Question about Sansui CVDV9000 9 in. TV/DVD Combo
Screen overscan too great
The image on this TV/VCR is too large, resulting in perhaps 20% of the image being lost off-screen. I don't see any obvious CRT gun adjustment trim pots, other than brightness and focus. I'm afraid I will have to give up fixing this issue without any schematics or further information. Everything else is normal on this Sansui TV/VCR, so I hesitate tossing it for a new one. Thanks for any advice...
    President:
  • 3,130 Answers
SOUNDS LIKE YOUR OVERSCANNING FOR SOME REASON.. MMM STRANGE AS USUALLY THERES AN UNDERSCAN PROBLEM IN THE VERT WITH THESE SETS.Opps sorry about caps. I would check to see the power supply ic and make sure its not putting out more then its supose to as I remeber those are between 125 and 130 volt dc output. as maybe the High Voltage shutdowns not working.oh is is too long and too wide??? if its only like too tall there is a small opot on the pcb thats for the verticle height buit its so small and easy to break off and if you do that the set will lose the verticle sweep totally. good Luck
Posted on Apr 07, 2006
SOURCE:
How do I adjust tv screen size to fit laptop? lap top projection is to large for operating properly. to big.
Assuming you have a flat screen 16x9 TV, make sure it is set to screen fit so that there is minimal overscan. The button should be called pic size or aspect ratio. Also set your laptop to the same resolution as your TV or as close as possible to a supported resolution.
Feb 02, 2018 | Televison & Video
Repaired the convergence and now the image quality is good but the TV seems to be over projecting the screen. The top, bottom and sides of the image are cut off slightly. is there a way to adjust?
Hey! its me again. I think what your experiencing is called overscan. This website might help but if not just google how to fix overscan on a projection tv.
http://www.cnet.com/news/overscan-youre-not-seeing-the-whole-picture-on-your-tv/
May 24, 2016 | Televison & Video
How do I enter the service menu on an Emerson EWF2004 CRT Television? (Pictures of the OVERSCAN ISSUE will be provided if needed.)
Older sets had vertical and horizontal size controls. If you have the horizontal size control, turning it counterclockwise will reduce the size of the picture horizontally and reduce the overscan.
Feb 25, 2016 | Emerson EWF2004 20" TV
My tv scren has been shrink, how to return it to the regular size. thanks
Try:
Main Menu - Picture - Screen Settings - 16.9 Overscan - ON
This mode displays the image for 16.9 aspect and when on enlarges the image to hide the edge of the image.
Good luck.
Sep 26, 2014 | Samsung Televison & Video
Magnavox 37MF337B/37 overscan only sometimes problem
This TV has a pixel resolution of 1366x768p
It will accept a 1920x1080i input from a high def source , but running a PC at 1920x1080i/p will cause the problems you describe, depending on what the PC is sending to the TV, because PC signals are not the same as high def.
Your PC should be set to a resolution as near to 1366x768 as possible. My PC allows 1280x768 and 1360x768. Try one of these for best results.
There are no settings on the TV to solve this problem.
Feb 06, 2008 | Philips Magnavox 42MF521D/37 Television
Overscanning
On your remote control there should be a button that lets you change the screen mode, IE. Auto, Panorama, Cinema, Full, Normal, Zoom, etc...
Jan 23, 2008 | JVC AV-27D305 27" TV
Panasonic NV-J45
Has VCR to TV hookup been changed? Cabling errors will result in no display from the VCR (no tape video/audio, no menu display). If you are using the TV aux/VCR input connections, you must select this input before anything from the VCR will be displayed. If you've verified hookup is correct, then perhaps something is afoul with the VCR. Try hooking it up to another TV.
Sep 03, 2007 | Televison & Video
Image on my Apex TV/DVD combo is too large for the screen
deer joe you need da service manual,becouse your tv is altereyted the memori,you moust going the center service for definetival reset
Jun 02, 2007 | Apex Digital GT2715DV 27 in. TV/DVD Combo
Sansui CVDV9000 9 in. TV/DVD Combo Logo
325 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
