I opened the printer to change the colour ink cartriges. The black cartrige was left in the printer. The lid of the printer closed and the printer went into print mode. Since I installed the colour cartriges the printer only prints inblack and it is not a complete print. Any ideas please? Many thanks
I just got this printer, & don't have an instruction book, I don't know how to change the ink cartidges. How do you get the thing to stop so you can replace them without damaging the printer?
Posted on Oct 21, 2008
I removed all the cartridges and reinstalled them. The printer then worked. Thank you
Posted on Sep 11, 2008
Black Cartrige Missing
Did you use a brandname ink cartridge - or is it a knock-off brand? If it is a brand name - then the cartridge is most likely defective. If it is a knock-off brand - some printers do not recognize the electronic in the cartridge and therefore don't see it as one being installed.
This may also help
Dell 922 AIO Black Ink Cartridge Missing Message
May 02, 2017 | Dell AllinOne Multifunctional (v515w)...
Colour Printing on a Samsung clp 500
Try unplugging printer from the power and connecting it back.
Try also extracting all toners and putting toners back.
Oct 30, 2008 | Samsung CLP-500 Laser Printer
My Lexmark printer 1270 only prints in black and white although the colour cartriges have good ink levals. This has just started happening, it was happily printing in colour not long ago. Many thanks.
Jast go to print option. Then Mantainance. Then try to print a nozzale. If all the colour comes out properly ( with out dot or misline), your cartrige head is goog for print. If not, your printer cartrige head is block. To reque from the problem follow the proces:
1. Unpluge colour cartrige.
2. Try to clean the cartrige head with soft cloth and amonia gentaly.
3. Try to out the ink through the head nozzale pore by using shaking or gentaly swape by soft tissue.
4. Now put the cratrige head upon a soft tissue. ( ink will comes out). If not, repit stage 1-4 until ink come out.
Thank you
Jun 07, 2011 | Lexmark X1270 All-In-One InkJet Printer
Attempted to change the colour cartridge but a message says "Parts inside your printer require maintenance or replacement. Contact your dealer."
I would suggest you to just cleanup the printer. For this follow the steps as under
1 open lid to expose cartridge area
2 push power button to power off
3 allow printer to shut down- cartriges will park on the left side.
4 look for any ink residue under where the cartridges normally are.If yes gently try to clean it up.You may also use screwdriver then several paper towells and iso alcohol. Under the cartrige area is a black plastic tray which can slide forward. Clean under that as well.Similarly follow with colour carridges.
5 close lid and power up and it now .It should work.
You may also try to hold the restart button of your printer for 1 minute just the way you push it to turn it on.
I hope it works, please let me know your responce.
May 31, 2011 | Epson Stylus C40SX InkJet Printer
How do i change my lexmark x4650 print cartrige?
Installing/Replacing your ink cartridges:
1. Open the printer, and then press down on the cartridge carrier levers. printmastert_52.jpg
2. Remove the used print cartridge or cartridges. 3. If you are installing new print cartridges, remove the tape from the back and bottom of the color cartridge, insert the cartridge in the right carrier, and then close the color cartridge carrier lid. 4. If a black cartridge is included in the box contents, remove the tape from the back and bottom of the black cartridge, insert the cartridge in the left carrier, and then close the black cartridge carrier lid. 5. Close the printer.
Sometimes the ink cartridge carrier won't automatically move to its loading position even when the printer is on and the cover is open. Follow the steps below:
1. Unplug the printer from the power source.
2. With the cover open, hold the solid white strip that connects from the carrier assembly to the ink cartridge carrier and gently slide the cartridge carrier to the center of the printer.
3. Remove the used cartridges.
4. Load the new cartridges. Close the cover.
5. Plug the printer back to the power source.
May 15, 2011 | Lexmark X4650 InkJet Printer
My Epson c88 was working fine. I changes ink cartridges and now the black will not print.
Your printer head may be closed.To remove the problem jast open ink cartrige from the cartrige chamber. set a seringe with full of black ink into the plustic pin which are tidely insert in the ink cartrige. After push 2/3 time your printer work fine again.
Thank You .
Shohagtush
Oct 20, 2010 | Epson Stylus C88 InkJet Photo Printer
Replacement of cartridges
Go to printers in the control panel, right click on printer icon. Open printer properties then optional settings and printer setting button. You will then see what to do.
Jun 05, 2009 | Epson AcuLaser C900 Printer
When I try to change my ink cartriges the carriage will not move
With the lid open, you will see the two arms that stick out of the lid, and go into the body of the printer, they are black. and on the far left and right of each side of the lid. They have Teeth on them like a saw. When the lid is closed, these go down into the printer, and hit a little micro button on the back of the printer. When this button is pressed, the printer knows that the lid is closed. I am guessing that this button has gone bad, so the printer does not know you have opened the lid, and therefore it does not move the print cartridges into the parked posistion.
Jan 18, 2009 | HP Photosmart 2575 All-In-One InkJet...
C4200 printer stop printing in colour
check the printer property if the colour ink is mark also check the ink level if you still have ink in the cartrige. to go to the printer property click on start menu locate printer and fax click on it when open move mouse on your printer name and right click on it scrown down to property that it the last task then click on the general task click "printing references" when another task open click on the advanced. There you can find the black and white or colour you can then select which task you want to do in some clolour printer task promt automatically which you can select the task you want to perform but in other printer you have to go to the printer property to specified which task you want to do. if you have low ink level then you have to change your cartrige to new refilled ink.
Nov 17, 2008 | HP Office Equipment & Supplies
Lexmark x3470
Hi, can you help me? This printer1.gif was working fine for about 4 months and then in wont print anything anoymore. All it says to do is close the lid, but the dam thing isnt open. I tried opening and closing, removing ink4.gif cartrige and even slamming it down but still say door opened?
Feb 24, 2008 | Lexmark X3470 All-In-One InkJet Printer
97 people viewed this question
jasbo
jasbo
