Question about Brother IntelliFAX 4100 Laser Fax
Will not let me dial.
I have an intellifax 4100, it will not let me push any buttons. The only thing I get when I push any of the buttons are 3 quick beeps. It does receive faxes, there is a dial tone, and everything else seems to be working.
  • 2,120 Answers
Did you try unplugging the power cord?
Posted on Oct 06, 2008
1. Open the front cover. 2. Press the "CLR" buttone. 3. Press 1 to reset.
Mar 25, 2010 | Brother IntelliFAX 4100 Laser Fax
The same thing just happend to me. Check all the buttons on the machine and make sure there isn't one that is stuck. My "Fax" button was jammed and I didn't even know it. As soon as I wiggled it loose everything started working again.
Mar 15, 2010 | Brother IntelliFAX 4100 Laser Fax
How do i program speed dial phone numbers into my brother intellifax 4100
Per Intellifax 4100 manual:
Storing Speed Dial Numbers
Press Menu, 2, 3, 2.
2 Enter a three-digit (a two-digit for
FAX-4100) Speed Dial number, and
then press Set.
3 Enter a number (up to 20 digits), and
then press Set.
4 Enter a name (or leave it blank), and
then press Set.
5 Press Stop/Exit.
I hope this answers your question. Thanks for using Fixya and best of luck!
Jun 12, 2009 | Brother IntelliFAX 4100 Laser Fax
Brother Intellifax 4100 unable to send fax but can receive
Is the fax sensing the paper you put in to send out? Check the little black levers that poke into the document area. They should move freely when you touch them gently with a finger, and return quickly when you take your finger off. If it can't sense the paper it won't try to send a fax. If, when the paper is inserted, the display changes from whatever it said to anything else, the paper is being sensed.
Let's try dialing manually. Just left of the 1 key is a button labeled "Hook." Pressing that will take the telephone line "off-hook," like picking up the receiver of a phone. You should hear a dial tone -- if not, try adjusting the speaker volume with the buttons just right of the numbers. Once you get a dial tone, dial a number, whether it's another fax, or your own cell phone. As far as the phone company is concerned, your fax is just a phone, calling another phone. If you can make a call, and the phone at the other end rings, we're closing in on the problem. If you can dial another fax machine manually, you can still turn this into a fax call, assuming there's paper ready to fax. After the distant fax answers, touch the Start button, and your fax should take over. If you can't dial manually, try unplugging your fax from the phone line, and replacing it with a regular phone. Can you make calls with it? If not, the fax is no longer a suspect - you have a phone line problem.
Are you at a business where you need to dial 9 to get an outside line? It's easy to forget that detail when you're using a fax, but it has to dial out just like any other phone on the system.
If you can't get a dial tone at all with the fax, but it works with the phone alone, the main board in the fax is probably bad. If you can dial manually, using the Hook switch, but the same number doesn't work when you dial xxx-xxxx-Start, that sounds like a main board problem, too.
May 05, 2009 | Brother IntelliFax-4100e Fax
Unable to send faxes long distance
Do you have to dial a code for long distance access?
Oct 29, 2008 | Brother IntelliFAX 4100 Laser Fax
Sounds when dialing
Press MENU button.Try going into either INITIAL SETUP, GENERAL SETTINGS, or FAX SETUP mode. Scroll until you find either VOLUME , SPEAKER,or RINGER settings. You can change or eliminate the sounds by changing the settings.
Jun 14, 2008 | Brother IntelliFAX 4100 Laser Fax
Brothers Intellifax 4100
Can you pre program a 9 so staff can just dial the phone number
May 06, 2008 | Brother IntelliFAX 4100 Laser Fax
Press speaker can you hear dial tone?
Try ringing you mobile from fax does it ring?
After dialing correct number with (outside line prefix if required) press start
Oct 18, 2007 | Brother IntelliFAX 4100 Laser Fax
Brother Intellifax 2820 fax machine
Same thing happened to ours here at work except it was the #3 that got stuck. It was idle for 3 weeks because no one took the time to see what was going on. Five seconds on Google and 20 seconds on and we have a working fax machine again.
Mar 14, 2007 | Brother IntelliFax-2820 Laser Fax
Brother IntelliFAX 4100 Laser Fax Logo
134 people viewed this question
James Cagle
James Cagle
Jim Keysor
