of my unit. Although poorly dimmed and the red Lamp light blinked constantly for that one week, at least it gave me enough warning to seek out a replacement. But so long as you're not mistaking the Power/Standby or Timer light for the Lamp light then I would have to agree with you. http://store.l-f-l.com/prod/A-1606-034-B Includes shipping to the United States and no sales tax outside of California.
    Aug 16, 2007 | Sony XL-2100U Projector Lamp for...
    408 people viewed this question
    Top Sony Office Equipment & Supplies Experts
    shaun taylor
    Jaime Hernandez
    Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
