Question about RCA P56950 56" Rear Projection Television
Convergence bad,rainbow affect,deleted from menu not listed in menu after circut breaker fuse blew.
    President:
  • 3,130 Answers
I dont understand the question. Please ask in plain english whats not working and why its not or how it started not to work please!! Whats deleted from the menu and not there??explain rainbow effect as does it move up and down the screen or side by side or sits there and looks like red green and blue lines??
Posted on Apr 07, 2006
MY picture is like a rainbow of colors....
press menu on the remote then scroll down to setup and see if the Auto convergence feature is still listed under the setup menu or has it disappeared? Please respond to this same post for assistance.
Aug 09, 2011 | RCA R52WH73 Projection Television
I can't find auto converge choice in menu of rca 52" rear projection tv.model # R 52 WH 74.
You have 3 pico fuses by your fly-back transformer. One of them blew that controls your convergence circuit. Your TV now thinks that it is a Basic CRT set with 1 tube. Find the bad fuse and replace with a 1/2 amp pico fuse, and re-solder all the pins of your fly-back transformer. Your menu should have the convergence option again.
Apr 27, 2011 | RCA HD52W59 HDTV Projection Television
Rainbow E-series will not turn on
Hi, there is no reset button on a Rainbow vacuum. There is a safety switch on all E series and E2 series Rainbow vacuums, that keep it from running without the water basin on it.
If you have any more questions let me know. I am a Rainbow seller, and a Rainbow expert also. Thank you, Ralph
One other thing. All E series vacuums have a built in circuit breaker on the motor. Some of the earlier ones, it was only a fuse, and if it blew, it had to be replaced, or removed and wired directly without it on there. Most of them have a automatic reseting curcuit breaker, that will blow and auto reset its self, after it cools off. They do sometimes stay blown also, and do not reset. If that is the case, it has to also be replaced, or removed, and wired directly, with out it on there.
Motor brushes are usually the source of a non working E-2 vacuums and when they burn out, they usually take the motor armature with them, from excessive heat and flare electrical arking to the armature.
Thank you again,
Ralph
Apr 05, 2010 | Rainbow E series Canister Wet/Dry Vacuum
Sometimes I get a rainbow on the bottom of the screen.
Your TV most likely has a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Jun 18, 2009 | Philips 60PP9202 60" Rear Projection...
3d rainbow pictures..with colorful waves..and no convergence menu to fix it.
Replace FL231, DL231 and CL230 you can get the parts and istructions at the following link listed under RCA Parts
http://servicemanuals.vstore.ca/
May 31, 2009 | RCA HD61W66 61" Projection HDTV
You will need to replace the FL231, DL231 and CL230 you can get the parts with free instructions with pictures at the following link. The parts are all listed under the RCA parts category total cost is about 11.00 http://servicemanuals.vstore.ca/
May 14, 2009 | RCA HD61W66 61" Projection HDTV
Kp-46wt500 shadow and slanted images with rainbow colors
  • Screen looks 3D
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Mar 04, 2009 | Sony KP-46WT500 46" Rear Projection...
RCA HDTV IS SHOWING SHADOWS AND IS WAVY
Go to Menu then setup look for convergence if you do not have convergence on menu then you have a open fuse FL231 it will be on the right side of FBT flyback Transfomer there is 3 of them small brown rectrangler looking caps but they are FUSES it will be the one in the Middle.
Feb 19, 2009 | RCA R52WH73 Projection Television
Convergence trouble
You most likley have bad convergence amps and two burnt resistors.Part# STK392-110.Convergence circut is located @ frot of set behind speaker grill.The only reset is in the customer menu listed Convergence reset.
Jan 12, 2009 | JVC AV-65WP74 Rear Projection Television
Fuse blew. Convergence messed up - No menu option. GE 46GW945
if you had a good pic before it went out then keep it but if you did not then toss it yes you have bad stk convergence ics this is not costly if you do the repair your self you might even have bad solder connections just look and see if your connections have small cracks in it then just solder your done good luck
Nov 15, 2007 | GE 46GW945 46" Rear Projection Television
RCA P56950 56" Rear Projection Television Logo
60 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
