Question about American Standard Plumbing
Kitchen faucet , reduced water flow / pressure
Regarding an American Standard model AS4205100 H7, one hole / single lever with pullout spray. Suddenly, there is a low volume /pressure delivery. Valves are full open, flow and pressure from all other faucets in house are normal. Screen in faucet is clean.
Is this fixable by owner?
  • 1 more comment
  • Anonymous Mar 12, 2009
    no pressure on sprayer 6310 series
  • Anonymous Mar 21, 2014
    The pullout head of this kitchen faucet does not retract snug to the base. Basically a little floppy
  • Anonymous Mar 26, 2014
    water pressure ok faucet clogged
    Novelist:
  • 171 Answers
Hi ssam1
I'm Harvey the Master Plumber.
You want to know if you can fix a sudden low volume /pressure delivery problem on an American Standard model AS4205100 H7, one hole / single lever with pullout spray And is it fixable by owner?
Yes and maybe!
All plumbing systems are plauged with debrie buildup. Every time you turn on a faucet the water starts moving and will bring bits of debrie up from the water main or well. Most are small and will pass through to be caught by the screen in the aireator. Sometimes a relatively large piece comes along and dosen't make it through to the screen. It is stuck in the body of the valve.
Fixing takes a little mechanical ability.
First, turn off the water to the faucet in question. Then carefully disasemble paying close attention to the order of disasembly so you can reverse the order when putting back together. As each part is removed inspect it for that troublesome bit. I find that a little bit of wire or a paper clip is helpfull. Carefully reasemble. If the volume is still low then you missed finding that bit. Try again or call in a local pro.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 10, 2008
Faucet whistles
According to FixYa.com: "
This is most likely debris in the aerator, filter screen or check valve in the hand sprayer of the faucet. Try removing the hand sprayer and checking the filter screen at the end of the hose. The try removing the check valve to ensure it is clear of debris. It is the yellow ring with the white plastic flap in the middle. You can simply push in on the white flap and hook the yellow ring with a cork screw. Then pull it straight out. You may want to cover the drain with a dish cloth while doing this to keep small parts from being lost.
Yes and maybe!
It could be one of two problems, one simple, one serious.
  1. Turn off hot water angle stop under sink to faucet.
  2. Remove supply line from hot angle stop.
  3. Place end of supply line in a small bucket to catch some water.
  4. Turn on cold water for a couple of seconds and backflush debris from faucet.
  5. Reconnect supply line.
  6. Turn on angle stop and test
  • Complex fix
If you have steel pipes you may be experiencing reduced flow due to corrosion in your pipes. Reduced hot water pressure in the kitchen faucet is usually the first sign since this is the faucet that is most used in the home.
Repiping is a job for a professional. Another symptom you may need a repipe is orange colored or rusty water.
May 10, 2015 | Hansgrohe Talis S Pull-Down Kitchen Faucet...
Low water pressure
Remove the spray head and point the hose into the sink drain. Turn the faucet on. If you have good pressure, cal American Standard for a free replacement spray head.
If you still have low water pressure without the spray head, ask them for a new faucet cartridge.
After replacing the faucet cartridge, if you still have low water pressure you will need to ask for a new faucet, possibly free if yours is still under warranty.
Sep 07, 2010 | American Standard Kitchen Faucet 6310 020...
Blanco harvest kitchen faucet with pullout spray low flow rate
Check fine filter at tip, probably blocked, got caught with same thing myself recently!!!
Jan 26, 2010 | Blanco Harvest Single Handle Faucet with...
Kohler K-12177 low water pressure output. Removed
check valves under sink make shure tey are all the way on but spray them into a bucket if you can to see if they are ok.
Oct 25, 2009 | Kohler Model 10433: Fort® Single-control...
Low hot water pressure in kitchen faucet
I have moen kitchen faucet # 7560 and water pressure very low. What should I do? We check water flow in pipe it is ok. I changed cartridge as well as pipe nothing help. Please let me know. thanks
Oct 14, 2009 | Moen & Replacement Cartridge
I have poor water pressure from the faucet, hot and cold, in a single handle faucet
could be a number of things.
most mixer taps have flexible braided inlet hose's make shure there not kinked.
also there may be built pressure reducing valves,usually removerable,a plumbers job really.
is there servive valves on hot and cold if so make shure there fully on.good luck ,any qs ask
Aug 09, 2009 | Kohler K-15160-7 Coralais single-control...
Small streams of water spray come out at an angle to the main stream causing water to spray over the sink and wet the operator. In checking the filter I find it to be clean with no obstructions. The errant...
You need to reduce the pressure to the tap, if you look at the isolator valves beneath the tap, using a screwdriver turn the isolator valve screw until it stops spraying.
Ihope this helps
Jul 07, 2009 | American Standard Kitchen Faucet 6310 020...
Low water flow and pressure
remove aerator and cart. and soak in limeaway over night
May 21, 2009 | Grohe 32 999 KD0 Alira Pull-Out Spray...
Plumbing Logo
1,390 people viewed this question
Top American Standard Plumbing Experts
john h
Roscoe007
Are you an American Standard Plumbing Expert? Answer questions, earn points and help others
