Question about HP Officejet J5780 All-In-One InkJet Printer
Wont print i am here, i reported our issue earlier, i was not able to see your message as well as mine pn the chat console. anyway, i was asking more information about your concern...
I have a HP J5780. Printed one page this AM and it stopped printing black. Called HP, seems they know about this problem, said it was a software problem. HP wants 56.00 to put me on another year warranty (my one year was out in June 08). Does anyone have a quick fix for this problem that might cost a little less ???
Posted on Sep 24, 2008
Don't need the help now. Please leave me alone. I solved it myself without your help.
Posted on Sep 11, 2008
Wont print server reports
hello,
to print a server report you should be the admin if you are please check if you are in the whight mask to print the report
Sep 12, 2012 | Casio QT 6000 Point of Sale Terminal
I was trying to get in to my facebook chat on my cell phone and appears a message that said that my acount was temporally blocked,not my wall,only the chat,what can i do? I cant chat,thanks!
This means that you did something prohibited during chat or were reported by someone you chatted with. Contact facebook to either petition the charges or determine the length of the issue.
Mar 08, 2011 | Cell Phones
Chain oil pump does not work when pumped. Eager ****** MAC 100 series
Your Eager Beâver model number is 600016. There are many prefixes and suffixes. The one below I used when repairing a similar problem with my Mac 110 (earlier version of your saw). Both the automatic and manual oilers work now.
I get the best results for new McCulloch parts here:
This is a little complicated so I am going in small steps.
M & D Mower
http://www.m-and-d.com/parts.html
Click “Illustrated Parts Diagrams ON LINE”
Click “Click Here for Parts Lookup”
Changes to “Select OEM” Window reads “Briggs & Stratton ▼” Click the arrow and select “McCulloch Power”
Click “Gasoline-Powered Chain Saws”
Click “18-600016-27”
There is a shipping and handling charge from M & D (about $9) if all parts in same container only one fee.
See “General Assembly” print
Item 33; pn 85557; Oiler body; most likely failure, on bottom of Item 31
Item 31; pn 217755; manual oiler piston; It pulls through the top of the tank. I ordered a new one but got Item 36, they were the same pn, I complained, seems they fixed it.
See “Powerhead Assembly” print
Item 07; pn 219989; oil pump assembly
Item 04; pn 217168; pump/bar pad connector (hose)
Item 05; pn 217167; pump/oil tank connector (hose) The new one was to long, I used the old hose. I have an earlier model.
Item 17; pn 110653; O-ring
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 06, 2010 | McCulloch Garden
Yahoo messenger chat problem.
Yahoo Chat Rooms have always ben having this kind of issues, anyway its recommended that you disable your Popup Blockers for the verification window to open up.
Sep 12, 2009 | Yahoo Messenger
Wont stop printing TX report!
moz-screenshot.jpgmoz-screenshot-1.jpgmoz-screenshot-2.jpgmoz-screenshot-3.jpgHere are some of the instructions you'll need, but you can also find more assistance by accessing the online Canon support site and searching the exact error message you get. (click here)
ssue:
ERROR LCD: INCORRECT PAPERSIZE
Solution: Reset the unit-IC D/PC 1000 Series
Reset the unit
  1. Slide the platen to the left.
  2. Slide the platen back to the right until it locks in place.
Here are instructions for changing the setting of the tx report:
Issue: How do I change the TX report
Solution: Changing the TX Report-IC D/PC 1000 Series
  1. Press <Additional Functions>.
  2. Use <la.gif> or <ra.gif > to select [FAX SETTINGS], then press <Set>.
  3. Use <la.gif > or <ra.gif > to select [REPORT SETTINGS], then press <Set> twice.
  4. Use <la.gif > or <ra.gif > to select the option you want.
Name Description TX REPORT 111OUTPUT NO
111PRINT ERROR ONLY
111REPORT WITH TX IMAGE
111111ON
111111OFF
111OUTPUT YES
Enables/disables automatic printing of a transmission report. No report is printed.
Prints a report only when a transmission error occurs.
If you select PRINT ERROR ONLY or OUTPUT YES, enables/disables printing of the first page of the fax under the report.
Prints a first page only when a transmission error occurs.
The first page is not printed.
Prints a report every time you send a document.
(The factory default setting is in bold face.)
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Apr 20, 2009 | Canon imageCLASS D880 All-In-One Laser...
Erroe message evertime I want to print.
Sounds like your issue is with your OS, not your printer.  You need to backup your data on the computer and reinstall your OS.
Feb 01, 2009 | Lexmark X125 All-In-One InkJet Printer
Al-1540 only scans, wont print says-data could not be sent to pri
it seems that the computer was trying to send the data to the printer through the wrong port. i went to the control panel in windows xp, and selected printers and scanners. and added a new printer (manually) as al-1540 cs on usb port 2. it alerted me that the software was not signed, i proceeded anyways. it asked if i wanted to keep the original printer , i said yes. and the test page printed away. so i would suggest people with similar problem to keep adding multiple copies of the printer again and again on usb ports 1,2,3... etc till it prints the test page. use the copy no. indicated in the printed test page to do all your print jobs in the future.
Dec 09, 2008 | Sharp AL-1540CS All-In-One Laser Printer
Cant chat to 1 of my freinds on xbox live
What is their internet connection speed?
Your friend may not have port forwarding on their home network and the network router filters the Internet NAT redirection...
Setting up a DMZ (Demilitarized Zone) on the router for the Xbox gives it unrestricted access to the internet; also puts your Xbox outside you routers firewall.
DMZ ports have to be programmed manually and the IP address also must be manually entered; The DHCP Automatic IP address puts the Xbox back behind the firewall; just duplicate the automatic DNS Server settings and the Netmask. Then choose a IP address outside the Automatic IP range (e.g. 192.168.1.175)
If that does resolve the issue see if the other Xbox needs a Live Update.
Nov 28, 2008 | Microsoft Xbox 360 Console
Where are you
i am here, i reported our issue earlier, i was not able to see your message as well as mine pn the chat console. anyway, i was asking more information about your concern... http://www.fixya.com/support/t1029576-wont_print
Sep 10, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
"waiting for report" /won't copy
I experienced this problem when "Fax Setting -> TX Setting -> Print Report" is configured before you send out the fax.
After your Fax was sent, and the message "Waiting for report" appear forever and does not leave.
It is because your INK Level is Low and your have set "Fax Setting -> RX Setting -> Auto Print ON -> Print when no ink OFF", and so the report will not be printed out due to ink level is low.
Solution:
Configure "Fax Setting -> RX Setting -> Auto Print ON -> Print when no ink to ON", and the report will be printed out immediately, the message disappear.
Apr 22, 2008 | Canon PIXMA MX310 All-In-One Printer
HP Officejet J5780 All-In-One InkJet Printer Logo
56 people viewed this question
Seeker5211
Seeker5211
